Porn
auxilary
Yes I heard that plane leaks alot from the panels constantly shrinking and expanding from the atmospheric pressures. I also heard it theoretically has an unlimited top speed.
We need SR71 trivia sheet!
The body panels are made to fit loosely because of the body panel expansion from the heat generated by friction of air at high speeds and high pressure air on the leading edges of the surfaces. (awful run on sentence sorry)
  • Replies 40
I've seen 61-7976 up close and personal here in Dayton at the Air Force Museum. I can confirm that there are STILL pans underneath them to catch what drips out. The nose of the plane is close enough to the velvet ropes surrounding it that I touched it once. Much to my surprise, it was not smooth, in fact it was extremely rough. If you think the first post's picture was cool, you should see one from < 10 feet.
Jay
A12's and Sr71's give me a woodie!!! The Ultimate airframe! Pacific Ocean to Atlantic Ocean in 1 hr. IIRC this plane was first flow in 1959!
Thats 51 years ago. Nothing could touch it!
They fly faster than a 30.06 bullet! The leading edge of the wing glows red at speed due to fiction!
Damb, I'm Drooling!!
Mongo
If we are capable of something like that 50 years ago in complete secrecy, imagine what we could do with todays technology.
yes and no. yes, our tech is way out there compared to other countries. However, during the space race, America pushed science, math and tech in schools. that is why we were 20 years ahead of the compitition (except for the space race which we should have won if the green light was given to JPL). Now we are still ahead but not as much because we push buisness instead of math and science. Priorities.
Jimbo
The A12 and SR71 maxed out at about Mach 3.2 although one pilot flying over Libya hit Mach 3.3 outrunning a SAM. The A21 first flew in 1962 and the SR71 first flew in 1964. The A12 also was used as the basis for the M21/D21 drone program. Imagine launching a Mach 3.5+ drone from the back of the A12 at Mach 3.
The first launch of the D-21 from the back of the M-21 occurred successfully on March 5, 1966. The release was successful, though the drone hovered above the back of the M-21 for a few seconds, which seemed to one of the flight crew like "two hours". Kelly Johnson called it "the most dangerous maneuver we have ever been involved in, in any airplane I have ever worked on."
My brother was stationed at Beal AFB in the late 70's. At that time Beal was home for the U2 and the SR-71. I had the privilege to see both of these planes in the air. The SR-71 flew right over his on base housing, very low, while we were in the back yard, it was a very impressive sight.
I've seen the SR-71 in flight too. Mid 80's at the Point Mugu Naval Base airshow with the Blue Angels (in F4 Phantoms). The Blackbird came from directly behind the stands at very low altitude at probably about as slow a speed as it could go. It cruised out over the ocean and then the pilot punched it and it disappeared very quickly into the distance. Nice sonic boom. I was about 8 at the time, still remember it like it was yesterday.
The Ram-Jet engines used on the SR-71 are essentially just a burner can, a fuel nozzle and a ejection nozzle. No real moving parts, and the faster you shove air in, the faster you go. So no real top speed on the engine, it was airframe limited.
Not exactly true. The P&W J58 is a variable cycle turbojet that has a compressor assisted ramjet section. At high Mach speeds 60 to 80% of the engine's thrust came from a fan assisted ramjet bypass of the turbojet burner section. It does not have an unlimited power output (top speed) due to the heat created by compressing the air with the supersonic shock wave. At full power it generated about 35,000 lbs of thrust.
According to the Wikipedia SR-71 page, 12 of the 32 planes were destroyed in accidents. The page if full of info on the history of the planes: http://en.wikipedia.org/wiki/Sr-71 Below is the list showing the fate and disposition of the 32 planes.
List of SR-71 Blackbirds
Serial number / Model / Location or fate
61-7950 SR-71A Lost, 10 January 1967
61-7951 SR-71A Pima Air & Space Museum, Tucson, Arizona
61-7952 SR-71A Lost, 25 January 1966
61-7953 SR-71A Lost, 18 December 1969
61-7954 SR-71A Lost, 11 April 1969
61-7955 SR-71A Air Force Flight Test Center Museum, Edwards Air Force Base, California[74]
61-7956 SR-71B Kalamazoo Aviation History Museum, Kalamazoo, Michigan
61-7957 SR-71B Lost, 11 January 1968
61-7958 SR-71A Museum of Aviation, Warner Robins, Georgia
61-7959 SR-71A Air Force Armament Museum, Eglin Air Force Base, Florida[75]
61-7960 SR-71A Castle Air Museum, Atwater, California
61-7961 SR-71A Kansas Cosmosphere and Space Center, Hutchinson, Kansas
61-7962 SR-71A American Air Museum in Britain, Imperial War Museum Duxford, Cambridgeshire, England[76]
61-7963 SR-71A Beale Air Force Base, Marysville, California
61-7964 SR-71A Strategic Air and Space Museum, Ashland, Nebraska
61-7965 SR-71A Lost, 25 October 1967
61-7966 SR-71A Lost, 13 April 1965
61-7967 SR-71A Barksdale Air Force Base, Bossier City, Louisiana
61-7968 SR-71A Virginia Aviation Museum, Richmond, Virginia
61-7969 SR-71A Lost, 10 May 1970
61-7970 SR-71A Lost, 17 June 1970
61-7971 SR-71A Evergreen Aviation Museum, McMinnville, Oregon
61-7972 SR-71A Steven F. Udvar-Hazy Center, Washington Dulles International Airport, Chantilly, Virginia
61-7973 SR-71A Blackbird Airpark, Palmdale, California
61-7974 SR-71A Lost, 21 April 1989
61-7975 SR-71A March Field Air Museum, Riverside, California[77]
61-7976 SR-71A National Museum of the United States Air Force, Wright-Patterson Air Force Base, Dayton, Ohio
61-7977 SR-71A Lost, 10 October 1968
61-7978 SR-71A Lost, 20 July 1972[3]
61-7979 SR-71A Lackland Air Force Base, San Antonio, Texas
61-7980 SR-71A Dryden Flight Research Center, Edwards Air Force Base, California
61-7981 SR-71C Hill Air Force Base Museum, Ogden, Utah
I wonder how old that list is? We have a SR-71 here in Mobile Al at Medal of honor park where we have the USS Alabama. Very impressive indeed walking around that thing!
Edited by wigenOut-S30
Sorry I dumbed it down a little. It had to have compressor assist just to take off, ram jets are only efficient after your moving.The little I know about them I learned in T56-A-15 school, just basic principles. Another thing I herd was that there is a sonic boom happening inside every jet engine, but the act of compressing the air keeps it contained. (True?)
Edited by thrustnut
  • 5 weeks later...
