(goldfish)
Everything posted by (goldfish)
  1. IS that price with the turbo? If not why are you looking for a turbo engine? What is attached to the engine in question?
  2. http://www.northerntool.com/webapp/wcs/stores/servlet/category_6970_792193+763941+769650 Sorry, best I can do. Harbor Freight use to have little copys of their Al jacks.
  3. HF, like all cheap china stuff, you have to be the quality control. They have good stuff and bad. Those jack stands are solid.
  4. Agreed, the Zx should have no problems starting. Did you check the fuel pressure after turning the engine off? Also check timing and radiator, maybe it's running a tad to hot.
  5. Sounds like talking with norm on zcar.com would be good for you. he has a ton of experience in that area.
  6. Even better the paid AVG has an anti-malware option that works good (old Ewido sp?) more anti-spyware >> http://www.lavasoft.com/products/ad_aware.php Also if you have XP get MS Defender >> http://www.microsoft.com/windows/products/winfamily/defender/default.mspx
  7. You might want to check if it has cv's also. more money to you. The last '82 2+2 I looked at had the cvs in back. Dang, 500 is a little steep for me, I'm still looking for a job. About all I could do would be 200 for the engine+tranny. Sorry, money's tight. I could pick up, I have to do some work for my grandma in Souix Falls.
  8. Rust doesn't look that bad.. Did you get a chance to test it's engine? I'll PM you phone # so we can hook up.
  9. http://www.miata.net/garage/tirecalc.html Give a pretty good idea of how the different tire affect the speedo.
  10. Rubber also has a changing coefficeint of friction, It actually increases as the pressure decreases.
  11. I would say that both systems measure crank angle as neither are driven from the cam. Just the the 81 system is more accurate because of the gear slop and such, but seems to be more prone to failure.
  12. I was like not a bad idea Until the part of leaving the blade in...
  13. Have you checked the Inner tie rod end? I haven't seen rack bushings mentioned, and I have heard of the steering column u-joints going bad, but not often.
  14. I'm sorry to hear Subaru hasn't fixed the seizing pin thing, real common on them. I don't know what to say about the aftermarket parts clownishness.
  15. http://www.amazon.com/Modify-Your-Nissan-Datsun-Engine/dp/1931128049/ref=pd_sim_b_2 is good too.
  16. The 81 US turbos were indeed auto only. They changed that for 82-83.
  17. I'll lend my ZX for the coupe version. It's not doing anything anyways
  18. I'll help you some more Jeffp Timz 1fastZ
