Gollum
    19
Everything posted by Gollum
  1. Irony of irony is that my S30 doesn't look a whole lot better, but would never get the attention of that car for the simple fact that I don't have obscenely stretched tire on wide rims with absurd camber and no ground clearance. I think Yuta still has a dash, I win.
  2. Actually running cylinder pressure readings on dyno's would be wonderful. Unfortunately that's more rare than scientifically done testing on dynos... I can appreciate HowlerMonkey's opinion as he has experience, but he also didn't specify very much information to go with his statement and of all the other times this has come up I still haven't heart hard data. I'm not saying he's wrong, I'm just saying we don't have the full picture of the scenario in which he gained his data regarding detonation and pistons falling apart. We don't know: HP Achieved Ignition Timing Ignition Map Data Ignition Logs to show signal scatter Wideband Data to couple to ignition logs Engine prep info before assembly Turbo used Intercooler setup used ECU used etc etc etc It doesn't take very much research to find out that, again, IDEAL, timing (meaning if detonation doesn't happen, where the best power starts) has very little to do with VE at all. It has much more to do with chamber shape, mixture quality, mixture ratios, chamber temps, etc. Just because an engine has poor VE and only makes 60hp per liter, doesn't mean it's going to need 40 degrees of advance, or will detonate easily. Chevy's fast burn economy heads for their SBC engines can see similar total ignition timings (even with detonation free race gas) similar to very efficient honda engines that are making nearly double the HP/Liter. By very nature, a higher compression L motor will have a LOWER max power timing because it has a smaller chamber. If you add quench (which flat tops on a P90 will) you'll have an even lower still max power timing setting. So again, you can't just use the same timing curve for both setups and go + or - on the dizzy and expect great results. Just because some people haven't had as many detonation issues with high compression L motors doesn't mean they were making less power at all. It just means that most likely their timing setup was better matched to the fuel and engine combo they had. There's WAY too many factors that will effect timing to make any blanket statements about timing in my opinion. I've seen enough well seasoned racers with cars down as low as the 7's who tune their engines by reading plugs that will tell you that "don't look for max timing, look for max power timing" to know that the assumptions made by most car guys is a bit narrow minded. If you wanna play with HP, you gotta learn the dynamics if you expect your engine to hold together. In my experience, if you're having detonation issues, I'd say you need to get out an IR temp sensor and figure out where your AFR's are during detonation events. Make sure you don't have hot spot issues, and make sure you're running plenty of fuel where you're detonating. Also take your injectors out and have them flow benched, you might have a weak injector causing issues. That's all as likely more likely to me than battling compression factors.
  3. Or ANY head design... It's a pretty blanket reality. Even the BEST head design engines can reach catastrophic engine failure. A 800hp supra engine WILL be damaged from detonation. A 500hp honda motor usually holds together if it's 100% detonation free. Both those engines would NEVER fail from SEVERE detonation at stock HP levels. I don't speak from theory, I speak from experience.
  4. Though the physics of what detonation is doesn't change, the effects of it change DRAMATICALLY is what I'm saying. I'd say 90% of vehicles pre 90's were designed to exhibit mild detonation under heavy loads. Drive any truck from the 70's and you'll understand what I mean. Yet most race cars that see any amount of audible detonation like the trucks mentioned above will probably be taking considerable damage.
  5. That's all debatable relativity though. The overall piston specs from dish to NA are nearly identical and there's no reason for the flat tops to blow up before the turbo dish pistons. And I've run timing in all of my NA cars very aggressive and I've had times where they've pinged all day long and survived just fine. It all comes down to the output of the engine when it comes to detonation. No piston should fall apart under detonation when pushing 80hp per liter. Now getting upwards of 120hp per liter things usually get temperamental in any production engine. So this again, is something I feel we don't have concrete information on. The question I want answers to is: "At what power level does mild detonation become damaging in the short term on both piston types." We know that for dish pistons, once you're up to 400hp detonation will rapidly ruin your motor. What we don't know, is the similar limits of flat tops. I personally can't imagine it being a whole lot less.
  6. The main drawback to most of the fun roads that are truly "in the bay area" is that they're generally crowded with cyclists and foot runners. Be very careful out there. That's one of the nicer things about having moved out to Vacaville for me, is that for the first time in my life there's SEVERAL local roads that are awesome drives that I rarely see traffic on. Not that I endorse crossing the lines, or speeding, but things happen on windy roads and the less traffic the safer they seem to be. Road conditions are also better out here too. Roads in the bay area are fairly abysmal. Regarding meets, I throw one at least once a year, usually mid/late summer. Pretty good size shindigs with burgers, plenty of diversity, and all around good people. One thing you'll probably notice is that many of the south bay car guys (z car guys are better, but not immune) tend to be pretty exclusive to their area. While guys from the Sac, modesto, marin, and even modesto regularly drive several hours to get to a car meet, south bay guys like to stay within a 30 minute drive. Part of it I'm sure is the fact that traffic is so bad out there that many have little desire to go further than needed, but it's gotten past being humorous for me. A good example is that I've sold a lot of stuff on craigslist, and the only times I've had people ask for me to drive to them, or meet them half way is when they're from the south bay. It hasn't just happened a couple of times, but a lot. One time a guy wanted to buy a $20 oil pump from me, and wanted me to travel an hour to meet him.... yea right...
  7. You know, one of these days I'm going to do some documented, scientific testing to put some myths to bed. And here's what I'd like to do. 1. Prep two as identical as possible F54 shortblocks, one with flat tops and one with dish pistons. 2. Prep a P90 to as OEM specs as possible. 3. Dyno the head on each shortblock with race gas to find ideal timing requirements. 3. Dyno with pump gas to find true detonation limitations. I have yet to see a SINGLE blown turbo motor using the NA flat top short block that actually failed due to the higher compression. Usually these failures are from people trying to just slap a P90 and turbo or just a turbo on the NA engine without resolving the engine management issues, and it it DOES knock it's because they're running the NA ECU which won't retard timing under boost. I even have a stock '81 280ZX waiting for an engine rebuild, and I have a spare P90 sitting on my shelf... Maybe one of these days I'll get around to it. I still firmly believe that all the hype about "not being able to run as much timing" is widely misunderstood. More timing isn't always better. Ideal timing is ALWAYS better. Know where the power for YOUR setup is, and strive to get there. KNOW the fuel you use, and what it's burn characteristics is. It's well documented that there's more power in timing than in compression, but many people fail to understand that not all setups will make peak power at the same timing specs. I don't know how many ways I can say this, but a smaller chamber space doesn't need as much time to burn completely, thus requires less timing for ideal power. Just because you raise compression with flat tops and can't run as much timing doesn't MEAN you've LOST POWER!!! I'm not saying run as much compression as you want. I'm just saying I don't think we have enough concrete information (from what I've seen) to make blanket statements about what's "best".
  8. You know, the irony I find in that Z is that every top I've seen on a cobra just looks wrong, or like and afterthought. When's first saw that z though I thought it actually worked, and seeing it again I think I believe so even more. It's one good looking car.
  9. I think, and this is just thinking and really grasping at straws here, if you order the RB, and NOT the RB-R rim the center cap MIGHT clear. Reason being is that the original RB prototype used basically a cast in place spacer to get to the offset specifications that we were wanting. When the prototype came in Chris was like "what the hell, this isn't the RB?!" and after contacting rota found out it was the RB-R that we wanted, and then he also specified that we'd like it if the rim spokes were actually moved in, not just mass added to the mounting surface. As far as I know, BOTH went into production. The RB rim is heavier and has less lip, and thus also has deeper sunken lug holes hence the center cap mount surface is further from the actual hub. If only the RB-R went into production then center caps will not really have a hope to fit. Custom caps would be required. Personally, I'd say just get your caps painted and call it good.
  10. Anyone else hear that knocking? I think it's opportunity. Sounds like it's saying, "Mike, buy a turbo for that bimmer." You know, there's not many bimmers I really would like to own, and the E36M3 is one of them.
  11. 10k for a 400hp L28ET eh?.... Mighty spendy for such a simple power solution. Has anyone here with 400+whp with their turbo L spent more than 10k? And if you have, are all those parts actually on the car? I know some have gone through 2, 3 or 4 turbo setups, multiple intakes, etc. That starts to get expensive. I hope this doesn't sound to arrogant, but I bet I could make a fairly reliably 400hp L28ET for under 5k. Only reason I haven't is that I have less than 2k in my ENTIRE CAR.
  12. Let it be shown for the record I don't disagree with this at all. I said "probably" because the scenario I was describing is usually when people put race gas in which isn't anything like pump gas and they do it for tuning reasons, then they see how much extra timing they can run and how much power it produces and assume it's "just timing", which isn't necessarily the case. Timing is VERY important, but it's not always a linear comparison from setup to setup. That's what gets people screwed up when comparing setups. Even in the datsun case, comparing a P90 with dish pistons and a P90 to flat tops is NOT apples to apples for timing requirements. It's a completely different combustion shape and flame front speed, thus different optimum timing requirements. For example, if you took detonation out of the picture, and could run "optimum" timing at all RPM, you'd see that a flat top+P90 combo started falling off power SOONER, than dish+P90, regardless of which one is making more or less. This example should hopefully show how one engine might "require" more or less timing versus another. If guy A is runing 32 total timing, and guy B is making more power with 35 total timing, that doesn't mean guy A will make more power by adding in 3 degrees of total timing.
  13. You my friend, seem to have a good head on your shoulders. And just so you know, your goals are entirely realistic. Focus on good chamber work and you'll be fine, despite the terrible intake. Past 300hp I'd seriously consider a better intake of course, but we're all limited by certain things, like money, and as such few actually take the time to make or buy a quality intake for their L motor.
  14. My suggestion would be to look into sunbelt cams, and other people that have made L specific cams. This might not mean much on turbo application, but several people's research indicates that the majority of common aftermarket cams out there were designed around other brand engines and their valve train, namely BMW. Sunbelt is among the few that actually designed aftermarket cams around the L motor's drivetrain geometry and ended up being able to make larger lift and duration cams that could use factory seat pressure just fine with no float issues. Most cam retailers offer L cams will tell you to upgrade springs for anything other than a mild upgrade, while people were making substantially improved power with minimal seat pressure on cams actually designed for the motor. The old timers in this field is isky, and are highly recommended by many. Many a builders have used their cams with GREAT sucess. 715149 is their part number for their stage 3 cam, which is basically a high lift cam with slightly more duration than a stock cam. I believe isky will also do custom grinds if you want more lift with less overlap, specifically for turbo application. Also, just their stage 1 cam would be more than youre .460 lift you were looking for, at .475, with 222 degrees of duration. I'm not sure what the lobe centers are. That 222 degrees is the same duration (or nearly so) as a stock turbo cam would have, and roughly 10 degrees less than the 240Z A cam mentioned. This should show that running a little more duration isn't exactly a bad thing on a turbo application, seeing as the "A" cam does so well. I'd go with the stage 2 or 3 isky cam if you go with isky. 300whp is easy btw. Add air with extra boost or better flowing head, and make sure you have an ECU that can tune it. The stock turbo will be way out of efficiency at that power level, but a well sized T3/T4 hybrid would do the trick. Some people have used Holset turbos with success too. 300hp is old hat, and easy to do. People have done it a million different ways. There's no "magic setup". I can say "well this is what you need to do" then I can show you a build that contradicts me. People have done it with bone stock longblocks, stock turbos, and stock injectors, and even with stock ECUs. I can't think of any that used ALL of those stock parts, but some have come close. One guy using stock injectors had his rail pressures over 100psi and used a twin pump setup. Some people using stock turbos use meth/water injection to combat the heat. Some using the stock ECU use RRFPRs with a larger turbo closer to it's peak efficiency in that application to get there. For most purposes, 400whp is the point at which things become sketchy. At that point the stock pistons will blow head gaskets and ringlands with mild detonation, that's usually very hard to catch before it's too late. What I've heard people say, which I think is great advice, is to tune your ECU on junkyard bottom ends. If you blow it up, go get another. No big deal. Then when you've got your tune solid and you're pushing your power goals on stock pistons, then build up your forged piston bottom end. You can easily blow up your forged pistons due to a bad tune at 400hp. Get the tune straight FIRST, then you won't be wasting money. No a requirement, just advice from people who've been there.
  15. Another good thread to look at http://forums.hybrid...p-progress-pics Flatblack is another member that just came to mind. He was running a NA-T conversion and I'm sure he was probably knocking on the door of 300hp. He's someone who's still around often that can be PM'ed.
  16. I'll do some digging for some people running turbo+flat top setups, but I also expect you to search as well. That said, I find it funny going through old threads like this one - http://forums.hybridz.org/index.php/topic/13564-i-need-help-on-my-280zx-turbo-project Notice that though people are suggesting starting with a turbo motor, nobody is freaking out about the compression, or saying that the NA motor can't be turbo'ed. It's just me guess, but I'm betting people like scottie were suggesting starting with the turbo for a COMBINATION of reason, and a big part of that is that the oil pan is already tapped for oil return, there's already an oil fitting to go to the turbo at the pressure sensor. There's already larger injectors. It already has a turbo exhaust manifold. The list goes on. Yet, nobody (at that time, in 2002) seemed to care to bring up the compression aspect.... Food for thought? There's two people here who did NA->turbo conversions. Cody is still fairly active, send him a PM and find out how much boost he braved before he wreaked that first Z of his http://forums.hybridz.org/index.php/topic/20021-has-anyone-put-a-turbo-on-a-na-block More people you can PM http://forums.hybridz.org/index.php/topic/23501-calling-all-flat-top-piston-turbo-z-owners/ You can see a similar discussion that comes up quite often in the NA realm too. User: Mack has run MUCH higher compression on pump gas than others recommend, or even think possible (again, some people). Some people say running anything above 9.5:1 NA is just too much for pump gas, yet there's people running 10.5, even 11:1 on street driven Z cars. There's WAY more that's going on than just static compression that results in detonation issues. Some people are convinced that more timing with lower comrpession is the "only" way to get better street power. I'd say that's true, but it's not THE truth. I'd say a higher level of truth is that each gas type has it's own compression and timing curve abilities and requirements. If you run a lower compression NA motor, you're in some ways wasting money by running high octane gas just to run a few more points of timing. Some people will also say "well I put race gas in and bumped the timing and got 15 extra HP!"... Well yea, but what power did you gain at the same as stock timing versus lower octane gas? The higher octane gas probably has more energy potential, so really you're just utilizing it better by matching your timing TO THAT FUEL. You might know all this already, I just want to make sure it's clear why I've said that FLAT TOPS are FINE on a turbo motor. If you want to run an OEM EFI setup, just get a L28ET longblock and be done with it. If you want to do a low buck turbo L motor use whatever you got, and run a good programmable EFI in order to tailor the fuel and timing to THAT SETUP. I've seen lots of blown up turbo L motors, and more often than not it's from a bad tune. It doesn't matter if it's flat top 7.4:1 or a 8.5:1. Run the TIMING REQUIRED for THAT fuel at THAT compression ratio and you won't have detonation issues. And in fact, running flat tops on the P79/90 will give you a ton more QUENCH thus you might be able to run similar timing maps anyways. But also remember that with a smaller combustion chamber with flat tops the distance for the flame front to travel is smaller, thus less timing is needed to optimize timing. Where people get messed up is they say "well I can run more timing on my dish setup, so it must be better". That's a very closed minded way to look at it. On a larger chamber more timing is REQUIRED, not allowed. It's just perspective, but it changes everything. Want a real mind bender? There's people running alcohol classes at the drag strip running non-intercooled roots superchargers on motors with 13:1 compression and higher! I bet they're not running extremely advanced timing, but I bet there's nobody out there telling them "you're loosing power by running such high compression"......
  17. Well you've come to the right place. Check out the L-specific threads in the FAQ section of the forum. People have done builds all from 300-700hp on L blocks on this very forum. Most are pretty well documented as well. Check out BRAAP's threads in which he goes through head work stuff, you can pick up on some of the key points to focus your headwork. And as far as the "been there done that", my advice stands. Find the "A" nissan cam. It's a great cam for turbo application and has shown to put down better numbers than some aftermarket "turbo" cams. Also, what's your goals with this build? 300whp? 350, 400, 450, 500? You'll find hundreds of builds like mine running mostly OEM longblocks, because it does fine getting you to 300hp, at which point the car becomes a handfiul.
  18. Possibly. Or maybe it was a dream I had in which you were cracking the displacement myth whips.
  19. Haha, it's kinda funny. I thought this was a new thread at first because the high-displacement extra stroke L motors came up recently in a thread here. I thought this was Tony's response, but instead it looks like tony's response to the same issue.... THREE YEARS ago... And some noobs wonder why people get mad...
  20. It's been fairly well covered here, but I'll add my 2 cents to the pile. The Compression of the flat top + P79 issue is WAY overblown. Both a dish+P90 and flat top+P79 have shown to be capable of well beyond 300whp under boost on pump gas. The liner topic is almost mythical. Though people on this very forum HAVE had issues with P79 liners melting up on them, they've been very isolated incidents while others (like howlermonkey) point out that it isn't always an issue. If you want to grind them out, feel free to do so. Shouldn't really help or hurt flow much in a turbo application (or NA really either) The key to getting ANY motor to run nice ARs without detonation is good management. The L motor is no different. I've seen SEVERAL people blow up flat top+P79 combos because they tried to use the stock L28E management, or tried to use stock L28E injectors, or tried to use stock L28E AFMs. It simply won't work well. If you want to try to use the L28ET EFI, then do it right and get every piece, including dizzy from 82-83. That being said, just go MS and be done with it. Install a trigger wheel and add some coil packs for MS to trigger. People have shown timing logs from MS and even the L28ET dizzy has very sporadic spark when compared to what you'll get from a good trigger wheel. And of course, I can't leave this post alone without advertising the best magic bullet to hit the car scene in the last 30 years (in my very honest but humble opinion). If you're willing to buy all new fuel lines, fuel injectors, and a large aftermarket pump, just go E85. That will eliminate ALL fear of detonation due to a "scary" 8.5:1 (a ridiculous fear in my opinion) and the cooler combustion temps will probably also help prevent any possible liner failure. It just means much larger injectors are required and you need rubber and lines that won't deteriorate. Small budget increase when you're already looking at MS3 + turbo, etc. As far as turbo fitment, I've see T4's fit with flange adapters. The stock turbo location is a little high and can stand to be lowered a little. Depending on what turbo you're wanting to run, and what kind of money you're looking at spending, you might just be better off getting a new manifold made. Not everyone's cup of tea, especially considering people make it past 300whp on the stock manifolds + turbos that bolt on without modification.
  21. Goals??? If you want 300hp there's several (some even on this board) that can build a head that will flow plenty well, and possibly every bit as well as that kameari head. I'm not saying kameari is not any good, I'm just saying there's LOTS of people still around that do work on L6 heads that know the tricks to getting great power out of them. And you'll probably spend less than half that...
  22. Which means pics for us tomorrow right?
  23. The question is, is mike going to go bigger next time, or more "getting old" like ZR8ED seems to be headed... (all in good fun if you're reading this ZR8ED). If you respond to this Mike, realize I don't care what the response is now. I'll be looking toward what you actually pick up and what the plans are when it comes. Go enjoy the bike ride, clear the head, and remember why life is worth living.
  24. If it was outrunning a VG30ET at 9lbs then I don't doubt the power claim. (we know they were both Z31's, and I'm assuming they were around the same weight) My personal opinion, is that if you can get the car for a song and a dance, go for it. Getting the same 250 hp out of the L motor will be more time, energy, and possibly money all for an engine that's longer and taller. It does sound better, and that really matters to some, but not everyone. I know you don't really need us to tell you if it's a good idea or not. It seems to me you're really just looking for someone to say it's ok for you to start another project, and I don't think you'll get many people arguing with you around here. All that said, doing the NA swap should be MUCH easier than the turbo swap you've done before. I'd say do it.
  25. Wonderful cars must run in the family.
