7
Everything posted by dr_hunt
From your pic's every piston has intake valve marks on them. IMO you didn't have enought p/v clearance and the springs are a question like braap said. It could be just the springs. 90% of all engine failures are valve train related.
This year I put 8 miles on the z. Since it probably won't get out of paint prison this year, that's probably it.
If you do the same with quarter mile times, you still get a better number than a dyno number. The quarter mile is real, force times distance, the dyno doesn't compare in any way to 1/4 mile times IMO. Chassis dyno is good for tuning the car or seeing what effect changes have made on THAT car on the SAME dyno with the SAME settings IMO. If it had any real world translation to 1/4 mile times we wouldn't see 1000+HP dyno turbo mustangs doing 10.80's and 11.30's in the 1/4 like you see on racingsouthwest. Chassis dyno means very little in the real world of drag racing. I'm not for a dyno database and don't support it. If you want to run your car, get a timeslip, post it, great. If you can't back it up cause it's not your timeslip, then be embarrassed at the track, that's your decision.
Gear drive VS chain cam drives
dr_hunt replied to grumpyvette's topic in Gen I & II Chevy V8 Tech Board
Gear drive, the only way to fly! -
Quieting that engine bearing sound..snake oil til' engine blows!
dr_hunt replied to a topic in Miscellaneous Tech
You should just start it in the morning when it's cold, put a brick on the gas and stand back. The noise will become self evident soon enough. Then go buy yourself a new BBC engine from grumpy, after all it's only money. -
Ok! I Confess, Ive Gone Brain Dead At Times...
dr_hunt replied to grumpyvette's topic in Non Tech Board
Well, I went to napa to get a changeover ujoint. 1350 to a 1310 for my mudbog truck cause I heard that they had them in stock. The factory sales rep was there too doing a sales call. The owner, Frank, did some measurements, pulled out a slide chart, hummed, ho'd and ha'd and said they didn't make what I needed according to his chart. Ok, so the sales rep looks at it and says to frank, "I think we make it, but you need the new book we have, I don't have one but I'll send you one". Ok, so off I go to albuquerque to U-joints Inc, which is 75 miles one way. Take my driveline and yoke and tell him what I'm trying to do. He says, you want the change over u-joint or a new driveline yoke, same price $38 and then you can use a standard ujoint. Bingo, bought the yokes and new u-joints for the front and the back, to change to a 1350 in the back and a 1310 in the front, so now even autozone and napa can't screw it up. Then he tells me that the ujoints are just in different series with either inner or outer clips, simple, and they make change over u-joints in many applications and gives me a card to call them. I can order over the phone, and they'll ship it to me ups. -
Pics of the Kelly Ranch and the new MMMMMMMMMMM!
dr_hunt replied to Mikelly's topic in Non Tech Board
Really nice mike! -
DD says my combo at 24psi boost is good for 1100HP. I'll settle for that for now. Should put the monte into the 9's at 3780lb race weight. Yes, I lost weight.
You know your legally insane right?!! I'd check into life insurance myself if I were you. Actually, can I get life insurance on you? If I could I would. Just kidding. 6's, 5's, you trying out for the next nasa space mission? Those heads are simply works of art aren't they? Almost put your fist in the intake ports, huh?!!! I was just messing with you, my normal mode of happy go lucky and see who I can get a rise out of. Personally I don't care who or what is in the timeslip database, simply because that's what the title is. It doesn't say z only timeslip database and there are as of yet no restrictions on entries. SuperDan is the man you want to direct those comments to. Nobody is really sure whether he exists or not. Rumor has it he's an alien that loves beer. But that's just a rumor.
Looks pretty impressive, wish zgad would get his going.
what blocks? Did I miss something? DAMN, that's some nice stuff, I want. Oh and brian.......... You suck
Me too! I can't imagine what would have happened if they'd of got the fire started. That is still bothering me, cause I could be dead now if I had of driven up at the wrong time.
Bring it Terry, let's make a badass car! You drive it though!
Yeah, the mud has alot to do with it. That pit only 5 trucks made it through, so that pit wasn't easy. Tomorrow there is another one. I bought boggers now and I've cut the back and cupped them like a paddle tire, we'll see how that works. I might cut the fronts too. The boggers are 18 inches wide, those in the vid are 15 inches wide. If that doesn't work, it's either 540" BBC or bore and stroke the 350. Actually, I'd like to sell the 357" motor, 5K takes it.
No!
He didn't tell you but it's in japanese.
Larry had another one I think where I was doing an exibition run backwards through the pit.
I guess this is why good tuners are never out of work. IMO, you add timing with elevation. So I'd go with the sea level case.
Well, that and a light car. 6100 launch, damn, I'm about to shift right then, cause my cam peters out at 6500. Guess I need bigger cam and more rpm. Here you go, ruining my lunch, now I have to spend paypal money that was earning interest. See how you are!
That'll never happen! Cause who would want them to get out of the way! :lmao::lmao::lmao::lmao:
Your wrong there, roundy round is where I started, drag was cheaper, otherwise there is an asphalt road course and oval track in Alb. as well, and I'd be doing that instead. Function of time and money. Time I don't have and money, well, easy come, easy go. Drag lasts 10 seconds or less, circle track or road lasts alot longer. It is harder on engines, parts, tires and costs more to maintain than what I do IMO.
I don't see your point about who's driving it and arguments over buld and such. What makes one hybridz with x powerplant, x trans, x rear end better than the next? When I went to SEZ, I could have spent days looking at all the cars. What makes it great isn't the powerplants, the drive train, etc. it's the workmanship and how it all works together. Anybody who has ever driven a 9 second car or faster knows it's a handfull, just ask jap tin (sbc), JNJ (blown sbc, stock r200), z gad (2jz street car), scottie (GN engine), or hanns (turbo sbc). And they have different combinations! Or even stony when he gets his going. I've taken friends riding in the z at the track down the return road warming up the car or on the street in front of my house, and got on it using the t-brake. Everyone that's ever ridden in it got out and wanted no more! I took a little kid for a ride in Alb and he pissed his pants. It's really that scary when you can't see the road cause the front wheels are 1 foot off the ground! It's not for the faint of heart and only qualified individuals would even have the opportunity to have seat time. The people that are driving these cars didn't just jump in a 8 or 9 second ride and say yeehaw! Besides this wouldn't be a car that you dog whip the crap out of! It's a car, it's replaceable, it's not "your baby" like your z or whatever you have, you don't love it, it's made to run, to drive and to look at. The quality of workmanship I've seen on this forum is amazing. I"ve built circle track cars from the frame up, and anybody that I've ever been around was just happy to have had a hand in whatever. I think the same thing is evident in the pinks build, as there were alot of great pieces that made up that puzzle, just morons doing the build in a self centered way, so your right about looking at the pinks threads, it shows, but that's not everyone on this forum either. The intent for a house car is for hybridz to have a car not individuals of the build team, which is what pinks was. The question is whether hybridz.org wants to back, have members build, and control a car. It may or may not happen, but if it were it would be under the direct supervision and control by admins, and a technical comittee of admin and well respected members. Alot of circle track chassis companies have "house cars". They invite qualified drivers to drive their cars in big races to showcase thier car which is the best of the best they have to offer. Drivers are often carefull with the car and well qualified to boot. In Manzanita I saw and met Kenny Wallace driving an IMCA modified house car for dirtworks, it happens all the time all over the country, on dirt, asphalt and drag strips. Alot of the people that drive big time cars are just that drivers, so this isn't a new concept.
