DuffyMahoney Posted November 7, 2024 Author Share Posted November 7, 2024 Dual L6 knock sensors using the stock block m6 hot water pipe mounts. They are actually about perfectly placed! These are just ti prototype. I am designing my own and will be adding them to the things I make and sell. 1 Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted November 23, 2024 Author Share Posted November 23, 2024 (edited) Custom grade 5 titanium studs of my design. I am so tired of installing the old studs and I hate the look of the allen ones. I designed intake, exhaust, my intake balance banjos, knock sensor stud, stack studs and my intake intake/ throttle studs! The flat spots work perfect with a box wrench. I also love the look of a rounded tip on a stud. I think they came out awesome, after testing I will be selling. I bought enough, that they should be fairly cost effective as well. Edited November 23, 2024 by DuffyMahoney Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted November 29, 2024 Author Share Posted November 29, 2024 Well I got my prototypes in for my passive cooling on my Efi hardware throttles! These will be between the heat shield and the throttle bodies. Also it will be a nice and clean way to run the return fuel. 2 Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted December 4, 2024 Author Share Posted December 4, 2024 I love it when a plan comes together. This is custom titanium banjos, which will come off my balance bar and hold my heat shield on! 2 Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted February 3 Author Share Posted February 3 240z hidden drive by wire actuator for my ITB setup. This is design number 4. This plan utilizes a Efi hardware actuator. The goal is the same length arm to the bell crank and distances from shafts and the rod. So the rod passes through the firewall evenly and doesn’t walk from left to right. This will mount to the pedal plate and the steering box mounts. So behind the firewall Prior designs walked too much in the hole and I don’t want that. 2 Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted March 18 Author Share Posted March 18 Well I decided to pick a new header. I wanted the header to give my room on port 5-6 for my lower mounted actuator and also get out of the way of the throttle bodies a little more. I decided on the Kameari drag 45mm. Which I purchased through Binh Nguyen. The header design gives me plenty of clearance for my actuator and throttles! Pretty darn happy with it overall. Prior I had a now moth balled Fujitsubo header. Which had a terrible runner design for a lower actuator. Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted April 8 Author Share Posted April 8 I love it when a plan comes together! Fully operational below dcoe throttle body actuator for DBW ITB. Mostly hidden! Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted April 14 Author Share Posted April 14 Quote Link to comment Share on other sites More sharing options...
Derek Posted April 15 Share Posted April 15 Man that is so cool. Not as cool as a DOHC though. 😀 I'm for sure going to do this mod at some point especially after seeing how responsive it is. Great job! Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted April 16 Author Share Posted April 16 On 4/15/2025 at 3:42 AM, Derek said: Man that is so cool. Not as cool as a DOHC though. 😀 I'm for sure going to do this mod at some point especially after seeing how responsive it is. Great job! I don't have DOHC type funds:) Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted April 18 Author Share Posted April 18 Here is something fun/ silly I have been thinking of and finally made. It’s a remote oil pressure distribution block made to look like the stock 240z brake prop valve. I previously had a steel T In the block, that broke off and then when I was using an easy out I cracked my stock block bung. I said never again! 3D metal printing is neat stuff. I had it tumbled to look even more cast. I run stock gauges and my ecu needs its own signal. This location allows stock wiring to also work. Quote Link to comment Share on other sites More sharing options...
A to Z Posted Wednesday at 04:40 AM Share Posted Wednesday at 04:40 AM very nice. You don't happen to make a vacuum line distribution block do you? I have 3 items needing vacuum supply, and they don't like T's in the line. Quote Link to comment Share on other sites More sharing options...
