Everything posted by e_racer1999
that does look pretty immaculate, though
OTM - i dig your setup! can't wait to see the MN47 built up and yes, i know that the SUs are going to be my weak link. i'm going to get SM needles for them for the time being; although i'll still be choking a bit. eventually i'm going to go with 45-50 mikunis
i agree
i know i shouldn't partake in this thread, but i will simply tell you my combo - F54 block (with flattop pistons) N42 head schnieder stage IV cam/valvetrain (thanks john!) good ol' SUs MSA 6-1 header 2.5" exhaust to super turbo muffler expecting ~10.5:1 comp ratio
someone got hungry!
looks flippin nice!!!
which intake manifold has bigger runners?
e_racer1999 replied to z_boi's topic in 6 Cylinder Z Forums
was admiring that manifold yesterday..... NICE -
thanks for the update!
with that MVP bellhousing i'm assuming
header wrap w/ block huggers in JTR position
e_racer1999 replied to Forces's topic in Gen I & II Chevy V8 Tech Board
thanks for the info on the header wrap, guys. -
IMO, SU & EFI >>>>> DGV and from everyone's feedback who has purchased the ZT carbs, i feel comfortable in saying that it is worth it. as far as EFI vs SU, there will be 2 camps on that issue. i have SUs on my car, but i feel that EFI has the greater power potential because of the metering involved. but do yourself a favor and switch to some SUs
agreed; this thread is great!
ATTENTION all Carb'd Z owners!!! I'm Stumped... (a little long)
e_racer1999 replied to Yorgee's topic in Nissan L6 Forum
maybe too rich? that's what would cause it to bog. any smells from the exhaust? -
OMG!!! what king of wheels are these?
e_racer1999 replied to 240z_808's topic in Brakes, Wheels, Suspension and Chassis
watanabes they are what the rewinds were modeled after. that's austin's car. you can ask him what offset, etc.! -
hahah, they must drive the trucks over the water....
front brake pad issue 280zx
e_racer1999 replied to nbesheer's topic in Brakes, Wheels, Suspension and Chassis
probably. that hump is a locator. one of the shims should have a cut in it..... otherwise, you could probably cut the area of the shim that's preventing you from mounting it. -
is it just a myth that headers deteriorate faster with wrap because of the temps reached? -
My new toy - need tow vehicle reccomendations
e_racer1999 replied to trwebb26's topic in Non Tech Board
landcruiser, 4runner, frontier, pathfinder haha, they all end in "er" -
77/78 had vents (i believe) have you been to motorsportauto.com yet? they have mad tyte JDM fairlady stuff. are you going to go g-nose?
those words should never be used in the same sentence
i agree raw it looks better, but he used body filler, so raw wasn't an option for it to look "complete"
my friend has a miata and he's 6'1". no issues
NOT MINE, but thought i'd pass it on! http://sandiego.craigslist.org/car/332089543.html 1970 240Z Roadster @ 3.1 litres - very rare - $8000 -------------------------------------------------------------------------------- Reply to: sale-332089543@craigslist.org Date: 2007-05-16, 9:41AM PDT After 15 years of ownership and effort, it is time to pass this little rocket along to someone else. This car is very fast, very fun, and truly unique. It has been heavily modified from nose to tail, including a 3.1 litre motor, 5-spd transmission, LSD, 4-wheel disc brakes, Tokico adjustable suspension, etc. The full details are as follows: BODY: 1970 240Z (HLS30 12759) Hand-laid Kevlar/fiberglass roadster cap, designed and installed by Sam Freeman of Hollywood Motors. Frame reinforcements throughout, using rectangular steel section, designed for 400+hp V8 applications and installed by Sam Freeman of Hollywood Motors. Cleaner lines from removal of side marker lamps and replacing with welded plates of original Datsun steel. ENGINE: 3.1 Litre “Strokerâ€, balanced and blueprinted @ 9.6:1 c/r Block – 1977 280Z 2.8L, bored .2 over to 8.8cm, deck shaved by .75mm. Crankshaft – LD28 (diesel). Provides 4mm of additional stroke. Rods – L24 with 9mm bolts. Pistons – LZ22E+1 with factory dishing. Head – N42 with chambers and ports individually hand shaped, matched, and polished to maximize volumetric efficiency. Intake valve seats ground at 5 angles, exhaust seats are fully radiused. Grinding and final assembly by Rebello Racing. Head Gasket – 1mm thick, 3-layer, all copper. Camshaft – Schneider Stage III with .460†lift, 270 intake duration, and 280 exhaust duration. Provides a reasonable idle and pulls hard from 3000 - 6500 rpm. Valves – Nissan/Datsun Competition stainless-steel at L28 diameter, factory modified and swirled for volumetric efficiency. Rockers – factory L28 rockers lightened and balanced to minimize dynamic differences along the entire operating valvetrain, for smoother, higher revs. Oil Pump – high capacity 280ZX Turbo pump with high-pressure springs. Fuel System – stainless steel braid, tubing, and swage fittings from tank to carbs through a Holley adjustable regulator. INTAKE/EXHAUST: Triple Weber 45mm carburetors with 38mm chokes on a Cannon six-throat manifold. 6-into-1exhaust, back to a Turbo muffler using a 3†pipe. ELECTRICAL: Battery – Optima maintenance-free gel battery Alternator/Regulator – 70A 280ZX internally regulated alternator Fuse Box – replaced with higher capacity, modern spade-type unit mounted to firewall in passenger footwell. Distributor – Mallory Unilite with fully adjustable mechanical advance. Spring and shim kit included. Coil – MSD Blaster Coil. Discharge – MSD 6AL with adjustable rev limiter (currently set at 7,000). Wires – MSD 8.5mm plug wires. Alarm – Alpine dual-zone radar. SUSPENSION: Struts – Tokico Illumina 5-way adjustable. Springs – Tokico springs, matched to struts. Bushings – Polyurethane throughout, except aluminum/Delrin at front t/c rods. Swaybars – 1†front and 7/8†rear. BRAKES: Four Wheel Disc – Toyota 4x4 four-piston calipers on stock 240Z discs in front, Datsun 280ZX calipers on 280ZX calipers in rear. Master Cylinder – larger diameter 280ZX, with in-line proportioning valve. DRIVETRAIN: Flywheel – lightened (to 13 lbs) Transmission – 1976 280Z close-ratio 5-speed Shifter – MSA short throw Final Drive – R160 Limited Slip Differential with a 3.7 ring/pinion (note that a 3.9 and 4.11 setup are also available) U-Joints – Spicer Heavy-Duty WHEELS/TIRES: 15x7 Centerline aluminum wheels 215/60/15 Yokohama AVSI tires COOLING: Radiator – Datsun high-capacity 4-row Fans – 2x10†puller fans on thermal sensors with manual override via heavy duty relays with individual fuses and indicators to show that fans are operating. Disclaimer THIS VEHICLE IS BEING SOLD AS IS, WITH NO WARRANTY, EXPRESSED WRITTEN OR IMPLIED. Buyer is responsible for vehicle pickup and/or shipping FOB my home in Del Mar, CA. The seller shall not be responsible for the correct description, authenticity, genuineness, or defects herein, and makes no warranty in connection therewith. No allowance or set aside will be made on account of any incorrectness, imperfection, defect or damage. Any descriptions or representations are for identification purposes only and are not to be construed as a warranty of any type. It is the responsibility of the buyer to thoroughly inspect the vehicle, and to satisfy himself/herself as to the condition and value and to purchase based solely upon that judgment. Seller assumes no responsibility for any repairs regardless of any statements, written or oral, made about the vehicle. That said, I am happy to answer any questions you may have, and will do so to the best of my knowledge.
looks sold
