Tomzern Posted February 1, 2016 Share Posted February 1, 2016 Hi! Sooo, I have an ongoing stroker build and just AFTER I got my F54 block resurfaced and bored to 89mm I found out that the best block for an 89mm overbore is the N42 and the F54 is a rather terrible choice for this. Wish I would have found this out before I bored it, but it's already done Now I am stuck with a finished F54 89mm block and I am unsure of what to do next. This engine is going to be a street engine and not a 10000rpm race engine. Is there anyone here who is running an F54 based stroker? Will it almost certainly fail? Any constructive input is appreciated here:) -Tomzern Quote Link to comment Share on other sites More sharing options...
Lurcher Posted February 1, 2016 Share Posted February 1, 2016 Were the bores Sonic tested before it was bored?Or were you just a cowboy and bored it on the original bore centreline? FWIW I went through 4 blocks - both N42 & F54 - before I found a my current F54 block that could take a 89mm bore safely - while retaining 120 thou wall thickness. Quote Link to comment Share on other sites More sharing options...
NewZed Posted February 1, 2016 Share Posted February 1, 2016 On 2/1/2016 at 10:28 AM, Tomzern said: Any constructive input is appreciated here:) Measure bore wall thickness so that you have some numbers to work from. Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted February 1, 2016 Share Posted February 1, 2016 I know 3 people who were running an F54 3.1 stroker. They had the blocks checked before hand. These are also just street builds, so maybe 250whp max. Quote Link to comment Share on other sites More sharing options...
Tomzern Posted February 1, 2016 Author Share Posted February 1, 2016 (edited) On 2/1/2016 at 11:59 AM, Lurcher said: Were the bores Sonic tested before it was bored? Or were you just a cowboy and bored it on the original bore centreline? Well I guess I am a cowboy then I just handed my engine mechanic the block and one of the pistons and told him to make it fit. It's my stupid fault of course. Should have done more research, but now it's done. At least it's good to know that there are F54 blocks that are thick enough. I will get it sonic tested and just take it from there. Thanks guys! Edited February 1, 2016 by Tomzern Quote Link to comment Share on other sites More sharing options...
Datsun#1 Posted February 2, 2016 Share Posted February 2, 2016 Ive got an n42 ill sell ya.pm me Quote Link to comment Share on other sites More sharing options...
Tomzern Posted February 2, 2016 Author Share Posted February 2, 2016 On 2/2/2016 at 1:02 AM, Datsun#1 said: Ive got an n42 ill sell ya.pm me Thanks for the offer, but I am located in Norway so It's cheaper to find one here Quote Link to comment Share on other sites More sharing options...
Andreas Posted February 2, 2016 Share Posted February 2, 2016 Im in Sweden, and may have a N42 block for you if you need it. Quote Link to comment Share on other sites More sharing options...
Lurcher Posted February 2, 2016 Share Posted February 2, 2016 (edited) My engine builder had a F54 block with a crack in the deck along its length that was un-repairable, so he milled the top of the deck off to see where the bore core shift was.Notice how non-concentric the bore castings are - this make sonic testing and off-set boring a must! Edited February 2, 2016 by Lurcher Quote Link to comment Share on other sites More sharing options...
Xnke Posted February 4, 2016 Share Posted February 4, 2016 They are offset exactly the wrong direction there lurch---woulda been great if the core was the other way round, wouldn't it! Coulda had a killer thrust side thickness to bore into, and moving the bore that direction helps with valve shrouding too. Quote Link to comment Share on other sites More sharing options...
josh817 Posted February 9, 2016 Share Posted February 9, 2016 (edited) On 2/1/2016 at 10:28 AM, Tomzern said: Hi! Sooo, I have an ongoing stroker build and just AFTER I got my F54 block resurfaced and bored to 89mm I found out that the best block for an 89mm overbore is the N42 and the F54 is a rather terrible choice for this. Wish I would have found this out before I bored it, but it's already done Now I am stuck with a finished F54 89mm block and I am unsure of what to do next. This engine is going to be a street engine and not a 10000rpm race engine. Is there anyone here who is running an F54 based stroker? Will it almost certainly fail? Any constructive input is appreciated here:) -Tomzern I ran (and still have) an F54 block 3.1L from when I was 17 until I was 21 when I took the car apart. It ran fine. I doubt it's an issue unless you start revving high, making a lot of power, or just got a really bad block with thin walls. I didn't bother with sonic testing. I feel like this is a matter of what's best and what will work and you're at the point where you can spend extra time and cash to do whats best but really... really, what you have will probably do just fine for your intents and purposes. But that's just me. Edited February 9, 2016 by josh817 Quote Link to comment Share on other sites More sharing options...
30 ounce Posted February 9, 2016 Share Posted February 9, 2016 On 2/2/2016 at 8:18 PM, Lurcher said: My engine builder had a F54 block with a crack in the deck along its length that was un-repairable, so he milled the top of the deck off to see where the bore core shift was. Notice how non-concentric the bore castings are - this make sonic testing and off-set boring a must! I don't think this is an F54 block as it doesn't have the siamesed cylinders between 1-2,3-4,5-6. Quote Link to comment Share on other sites More sharing options...
HS30-H Posted February 9, 2016 Share Posted February 9, 2016 On 2/9/2016 at 12:59 PM, 30 ounce said: I don't think this is an F54 block as it doesn't have the siamesed cylinders between 1-2,3-4,5-6. Common misunderstanding. It's the coolant passages that are 'siamesed' on the F54, for more even cylinder cooling. It means less metal, not more. Quote Link to comment Share on other sites More sharing options...
30 ounce Posted February 13, 2016 Share Posted February 13, 2016 On 2/9/2016 at 5:46 PM, HS30-H said: Common misunderstanding. It's the coolant passages that are 'siamesed' on the F54, for more even cylinder cooling. It means less metal, not more. Actually I enlarged that picture and you can see the metal between 1-2,3-4,5-6. Quote Link to comment Share on other sites More sharing options...
HS30-H Posted February 13, 2016 Share Posted February 13, 2016 On 2/13/2016 at 6:27 PM, 30 ounce said: Actually I enlarged that picture and you can see the metal between 1-2,3-4,5-6. The point is that the cooling passages are siamesed on the F54. That means less metal, but not none. An N42 cut in the same way would look quite different. You'd see less coolant passage space and more metal. Quote Link to comment Share on other sites More sharing options...
Xnke Posted February 13, 2016 Share Posted February 13, 2016 On 2/13/2016 at 6:27 PM, 30 ounce said: Actually I enlarged that picture and you can see the metal between 1-2,3-4,5-6. You can see metal, yes, but if we cut that block down another inch you'll see an open gap. That open gap is what we're talking about, the N42 block does not have it. The webs are solid all the way down on the N42, and the F-54 block is only solid at the top and bottom of the bores. Quote Link to comment Share on other sites More sharing options...
1 fast z Posted February 15, 2016 Share Posted February 15, 2016 I have written many post about the Siamesed vs non on the F54 and N42. N42 has solid walls between 1-2, 3-4, 5-6. F54 does not. Quote Link to comment Share on other sites More sharing options...
LLave Posted February 17, 2016 Share Posted February 17, 2016 Hardbock it!.... Kidding, just kidding. Either run it, or don't. Quote Link to comment Share on other sites More sharing options...
WhitleyTune Posted February 17, 2016 Share Posted February 17, 2016 On 2/17/2016 at 6:41 PM, LLave said: Hardbock it!.... Not a silly idea. Block fill up to the water pump level if you are that worried about it. Quote Link to comment Share on other sites More sharing options...
rossman Posted February 18, 2016 Share Posted February 18, 2016 On 2/1/2016 at 10:28 AM, Tomzern said: ...what to do next. On 2/1/2016 at 11:06 PM, Tomzern said: Well I guess I am a cowboy Just run it cowboy! If it breaks, fix it. Quote Link to comment Share on other sites More sharing options...
