List your L28ET setup.
Guest 280ZForce
ENGINE SPECS:
BOTTOM END:
-L30ET
-N42 Block
-Maxima v07 LD28 Diesel Crank
-Lightened, polished & prepped 9mm 240Z rods
-Ross Forged Dished Pistons
-ARP Studs throughout longblock
-1.25mm Ajusa Metal Head Gasket
TOP END:
-p90 head (head is ported and polished with 5 angle valve job, performance valve train)
-Isky Custom Grind Turbo Cam
-Kameari Adjustable Cam Gear
INTAKE MANIFOLD - Extrudabody 45mm efi ITBs on Canon Manifold and custom aluminum plenum
HEADER - GReddy Tubular Turbo Exhaust Header
TURBO - Holset HY35 (externally wastegated, ceramic coated
WASTEGATE - Synapse Engineering 50mm vband external wastegate
BOV - GReddy RS BOV
INTERCOOLER - Treadstone 29x12x3.5 One-Sided Vertical Flow Front Mount Intercooler
INTAKE SYSTEM - 4" CAI with Huge K&N Air Filter (4" inlet/14" long)
EXHAUST - 4" Downpipe, 4" mandrel exhaust system that splits to dual ovals, Dual Aero Turbine Mufflers
RADIATOR: Afco Aluminum Radiator w/ 16" Electric Fan
OIL COOLER: FC Oil Cooler
GEARBOX: Tremec T56 (swap & clutch setup in the process)
EMS/EFI:
-Mega Squirt Engine Management (MSnS)
-Custom Coil on Plug (COP) Setup using LS1 Vortec truck coil packs (in the process)
-Magnecor R100 custom plug wires (10mm)
-14mm O-ring Fuel Rail
-785cc Rochester Injectors
-Aeromotive FPR
-Aeromotive A1000 fuel pump
-RCI 15g Aluminum Fuel Cell
APPROX POWER: Around 600 whp/600 ft-lbs tq on 20-25 psi
*bookmarked page three times to make sure i had it*
*checks again to make sure it saved*
Hey, you know how everyone is saying, "this will be a great thread for someone who wants to build a turbo Z?"
Thats ME :D
YAY!!! thanks again everyone, the info is much appreciated. and now i am very jealous...of all of you :sour:
ENGINE: f54 block with stock turbo pistons, n42 head with NA cam. ARP hardware.
TURBO: T3 at 7psi with supra MKIII intercooler, boost at 2500rpms
FUEL: zxt 270cc injectors
ELECTRONICS: :( :( :( stock NA ECU with "tuned" NA afm
EXHAUST: 3inch DP with 2.5inch exhaust
HP: Lower then a stock NA l28!, or so it feels...
NOTE TO ALL: I just finished putting this together, its one of the many things Ive been doing to my Z while Ive been away... It pretty much runs like crap and I need MS, or at least a turbo ECU/wiring harness. Got one for sale? 707-252-6070, please let me know!
Clear out your pm inbox, no one can send pm to you. http://cgi.ebay.com/ebaymotors/Datsun-Nissan-280z-280zx-L28et-Turbo-Kit-LOOK_W0QQitemZ320278678450QQcmdZViewItem?hash=item320278678450
This includes a harness, you could sell the stuff you dont need.
That turbo is jacked!!!! Did you look at the compressor wheel?!?!?!? Eff that!
Chris and Big Phil, both of your cars are making tons of power with just a L28 without the diesel crank? Thats amazing! What is it about your builds that gives you all the power and torque? Custom cam grind? Bigger injectors? Big turbo with lots of boost?
It would certainly be cheaper to build a turbo engine with the stock 2.8L crank than to hunt down a diesel crank.....and if it makes that much power that way, then it makes me wonder why I'd bother looking for one....
Greg
My L28 setup:
N42 block and crank
87mm forged wiseco-pistons
LD28-rods
NA P90 head (valves/seats 3angle, heavy valve springs)
stock intake manifold
exhaust manifold by me
3" exhaust all the way
1,6mm kameari metalheadgasket
about 8,8:1 CR
Boost 1,1bar
megasquirt
688cc injectors
Holset Hy35
Power: 394hp at the engine
Torque: 570nm at the engine
L24 block, balanced and blueprinted, Aeris 9mm pistons
E-88 head, o-ringed, Racer Brown cam, Not sure about the valves or the springs but know that it was all replaced with high-end siht back from 1979-81.
MSD 6-T ignition, Mallory coil, MSD Super-conductor wires, Pertronix pick-up
Turbo Tom kit, Holley 660cfm carb ( was just rebuilt by Dan Davinci)
Water injection
I have put in a Centerforce Dual-friction clutch in the 4 speed. I don't have a lot of faith that the R180 rearend will stay together or the transmission for that matter with this thing being as stout as it is....( just more parts for me to change out)
I have not dyno'd the car but will when I get the cracked manifold fixed as well as a exhaust leak. It will be a while before this sees a dyno. I have a few other parts I want to change out. The car sat in a garage for about 15 years without being started or touched, I have been going through it slowly for the last 2 years and I think it will be about that long untill I am done with it completely.
Here s the thread on the car.... http://forums.hybridz.org/showthread.php?t=117481
N42 Block , O ringed
88mm BRC coated pistons
133mm Cunningham I beam rods
Diesel crank
N42 Head pro- ported, stainless valves, 1mm oversized exhaust. WEB Cam (secret specs), MLS head gasket
N42 non EGR manifold , cut apart ported and welded together, ceramic coated
Stock Exhaust manifold with turbo outlet relocated , ported and ceramic coated
AEM EMS with custom wiring harness
T56 six speed with custom adaptor and Rockland Standard Gear 750rwh drag kit
10,000 rpm tripple disc 750rwh drag clutch
Six 72lb injectors(gasoline) , two 160lb injectors (methanol)
TO4S T67 with .82 with p trim wheel, ball bearing.
427rwh 434 fpt @17psi
http://www.cardomain.com/ride/2071134
Looking for 500rwh and 30mpg using 240cc and 1600cc injectors using gasoline and methanol , from two seperate fuel systems.
3.0L L with:
F54 Block, Bored .060, stainless steel o-rings in machined grooves on deck
Solid copper head gasket
Diesel Crank
Prepped 240Z rods (polished, shot peened, bushed for floating pins)
Venolia forged turbo pistons, skirts and tops coated
ARP rodbolts, Main studs, and head studs
Rotating assembly balanced
P90 head with minor cleanup porting/ Ferrea Stainless valves, +1mm
oversize exhaust valves
Elgin Turbo cam 280/266, 505/480, 112*
Thagard intake manifold
Weber 60mm Throttle body
Diesel water pump
Arizona Z Car oil pan
BAE cast log manifold with T3 and external wastegate flanges welded on,
ported and coated
T3/T4 -.63/stage 5, t04S 70 trim (67mm)
Turbonetics Racegate
3" downpipe
Magnaflow race muffler
Electromotive TEC2
78 pound Delphi Injectors
BHJ Damper with 60-2 trigger wheel
Bosch Porsche Turbo fuel pump with MSD Pump voltage booster
G- Force T5
ACT pressure plate w/ Clutch specialties sintered iron disc
McCleod hydraulic Throwout bearing
3.69 R230
424 rwhp, 538lb/ft torque @ 17psi
**Engine/turbo/EMS to be removed soon, and will be for sale**
ENGINE SPECS:
BOTTOM END:
Bone stock junkyard pull. Had about 185,000 miles when removed.
Headgasket blew, now running felpro and ARP head studs.
TOP END:- p90 head
INTAKE MANIFOLD - Stock N42
HEADER - Stock manifold
TURBO - Stock Rb25det
WASTEGATE - Stock Rb25det
BOV - None yet
INTERCOOLER - Home brew, see avitar.
INTAKE SYSTEM - 3" CAI
EXHAUST - ebay downpipe and 3" unrestricted straight out
RADIATOR:- Stock
OIL COOLER- None yet, have everything sitting and waiting for my 62-1
GEARBOX: stock 79 280zx w/aprox. 300K miles
EMS/EFI: MSnS not sure which version
this setup is building boost by 1300 rpm and full boost by 2400 rpm
197rwhp / 285 rwtq @ 12psi (also was like 95deg outside)
Bottum end: Stock N block from 77 Z
ARP main/Rod/Head
2mm Metal Head Gasket 7:1 compression
Bone stock P90 head
60mm 240sx throttle body
N42 non-egr intake ported to TB
Stock exhaust manifold/Tial 38mm welded on
Holset HY35W with puck welded
Filter on turbo..working on CAI
2.5 intercooler piping and 12X24 intercooler
Aeromotive FPR and wallboro 225 pump
Pallnet rail with Supra 440cc injectors
MS&S 2.2
Spec stage 2+ clutch (feels stock but holds)
Jegs universal radiator
Taylor wires
NGK plugs
Full boost hits @ around 3100-3300
15 PSI worked out to 280rwhp and 330rwtq around 60 degrees outside with 2.25 exhaust
20 PSI worked out to 308rwhp and 360rwtq around 95 degrees outside with no exhaust
25 PSI with the new meth kit running 100% Meth ???? Haven’t tuned yet???
The Heat really made a HUGE difference in power...the 280rwhp was using a 2.25 exhaust and the 308 had no exhaust but was hot outside!!! I wonder what the 308 would be if it was 60 degrees outside?
Going back to the dyno soon so I may play with a few things…Tune the car for the 25PSI on meth –or- Leave the car @ 20PSI and hit it with a Wet 75 shot. Still haven’t decided which way to go yet. I have 4 blocks in my garage so I might just have to see what the stock block will hold with a good tune.
PHASE 1:
135K mile all stock L28ET
P90A Hydraulic Stock head
Stock EFI/injectors/ignition/AFM
Walbro Pump
Begi FMU
T3/TO4B Super-V trim rebuilt unit
Long, restrictive, cold air intake.
2.5" DP and exhaust glass pack tail
Spearco Intercooler 2.5" I/C tubing
14psi boost/65psi fuel
ACT 6-puck solid disc clutch
Dyno'd 265rwhp/300rwtq
Runs leaner around 5500rpms. maxed out factory EFI.
PHASE 2:
Megasquirt II v3.0 w/4bar sensor
Megaview data panel in dash
LC-1 Wideband O2
Ford Lightning 42# injectors
JSK Fuel rail
Large cone filter intake directly on compressor inlet.
Guessing 300rwhp/320rwtq
No more leaning out!
15psi removed FMU for stock fuel pressure.
PHASE 3: (in progress)
Ford EDIS-6 ignition system in progress.
Rebuilt P90A original solid lifter head w/5 angle valve job.
Ported stock exhaust manifold.
Gasket/Port matched intake/exhaust.
Z32 5-speed in progress
Fidanza 11lb flywheel in progress.
ACT sprung center 6-puck clutch in progress.
Great thread. Anyone out there running a "blow-thru" or "draw-thru" carburated turbo set up on their L28?
Julius
yeah my lil brother who also has a 240z is doing a blow -thru carb set up should be done in a few weeks this is the stuff he has so far:
L28et long block
cliffford 6=8 4barrel intake manifold
t3/t4 turbo
holley 650 cfm double pumper modded for blow threw
greedy b.o.v. type rs
all he needs is a front mount ic waste gate and indution piping witch we might get this weekend
Greg
you don't need the diesel crank.
  • 1 month later...
ENGINE SPECS:
BOTTOM END:
-L30ET
-N42 Block
TOP END:
BOV - GReddy RS BOV
EMS/EFI:
-Aeromotive FPR
Your car makes me so excited that I want to punch my own mother in the face for no reason.
By the way... what is that small opening just above the Datsun emblem on the driver's side?
1983 280zxt 2+2
-engine= stock bottom end, 185km on the clock
-turbo= jy h-trim t04b compressor, t3 .82 stage 3 hotside
-Exhaust system - 3" as well as muffler bypass behind rear wheel
- How much boost- 21-23psi
-ECU= I ran the time in my sig with a nistuned z31 ecu/z32 maf, i dyno'd with an infiniti m30 ecu/z32 maf
- autospeed dc motor controller with an m15 and a m10 nozzle methanol setup.
-CC injectors - z31 ecu/440cc - latest setup = m30ecu/nippon denso injectors flow tested@670cc
-IC - dual grand national cores welded together with 2.5" piping both sides
-HP= 422hp on a mustang dyno @ 21-22psi
I should mention that I have a built cyl head, but I'm not sure on the specs.
I get about 5psi by 3k with max setting hitting around 4k.
In my opinion the L28ET is sufficient to run any zcar into the 10's with the earlier cars having very low 10sec et's available to them with very little work.
  • Like 1
Block. Unknown mileage J/Y turbo short block
Head. P90, port matched and cleaned up, Schneider springs, Delta cam
Intake. Custom manifold, MKIII intercooler
Ex Man. Stock w/ T4 flange welded on
Turbo. GT35R cold side/ P trim,.58 hot. 38mm WG 15 psi base spring
EFI. 550's, SDS
HP.... With old turbo (slightly smaller), different JY block and stock cam. 358
rwhp at 15 psi, 417 w/ 22 psi on a dynojet.
