ZT-R Posted May 10, 2011 Share Posted May 10, 2011 I would like to see some more pics of s30s running the mufflers at like a 45 degree angle. i think i have seen maybe 2 pics on google. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted May 11, 2011 Share Posted May 11, 2011 (edited) Edited May 11, 2011 by BLOZ UP Quote Link to comment Share on other sites More sharing options...
ZT-R Posted May 11, 2011 Author Share Posted May 11, 2011 (edited) ahahahha, thats not what i had in mind. hahaha also at least i know i dont like the volk GTZ on 240z Edited May 11, 2011 by ZT-R Quote Link to comment Share on other sites More sharing options...
280z"Vador" Posted June 13, 2011 Share Posted June 13, 2011 (edited) Edited June 13, 2011 by 280z"Vador" Quote Link to comment Share on other sites More sharing options...
Cannonball89 Posted June 17, 2011 Share Posted June 17, 2011 Is this the kind of muffler arrangement you are looking for? Quote Link to comment Share on other sites More sharing options...
motoman Posted July 9, 2011 Share Posted July 9, 2011 Heres a video of big phils car. His exhaust has a slant to it. Skip to 0:45 to see it. http://www.youtube.com/user/turbo280z#p/u/174/ZMLm9ZU-yko Quote Link to comment Share on other sites More sharing options...
ZT-R Posted July 20, 2011 Author Share Posted July 20, 2011 finished mine. Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted July 20, 2011 Share Posted July 20, 2011 I recently redid the rear portion of my exhaust to have the mufflers (Borla Pro XS) follow the line of the body. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted July 20, 2011 Share Posted July 20, 2011 Hey Dan, is that a petcock hanging down about 1.5" off the ground in the 1st and last shots? Car looks friggin amazing. I think I'd be worried about knocking that thing off though... Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted July 20, 2011 Share Posted July 20, 2011 Jon, That is the petcock on my radiator catch can. It does hang down a bit, but it has never hit anything. I probably should raise it a bit, but I may never get around to it until I break it off Quote Link to comment Share on other sites More sharing options...
19762802+2 Posted July 21, 2011 Share Posted July 21, 2011 Are those Diamond racing wheels? Those look awesome. Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted July 21, 2011 Share Posted July 21, 2011 (edited) They are Spin Werkes series 82 wheels. They are very similar to the Diamond wheels, but they are constructed of aluminum. My wheels are 15x10 and weigh 14.9 lbs each. I highly recommend Spin Werkes. The wheels are lightweight, and you can specify the width, backspace, bolt pattern, and center bore diameter. My wheels cost approximately $250 each. These are probably the most affordable custom aluminum wheels available. Here is a link to the company's Facebook page: http://www.facebook.com/pages/Spin-Werkes-Aluminum-Racing-Wheels/100456613370000 Edited July 21, 2011 by 74_5.0L_Z Quote Link to comment Share on other sites More sharing options...
Fuzzydicerule Posted December 11, 2011 Share Posted December 11, 2011 Not really applicable to the title because there is no muffler in the tail section, but here you go Basically, this exhaust is setup as straight as i could get it. Its got 2 <45* bends off the turbo, obtuse enough bends that it comes within 1/8th of an inch of both the bell housing and the firewall. At the bottom of that down pipe is a 3 inch flex section, followed by a ~5-10* bend to contour it to the trans tunnel, into a Moroso Spiral flow muffler, Followed by 2 more 10* bends to snake around the diff support and diff as tucked as possible and exit under the differential straight, and then a 60* bend straight out the back I built this exhaust out of 6 components 1: a peice of plate that i plasma cut into the proper shape, Had it laying around 2: an O/R 2 1/4 inch DP off a mitsubishi starion, aquired for free, used only for a small straight section that is the first 2 inches out of the turbo, immediately expands to 3" 3: 2 4ft 3" Lengths of tubing, about 50 bucks or so 4: 1 UJ 180&60* Stainless Mandrel bend. roughly 50 bucks 5: Moroso Spiral flow. 30 dollars i believe 6: Flex pipe, iIRC was only about 50 This Setup would not be attainable on a stock car for obvious reasons. 1 Being the valence, as you may notice, mine has been cut. 2 The fuel Cell, i have it raised a bit into the cabin, and i doubt this kind of setup would clear the stock tank. but for a modified car for less than 200 bucks it works pretty damn well its not everyones cup of tea, i know, hell i never really liked it before, but i quite literally used every last bit of tubing i had, and i couldnt really afford to buy more at the time, and i like the way it came out... Quote Link to comment Share on other sites More sharing options...
Nelsonian Posted December 11, 2011 Share Posted December 11, 2011 These are pics from Blakt out's increadible 240z showing his exhaust setup. Nice bends all the way throughout. Quote Link to comment Share on other sites More sharing options...
Six_Shooter Posted January 28, 2012 Share Posted January 28, 2012 Here is a pic of mine from a few years ago, I have since cut the "tip" shorter. Moroso Spiroflow, full 3" exhaust. Quote Link to comment Share on other sites More sharing options...
Fuzzydicerule Posted January 30, 2012 Share Posted January 30, 2012 do you have a sound clip? thats my exact setup (except my muffler is under the car) and im curious as to what it sounds like Quote Link to comment Share on other sites More sharing options...
Six_Shooter Posted January 30, 2012 Share Posted January 30, 2012 I have two clips, one was just before I started pulling the carbs off for the turbo/EFI upgrade, and one is after the Turbo/EFI and DIS was added. They sound(ed) better in person. N/A, carburetted: After turbo, EFI and DIS: Quote Link to comment Share on other sites More sharing options...
LoneStarS30Z Posted January 30, 2012 Share Posted January 30, 2012 Thanks Six_Shooter for the sounds clip, I'm contemplating re-doing my exhaust and I would love to hear more people's set ups and what mufflers and resonators everyone is using. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted January 30, 2012 Share Posted January 30, 2012 Not a hole lot of angle. Quote Link to comment Share on other sites More sharing options...
bradyzq Posted February 3, 2012 Share Posted February 3, 2012 Not the best shot to show the exhaust, but here it is anyways.... Quote Link to comment Share on other sites More sharing options...
