tim.d
Everything posted by tim.d
  1. Hey Y'all, Right as COVID hit, career, kids, shutdown, and just about everything else took over and I essentially stopped all work on my car, forums, and deleted social media. Six years later, life has calmed down and I find myself with time, motivation, money, and a little bit of energy to work on the car again. The parts hoarding is done, now I just need to work on it. But the state of internet forums/groups has me completely baffled. 1) I have a ton of OEM and aftermarket parts to sell, and aside from Craigslist and FB Marketplace..how do you do that? Like, how would someone on the other side of the country know I have a bunch of parts to sell for cheap that I'll ship? I can't create a parts FS thread here, and we all know that unfortunately forums just don't get the visits they used to. 2) how do I engage in non-facebook Z chats/community? IS there one?? 3) Generally wtf has happened and how do y'all manage it being a Z / auto enthusiast in the current landscape?
  2. Way super mega late to this thread... but still open for new orders?
  3. The front of the differential IS bushed; they're OE pressed into the carrier housing. See attached image. I've asked AE a lot of questions and haven't bought jack from them, and they've been outstanding answering all of my questions, including dimensions and materials as I attempt to copy their stuff. I've heard nothing but positive things from those I know who have purchased from them. Maybe they're not the problem.
  4. Hola, I measured off centerline and cut out upper core support at ~45*, then drilled and bolted two plates together tight, trimmed the upper support until upper edge was flush as it would have been before, and welded it together. It's plenty stiff!!
  5. I don't think a single thing about this build is considering real life use/wear/maintenance. I think someone told me that he's talking about bagging it now so it'll lay frame?!? I mean I miss the minitruckin days too, but comeon.
  6. No, if you didn't want to cut the strut tower you would have to drop the whole strut assembly to adjust camber.
  7. I thought about doing the same to mine..until I dug deeper. Ended up doing waaayyy more than just the outter rocker panel. See photos: https://imgur.com/a/SkwkJ
  8. Mark, Thank you very much for posting that information here on HBZ; DPAN is a mess.
  9. I have the DR's purchased, but car isn't ready for them yet. When researching, digressive shocks are definitely the way to go for a more performance oriented car. I was hoping to find a few different shock dynos of the BCs, but only found a couple... likely because at the BC pricepoint, most people aren't going to have them run through a shockdyno. BUT - they seem to use standard bilstein sized pistons and valves so really fine tuning their setup is possible and rebuilding shouldn't be a big deal. I would have preferred the shocks to be inverted like the Stance or Simtec, but a lack of information about the internals made me lean towards the BC. TLDR; I thought the BC DR's were the best way into a digressive coilover setup that was a solid base with room for improvement down the road.
  10. It's painful to watch. I had to unsubscribe, I was about ready to leave a youtube comment.
  11. Well wifey and kiddo are at Grandma's tonight so I guess I'll update this thread while drinking some beer. Got the front half of the rocker welded in. The rear half is welded in where it can be, but I've got a bunch of metal to replace back there.... Had some issues getting the rocker panel to line up with the rear quarter door seam. In the end, i'm putting it down to 40 year old cheap japanese cars weren't built with a lot of precision and to allow for some variances. After getting it welded in and flanges hammered down it fits better but not what i'd call 100%. But in the end, it welded up ok. also took care of some stitch welding while I was in the area And then getting the inner wheel well ready for it's patch. I'm guessing it's probably best to make this panel once I've got the new dogleg in. Parts are primed on all faces before being enclosed, and then I'll be doing over everything with Eastwood's internal frame coating to seal it up. Oh, and sent in my speedhut gauges to go from 4.5 to 4" so I can fit the trim rings. While those were getting snail mailed to Utah, the 2 5/8s came in. Thanks to Steve (ihiryu) here on the forums for being an awesome dealer with many hookups. Saved me a couple hundred bucks on my BCs and about 150 between all these gauges.
  12. The mechanical side of his builds have consistently been... questionable. Hoping since he cares about this car that'll be different. Would love to hear that thing howl!
  13. Very curious about what the smart people here think about this design. I'm planning on going down a similar path, also with the main hoop also protruding into the wheel wells slightly. I've got full length box frame rails that the hoop would brace down into as well.
  14. When really honing in on your skill, electrodes do make a difference. The video below does an excellent job of comparing the various 'colors' that are out there. But no electrode will make up for beginner or sloppy technique.
  15. technique is way more important than electrode choice in tig welding. Establish your puddle, then start moving the torch. keep arc TIGHT. Feed in filler at appropriate increments, and don't stop the torch for too long otherwise you'll put too much heat into the part. A million billion times more tricky than it sounds.
  16. You're posts and knowledge is pretty much gospel, so I'll soak up everything I can from you. I have a similar method planned; though I'm not sure how to effectively put a tube inside the rocker with everything else thats in there, or how to tie it in. So many angles, feels beyond my ability. I've already got the passenger side reinforced for the front brace you were talking about, https://imgur.com/DPdo6lp. I will also be running a small tube or some 1x2 from the TC bucket to the rocker. Do you think using 16ga is thick enough for a "doubler" on the stock rocker? My seat rails tie in from the full length frame rails into the rockers as well, and the transmission crossmember will brace between the two sides. Then the normal other triangulations in the cabin and engine bay. For sure. Not doing this BS again. And we'd get an awesome road trip out of it! So far, the only wood screws I found were holding in a bunch of shotty grounds in the engine bay. I'll be rewiring everything from scratch (something I'm actually proficient at), so there's some enjoyable work to come later on. I did have an old supra that had "custom wiring" terminated in the manner you described... never did get the gremlins fully sorted from that car. The shit people pull....
  17. Don't really have much of a choice, I've committed to this body. Hopefully in the end it's not terrible! It appears to be window screen and bathtub caulking. .
  18. So the last few weekends I've started tackling the driver's side rocker replacement. After drilling out many, many spot welds I found that the "tie in panels" (which I didn't even know where there) were rotted out as well. Picked up a set from Prospect-D to save myself some fabrication time, and have been working on removing the rotten metal , treating, and replacing. I also found that the lower portion of the rear inner fender was completed rotted out; so that's another panel I'll have to make from scratch, but I'll get to that after the rockers are back in. Looks like the PO was well aware of the rot in this area... as he came up with a rather "Home Depot" approach to repair. What metal was left was brushed down the best I could with wire wheels, and then ospho'd twice, followed by rust converter for anything else I missed, then weld thru and normal primer. three days of curing just to get through the primer stages! ugh, le lame. Album: https://imgur.com/a/SkwkJ
  19. I think it's the universe's will that this goes to Neverdone.
  20. Below the blue header (at the top of the page) there are words. One of them is "Donations." Click on that. Then click on the green button "Donate Now." It's on the right half of the page, just off center.
