speeder Posted October 25, 2011 Share Posted October 25, 2011 So when can we expect these, Matt? I would like to have one now! Quote Link to comment Share on other sites More sharing options...
jpconrad Posted October 25, 2011 Share Posted October 25, 2011 Sounds great! I'm interested as well! Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted October 25, 2011 Author Share Posted October 25, 2011 On 10/25/2011 at 6:44 AM, speeder said: So when can we expect these, Matt? I would like to have one now! Good news, the boss has given it the green light. I'll see if I can get the design off to the laser shop by the end of the week. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted October 25, 2011 Share Posted October 25, 2011 Any details? I'm guessing it will be VG compatible by default, but just checking. Quote Link to comment Share on other sites More sharing options...
ModernS30 Posted October 25, 2011 Share Posted October 25, 2011 Let me get this straight. This means, you can run coil packs using this in your distributor? Quote Link to comment Share on other sites More sharing options...
letitsnow Posted October 25, 2011 Share Posted October 25, 2011 Yep, dizzy stays, no plug wires, but you can control seq injection or COP using the signal. Quote Link to comment Share on other sites More sharing options...
FlatBlack Posted October 25, 2011 Share Posted October 25, 2011 Sign me up. Very reasonable price! Will you have trigger settings for this wheel for MS1E? Quote Link to comment Share on other sites More sharing options...
LineC Posted October 25, 2011 Share Posted October 25, 2011 (edited) I think I pooped myself. I can keep all three of my pulley wheels without some crazy trigger wheel design and have coil packs. Edited October 25, 2011 by LineC Quote Link to comment Share on other sites More sharing options...
speeder Posted October 26, 2011 Share Posted October 26, 2011 On 10/25/2011 at 3:43 PM, BLOZ UP said: I'm guessing it will be VG compatible by default correct - It will fit in the VG30E and VG30ET distributors. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted October 26, 2011 Author Share Posted October 26, 2011 On 10/26/2011 at 4:11 AM, speeder said: correct - It will fit in the VG30E and VG30ET distributors. Right. But not the VG30DE - those use the smaller 50 mm wheel. I'll see if I can have the settings these wheels need up soon as well. Quote Link to comment Share on other sites More sharing options...
Chemicalblue Posted October 26, 2011 Share Posted October 26, 2011 Now I think I get it, its MS that is the problem using stock trigger wheels. Ive been running COP and Sequential for many years now on the stock Z31 wheel. I was trying to figure out why you would want to make a low resolution wheel to replace the the high resolution stock wheel. So MS cant read the stock Nissan trigger wheel? Seems it would be much easier to change the software than reinvent the wheel. Quote Link to comment Share on other sites More sharing options...
letitsnow Posted October 26, 2011 Share Posted October 26, 2011 There was code to figure out the longer slot based on the high res slots, but the author and the MS people had disagreements and the author packed up his proverbial goodies and left. The way MS would decode the high/low res portions, it would determine which was the cyl 1 slot, then 'remember' it, it would not decode the high res wheel on the fly. The low res portion is 6 slots, using some math(rpm, time, etc) it predicts the time the next cylinder should be coming to TDC. This can be thrown off with high rpm acceleration rates. If you increase the number of slots, you decrease the time between slots, decreasing the amount of acceleration that can take place between each slot, increasing the overall accuracy. In short, short of the angle clock for MS3 being completed(or is it already done?), a 36-1 pattern is MORE accurate than a z31 wheel that is decoded by the code that's no longer available. MS1 and 2 do NOT have enough computing power to decode the high res wheel on the fly. Quote Link to comment Share on other sites More sharing options...
dga280z Posted October 26, 2011 Share Posted October 26, 2011 Please sign me up. Where should I send my $$ and address? Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted October 26, 2011 Share Posted October 26, 2011 On 10/26/2011 at 7:24 PM, dga280z said: Please sign me up. Where should I send my $$ and address? I imagine it will be offered from Matt Cramer's site, DIYAUTOTUNE. Quote Link to comment Share on other sites More sharing options...
dga280z Posted October 26, 2011 Share Posted October 26, 2011 On 10/26/2011 at 7:26 PM, SleeperZ said: I imagine it will be offered from Matt Cramer's site, DIYAUTOTUNE. Thanks! Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted October 26, 2011 Author Share Posted October 26, 2011 On 10/26/2011 at 2:08 PM, Chemicalblue said: Now I think I get it, its MS that is the problem using stock trigger wheels. Ive been running COP and Sequential for many years now on the stock Z31 wheel. I was trying to figure out why you would want to make a low resolution wheel to replace the the high resolution stock wheel. So MS cant read the stock Nissan trigger wheel? Seems it would be much easier to change the software than reinvent the wheel. That capability is in the works for MS3, still need a bit of testing before it's ready for prime time (it won't need a full angle clock, though). I believe there's currently a running GM Optispark example (same pattern as the VH45) but no other modes are yet on a live engine. Basically, Nissan used dedicated hardware to count the high resolution slots. MS3 has enough power to brute force this and use it without a special tooth counter, MS2 and MS1 don't. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted October 26, 2011 Share Posted October 26, 2011 On 10/26/2011 at 1:38 PM, Matt Cramer said: Right. But not the VG30DE - those use the smaller 50 mm wheel. I'll see if I can have the settings these wheels need up soon as well. When I said VG, I meant VG30E. Quote Link to comment Share on other sites More sharing options...
Git-y-up Posted October 31, 2011 Share Posted October 31, 2011 Count me in aswell, about to do MS on my 280z and would love to run a triger ignition system Quote Link to comment Share on other sites More sharing options...
s30red240z Posted November 3, 2011 Share Posted November 3, 2011 The Z31 distributor swap on L series was a success, i am only waiting for the wheel release. Quote Link to comment Share on other sites More sharing options...
macambra Posted November 7, 2011 Share Posted November 7, 2011 I'm in!! When can it be available? Do you take paypal? I'm trying to convince my wife that I need a MS2 for Christmas. Quote Link to comment Share on other sites More sharing options...
