8DC Posted May 1, 2013 Share Posted May 1, 2013 The old large NAPA battery died over the winter, so I replaced it with the ETX14 motorcycle battery (O'Reilly's relabel of a Deka/Braille). Removed the plastic battery tray to strap this down and found a rusty shelf (never ends, eh?). Ignore the cables and strap, which are temporary and cobbled together with what I had on hand. The ETX starts the car surprisingly well. Being light and sealed, it should be easy to disconnect and take inside when it gets cold or during other long periods where the car may not see use. Quote Link to comment Share on other sites More sharing options...
PLATA Posted May 6, 2013 Share Posted May 6, 2013 (edited) I just installed this wood steering wheel on my beast a few ago and love look IGNORE THIS ONE < NO F&^&^%$ING IDEA HOW TO DELETE . Edited May 6, 2013 by PLATA Quote Link to comment Share on other sites More sharing options...
PLATA Posted May 6, 2013 Share Posted May 6, 2013 (edited) I just installed this wood steering wheel on my beast a few days ago and love the look Edited May 6, 2013 by PLATA Quote Link to comment Share on other sites More sharing options...
Domzs Posted May 6, 2013 Share Posted May 6, 2013 On 5/6/2013 at 2:25 AM, PLATA said: I just installed this wood steering wheel on my beast a few days ago and love the look 20130225_222855.jpg I like it . Where did you get it , MSA ? Quote Link to comment Share on other sites More sharing options...
PLATA Posted May 6, 2013 Share Posted May 6, 2013 (edited) Ebaymart...........................it's an NRG .......real wood and I mod it a bit , I likes it Edited May 6, 2013 by PLATA Quote Link to comment Share on other sites More sharing options...
rnye Posted May 6, 2013 Share Posted May 6, 2013 Drove it!!! Preliminary shakedown before ZDayz. Yes I will be running foam and I DO clear the bars when not taking an in car stoplight picture. Quote Link to comment Share on other sites More sharing options...
280zex Posted May 6, 2013 Share Posted May 6, 2013 Trying to do the 240sx 5 speed swap into a 1976 280z. Running into problems getting the bell housing machined. Nothings easy!! Quote Link to comment Share on other sites More sharing options...
Racer Z Posted May 7, 2013 Author Share Posted May 7, 2013 Drove it . . . real fast . . . on the track at Chuckwalla Raceway in So Cal. First time at this track and I got to say it is a fun track. The Z had three drivers for this two day event and performed well, no problems at all. Our rear disc brake mod seems to work very well. Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted May 9, 2013 Share Posted May 9, 2013 Finally got the replacement alternator after 5 days of waiting and got it in in 30min. Feels good to drive my car again. Also tried to test fit my new wheels on the front as well, but the tire is a little too big and hits the perch. Guess I'll just have to burn them off 1 pair at a time in the rear. Quote Link to comment Share on other sites More sharing options...
daddydonuts Posted May 10, 2013 Share Posted May 10, 2013 I put my front wheels back on cause my floor jack lost pressure and my front end was about two inches from hitting the ground Quote Link to comment Share on other sites More sharing options...
daddydonuts Posted May 10, 2013 Share Posted May 10, 2013 (edited) And I started removing the N/A engine... to make room for the Turbo Edited May 10, 2013 by daddydonuts Quote Link to comment Share on other sites More sharing options...
Dat260 Posted May 11, 2013 Share Posted May 11, 2013 Trying to fix my jumping tach issue, I searched and found a couple of approaches. - replaced the resistor situated in the passenger foot well, no go - dismantled the tach, cleaned it and slightly heat up the soldering connections, no go. Quote Link to comment Share on other sites More sharing options...
NCchris Posted May 12, 2013 Share Posted May 12, 2013 (edited) I finally finished welding in the new drivers' side rocker panel. The passengers' side went slick as snot but, discovery of old crash damage on the drivers' side almost caused me to scrap my early 260 project. After a lot of massaging I finally got it to fit. Wish I had known when I was replacing the floors!!! chris Edited May 12, 2013 by NCchris Quote Link to comment Share on other sites More sharing options...
Mikelly Posted May 12, 2013 Share Posted May 12, 2013 It was yesterday, but I track prepped my little monster, and she's ready (I hope) for her big showing at VIR. So what did that involve? Bleeding the brakes, changing the oil, checking the plugs and while I was at it, clearancing the inner two plugs on each side of the motor, which means "dinging" the pipes for air flow around the plug wire, adding some insulated wrap to a brake line that runs close to the header on the passenger side, and in general checking everything once, and putting a wrench on all the important bits. Rock on! Mike Quote Link to comment Share on other sites More sharing options...
duragg Posted May 12, 2013 Share Posted May 12, 2013 Stripped interior again for cage install. Quote Link to comment Share on other sites More sharing options...
LowCarbZ Posted May 22, 2013 Share Posted May 22, 2013 (edited) Putting an air-dam on finally. Sorry for the crappy iPhone pic. Should tie in nicely with the side skirts, just fitting before paint: Edited May 22, 2013 by LowCarbZ Quote Link to comment Share on other sites More sharing options...
OldAndyAndTheSea Posted May 22, 2013 Share Posted May 22, 2013 Didn't work on MY Z very much. Other than puttering. But...I managed to spray the first coats of 2k high build primer on my friend Pat's 1971 240z that is the background of many of my pictures. It was a long time coming.Here's just a SAMPLE of where it came from. The following is a modest shot to say the least. The body was pretty well neglected..But she's coming back, beautiful as ever.And here it is now. Freshly rolled out of the garage, before cleaning.He's going to drive it in primer for a while, until he affords paint.So he's slowly putting it back together. Not bad for a 800 dollar car. Quote Link to comment Share on other sites More sharing options...
bfg Posted May 23, 2013 Share Posted May 23, 2013 Went to a junk yard and got myself some Kia Sportage door seals. Quote Link to comment Share on other sites More sharing options...
sito Posted May 23, 2013 Share Posted May 23, 2013 Got my radio reinstalled and cleaned up some more wiring. I can finally listen to some music in the Z! Quote Link to comment Share on other sites More sharing options...
Darrel Posted May 24, 2013 Share Posted May 24, 2013 (edited) Wasn't mine. Helped do the front suspension, eibach springs, poly bushings, illuminas. Started the driver side first. Couldn't get the strut out of the tube. PB blaster, heat. So far nothing working. Did the pass side with no problems, already back together. Back to the driver side strut. More heat, pb blaster. Leaving a scissors jack under pressure with vise grips at the top with nut at the top of the strut. Base of the scissors jack against the vise grips, the other end of the jack on the spring perch. The cartridge does move side to side slightly, but not enough to completely free it up to lift it out. Will keep it under pressure over night and smack it with a hammer again in the morning. ** Bent strut housing, got one from salvage yard, same thing bent housing. Gave her one of mine, will replace when she gets one. Car is on the road. 5-24** Edited May 30, 2013 by Darrel Quote Link to comment Share on other sites More sharing options...
