softopz 16 Posted December 10, 2019 Share Posted December 10, 2019 As you guys may have seen on social media we are almost finished putting the final touches, for a custom intake manifold for the l-series. We thought it only be fair to post here as well. Here are the details... Finally a Beautifully Tig welded Aluminum Intake Manifold For the L-Series motors. With a choice of 75/ 90mm Throttle body and Fuel Rail. We have been researching and devoloping this behind the scenes it is a very well thought out piece that has function and form combined. Link to store with full details (75mm intake set) Follow us on our Facebook and Instagram by giving a like to stay up date with new product development and sales. now check out sweet shots!! More on our social media pages Link Quote Link to post Share on other sites
malibud 0 Posted December 10, 2019 Share Posted December 10, 2019 Does it clear the cooling mod ? Quote Link to post Share on other sites
HuD 91gt 6 Posted December 10, 2019 Share Posted December 10, 2019 (edited) Anyone doing the cooling mod shouldnt have issues cutting this flange to make it work. but to answer your question, im betting that’s a definite no. Edited December 10, 2019 by HuD 91gt Quote Link to post Share on other sites
softopz 16 Posted December 10, 2019 Author Share Posted December 10, 2019 I haven't done the cooling mod. To be honest I don't know at the moment. Quote Link to post Share on other sites
HuD 91gt 6 Posted December 11, 2019 Share Posted December 11, 2019 Considering the flange is solid between all runner, the answer would be no. Quote Link to post Share on other sites
softopz 16 Posted January 19, 2020 Author Share Posted January 19, 2020 INTAKE (4 colors Red, Blue, Flat Black , Polished) Anodizing at no extra charge Angled Plenum/Runners: improves air flow smooth transition into head allows easier access to Header/DownPipe for maintenance. Less Heat soak due to reduced heat absorption properties of materials (when compared to stock and other aftermarket manifolds). CNC BILLET Flange with built-in fluted runners to minimize eddy turbulence and promote nearly even cylinder head aspiration at all ports. Gorgeous Fabrication: TIG welded Aluminum Bolts and Fittings included. Vacuum ports: 4 on the top/side to support vacuum-based accessories and accurate MAP readings. Durable Finish FUEL RAIL (5 Colors Black, Polished, Red, Blue, Purple) Fuel Rail designed for 14mm/11mm Or oem Barb style Injectors ORB-8 inlet with 6AN male fitting ends Fuel Pressure/Sensor Port (Plug included) THROTTLE BODY (Will match chosen manifold color by default. (Otherwise message us for different color selection). 90mm Throttle body, Improve throttle response and increase air flow! Cable actuated. Improves throttle feel and smooths pedal feedback. (Plus no more yellow balls and ugly mechanical linkage!) Utilizes stock OEM TPS/240sx or 2jz adapters included! (for modern Engine Management Systems that require potentiometer) Shipped Via Express Tracked and insured. Intake is very well packed with dense foam to ensure perfect delivery. Please view pics Quote Link to post Share on other sites
softopz 16 Posted June 12, 2020 Author Share Posted June 12, 2020 Just a small update we have already shipped out Intakes and we have some left! Quote Link to post Share on other sites
DuffyMahoney 2 Posted June 14, 2020 Share Posted June 14, 2020 I can't wait to see flow data! I bet it will do well. I would buy it just for the looks. So much better then the stock. Quote Link to post Share on other sites
