(goldfish)
Everything posted by (goldfish)
  1. Don't forget to unplug the second connector from the dizzy.
  2. My 97 legacy is alot like the earlier one you pictured, but has a recirculate.
  3. How much were they asking? And where may I ask.
  4. Possible but unlikely. Maybe try measuring fuel pressure right before the FPR.
  5. Component speakers typically have better crossovers. As for needing more power, that is only an issue if you turn the receiver up to much, asking for to much power out of the amps. Amps have a designed load they work against. By bridging or running 2 channels to the same speaker will reduce the load seen by the amps, possibly causing them to burn out.
  6. 9.7:1 sounds a little high for a setup like that.
  7. Erase the main part. "I". The recovery part can boot on it's own and will let windows get re-installed.
  8. I had problems with MS conflicting with a game and hogging all my cpu cycles.
  9. the red and black ae's are def. more rare than the gold.
  10. Malwarebytes is not an anti-virus program! I typically use the free AVG, but have read in several places that both Norton and Mcafee have updated and improved their 2010 offerings. And none of these products install viruses just so they can remove them, they are all legit and on the up and up. Just maybe not the best they could be.
  11. Thanks for the tip. I'll stay away from Proven Force if I have to get something rebuilt.
  12. I say make your own. If I remember right the cartech boxes are just that, simple boxes. As a side note, JnJDragracing say the R200 can handle the torque you'll be making.
  13. They have posted on this site frequently. Sound like good guys.
  14. PM Yetterben. He's in Wi and recently did this. Check on Zcarchat for people willing to do stuff in that area. Facebook too.
  15. Must must be a midget if you fit in a Sky
  16. Man, did you see that baby squat in the back
  17. If you look at the specs pdfs they have prices listed. $2k tables
  18. If you need parts, maybe try posting on zcarchat. I know one person parted a 81 zx out recently, I don't know what else he might have still.
  19. Camp-Inn trailers are stated as 850 with 130 on the tongue. I would think that was really bare. Don't forget the weight of your food and gear. I could see an easy 300 more. But here is their spec sheet. http://tinycamper.com/spec.htm
  20. I ran into trouble trying to set the timing on my 82zx after replacing the engine. The replacement engine is a L28 out of an 81. The timing is retarded past the point that the slots in the dist. will allow for. I tried dropping the oil pump and spindle and pulling the dist. off and reassembling everything to the 82 FSM ( and Haynes). It is still about 10 degrees? retarded. Which way should I line up the punch mark in relationship to the oil hole on the pump? About how much? I think it's an 81 turbo auto pump if it matters. Thanks
  21. The crazy part is the backgrounds are real. There is a show info button in the top right that has some interesting notes.
  22. And now I know how to make copyright signs. The amazing things you learn from Tony
  23. Is this the one? http://www.hammondsplains.com/z/zworld/280zone/
