ZT-R
    4
Everything posted by ZT-R
  1. No this is a 800hp build.
  2. I'll let ya know what I decide to do, but mine would be coming from NZ not AU.
  3. Mains look ok. Check the mains for runout. Only other damage i found was a scar in the oil pump, but thats to be expected.
  4. 1700 -2000 miles I have to gustimate cause my speedo wasnt working for a little bit. But def not more than 2000.
  5. I wouldnt think it would get any better the a R.I.P.S. build. Everything is out now, so its no longer a rips Anyone can assemble them, but not to his specs and attention to detail, Although I think i will debur the inside of this block, its ugly and quiet scary looking. The number one piston is out of round by 8 thousandths. and the crank is egged. So for sure needs a new crank and rod. Anyway, more disassembly pics.
  6. 2Jz is the same BS as this, over priced stuff.
  7. Where RB's come to die...
  8. Ahhh, the 240z has the big spare wheel well.
  9. i would probably do something different than a LS.
  10. Hmm measuring crank rod journal... I/m getting 49.657mm.... Why the hell would this have +.25mm bearings when standard calls for min of 49.961mm and max size of 49.974mm. hmmmm.
  11. I'm not real familiar with the rb25 but does that have an ignitor? that was a common problem on the rb26s. I put aem externail coils to get them out of the heat and ditched the ignitor.
  12. got off at the next exit about a mile and shut it down. "The crank will already be at 0.25mm, it was ground to suit each individual pair of bearings (so no set sizes as such) and with the heat/damage it has I wouldn’t recommend trying to go to 0.5mm and I doubt it would clean up anyway. Rob"
  13. Hmmmmm. I am measuring 1.9590-1.9630 on this number one rod journal. and supposedly it has +.25 bearings. Min STD is 1.9670 Max STD is 1.9675.
  14. The 26 doesnt have enough torque.
  15. No, no way to find out either. Steady state cursing with no loss in oil pressure. Fucked if I know. Im done with it though.
  16. Have you bolted it up yet? How does it fit? 240z, 260z or 280z?
  17. Crank is shot, number 1 rod shot. Looking like V8 time. Same price for a fix as the original. Im not doing that again. This one didn't even make it 2000 miles. Joel please fix my title, i dont want anything to do with this.
  18. Number one rod gone big time. Crank shot, hope bore is ok.
