NOT MINE, but thought i'd pass it on!
http://sandiego.craigslist.org/car/332089543.html
1970 240Z Roadster @ 3.1 litres - very rare - $8000
Reply to: sale-332089543@craigslist.org
Date: 2007-05-16, 9:41AM PDT
After 15 years of ownership and effort, it is time to pass this little rocket along to someone else. This car is very fast, very fun, and truly unique. It has been heavily modified from nose to tail, including a 3.1 litre motor, 5-spd transmission, LSD, 4-wheel disc brakes, Tokico adjustable suspension, etc. The full details are as follows:
BODY: 1970 240Z (HLS30 12759)
Hand-laid Kevlar/fiberglass roadster cap, designed and installed by Sam Freeman of Hollywood Motors.
Frame reinforcements throughout, using rectangular steel section, designed for 400+hp V8 applications and installed by Sam Freeman of Hollywood Motors.
Cleaner lines from removal of side marker lamps and replacing with welded plates of original Datsun steel.
ENGINE: 3.1 Litre “Strokerâ€, balanced and blueprinted @ 9.6:1 c/r
Block – 1977 280Z 2.8L, bored .2 over to 8.8cm, deck shaved by .75mm.
Crankshaft – LD28 (diesel). Provides 4mm of additional stroke.
Rods – L24 with 9mm bolts.
Pistons – LZ22E+1 with factory dishing.
Head – N42 with chambers and ports individually hand shaped, matched, and polished to maximize volumetric efficiency. Intake valve seats ground at 5 angles, exhaust seats are fully radiused. Grinding and final assembly by Rebello Racing.
Head Gasket – 1mm thick, 3-layer, all copper.
Camshaft – Schneider Stage III with .460†lift, 270 intake duration, and 280 exhaust duration. Provides a reasonable idle and pulls hard from 3000 - 6500 rpm.
Valves – Nissan/Datsun Competition stainless-steel at L28 diameter, factory modified and swirled for volumetric efficiency.
Rockers – factory L28 rockers lightened and balanced to minimize dynamic differences along the entire operating valvetrain, for smoother, higher revs.
Oil Pump – high capacity 280ZX Turbo pump with high-pressure springs.
Fuel System – stainless steel braid, tubing, and swage fittings from tank to carbs through a Holley adjustable regulator.
INTAKE/EXHAUST:
Triple Weber 45mm carburetors with 38mm chokes on a Cannon six-throat manifold.
6-into-1exhaust, back to a Turbo muffler using a 3†pipe.
ELECTRICAL:
Battery – Optima maintenance-free gel battery
Alternator/Regulator – 70A 280ZX internally regulated alternator
Fuse Box – replaced with higher capacity, modern spade-type unit mounted to firewall in passenger footwell.
Distributor – Mallory Unilite with fully adjustable mechanical advance. Spring and shim kit included.
Coil – MSD Blaster Coil.
Discharge – MSD 6AL with adjustable rev limiter (currently set at 7,000).
Wires – MSD 8.5mm plug wires.
Alarm – Alpine dual-zone radar.
SUSPENSION:
Struts – Tokico Illumina 5-way adjustable.
Springs – Tokico springs, matched to struts.
Bushings – Polyurethane throughout, except aluminum/Delrin at front t/c rods.
Swaybars – 1†front and 7/8†rear.
BRAKES:
Four Wheel Disc – Toyota 4x4 four-piston calipers on stock 240Z discs in front, Datsun 280ZX calipers on 280ZX calipers in rear.
Master Cylinder – larger diameter 280ZX, with in-line proportioning valve.
DRIVETRAIN:
Flywheel – lightened (to 13 lbs)
Transmission – 1976 280Z close-ratio 5-speed
Shifter – MSA short throw
Final Drive – R160 Limited Slip Differential with a 3.7 ring/pinion (note that a 3.9 and 4.11 setup are also available)
U-Joints – Spicer Heavy-Duty
WHEELS/TIRES:
15x7 Centerline aluminum wheels
215/60/15 Yokohama AVSI tires
COOLING:
Radiator – Datsun high-capacity 4-row
Fans – 2x10†puller fans on thermal sensors with manual override via heavy duty relays with individual fuses and indicators to show that fans are operating.
Disclaimer
THIS VEHICLE IS BEING SOLD AS IS, WITH NO WARRANTY, EXPRESSED WRITTEN OR IMPLIED. Buyer is responsible for vehicle pickup and/or shipping FOB my home in Del Mar, CA. The seller shall not be responsible for the correct description, authenticity, genuineness, or defects herein, and makes no warranty in connection therewith. No allowance or set aside will be made on account of any incorrectness, imperfection, defect or damage. Any descriptions or representations are for identification purposes only and are not to be construed as a warranty of any type. It is the responsibility of the buyer to thoroughly inspect the vehicle, and to satisfy himself/herself as to the condition and value and to purchase based solely upon that judgment. Seller assumes no responsibility for any repairs regardless of any statements, written or oral, made about the vehicle. That said, I am happy to answer any questions you may have, and will do so to the best of my knowledge.
