NewZed Posted August 20, 2012 Share Posted August 20, 2012 I see a weight on the left and a part description, under a year-of-car heading. What's the issue? Hard to complain about free. Quote Link to comment Share on other sites More sharing options...
Racer Z Posted August 20, 2012 Author Share Posted August 20, 2012 Is there some reason your "table" doesn't list O.E.M. parts and weights next to the weight of the part(s) you replaced them with? This isn't a table, it's a series of lists that one must read through and struggle with to extract any meaningful information. I will do this and post a spreadsheet that actually show a "table" of comparisons so that one can actually use it at a glance. Well, to answer your question as honestly as I can: At the time that I started it I didn't realize just what it would turn into. If I knew how to program for spreadsheet, maybe I would have thought to start on a different platform. As to why I have not changed it or updated it: After a few weeks the post can not be changed. I can't add to it or alter it in any way. I thought about changing it so that I can have it show a table that's hosted on another server. I even wrote the HTML code and posted it to the internet. I asked a moderater to change it for me. I tested my code in a temp posting here and made it work, set him the code. He said he chabged it for me I can't see any change. So, this became an abandoned topic on my part. You're welcome to use what I posted in any way you like. Just try to avoid the pitfalls I fell into. Quote Link to comment Share on other sites More sharing options...
ls240z Posted June 19, 2013 Share Posted June 19, 2013 To bump this thread... I recently tore out a bunch of items from my 78 280z and decided to weigh them all. All weights are within 0.2lbs. Triple Webers w/ Cannon manifold - 28.4 Dash w/ glovebox + harness/gauges - 30.6 Quarter window plastic x2 - 1.4 Dash cowl piece - 1.2 Console w/ armrest cover - 4.6 Toolbox area 90° carpet holder - 1.2 Sunvisors x2 - 1.4 A pillar covers x2 - 0.2 Rear view mirror - 0.6 Seat belt buckles x2 - 1.2 Lower quarter window covers (speaker holes) x2 - 1 Ashtray - 0.2 Maplight/Vent control cover - 1.2 Ashtray sliding cover - 0.6 Footwell plastic covers x2/lower glove box plastic - 1 Gear shift lever w/ knob and trim - 1.2 Door panel w/ armrest, window knob, handle cover x2 - 12 Upper/lower steering column covers - 0.4 Dash cap - 1.4 Hood w/ vents - 39.4 280z tail light x2 - 3.6 Tail light cover x2 - 1.6 Fuel reservoir tank - 4 EFI harness - 4 Washer fluid reservoir - 0.6 Bosch ignition coil - 1.8 Relays + cover from pass. side engine bay - 1.8 EFI module - 2.4 HVAC controls - 3.8 Defrost vent x2 - 0.4 Dome light cover - 0.8 Door sills x2 - 1 Interior tail light panel - 1.8 Spare tire well area - 14.6 Quote Link to comment Share on other sites More sharing options...
zohanisback Posted June 24, 2013 Share Posted June 24, 2013 I anyone interested in me making a Google doc we can all access? You can organize it by weight or name so you can view the items easier and select which ones are priority. 35# for a seat?!!? Good thing those were the first to go! Quote Link to comment Share on other sites More sharing options...
Gollum Posted August 24, 2019 Share Posted August 24, 2019 Nice! I'd say that should get cross posted here, but it got moved to the FAQ section, which can't be posted in Quote Link to comment Share on other sites More sharing options...
tube80z Posted November 12, 2019 Share Posted November 12, 2019 On 8/24/2019 at 9:43 AM, Gollum said: Nice! I'd say that should get cross posted here, but it got moved to the FAQ section, which can't be posted in I moved it to the FAQ. I tried to keep it here too but couldn't get that to work. Cary Quote Link to comment Share on other sites More sharing options...
AydinZ71 Posted February 25, 2021 Share Posted February 25, 2021 (edited) Digital fish scale. 600lbs capacity. Assume +-5% error or to within nearest pound, whichever is greater. R200 open diff, no oil, with cover, no stub axles, including front yoke: 70 R180 from Subaru STI w/ helical LSD, no oil or stub axles, with cover and front yoke: 56 280z halfshafts (drive axles), with diff stub axles attached, left and right: 31 280z front diff mount: 3.1 Edited February 25, 2021 by AydinZ71 Quote Link to comment Share on other sites More sharing options...
AydinZ71 Posted June 5, 2022 Share Posted June 5, 2022 More to add… weights in lbs. from a series one 240z. 50-lb kitchen scale. Accurate to 4oz OEM 240z genuine Nissan windshield: 25 polycarbonate windshield cut-to-size: 11 Series one “bench” oem sheet metal behind seats (no storage cubbies): 7 Pedal assembly and steering wheel mount: 7 sway bar w/o links or mounts: 11 Quote Link to comment Share on other sites More sharing options...
JMortensen Posted June 5, 2022 Share Posted June 5, 2022 (edited) What thickness polycarbonate? I think most of the sanctioning bodies require 1/4" for front, but you can use whatever you like on sides and rear (most use 1/8). Edited June 5, 2022 by JMortensen Quote Link to comment Share on other sites More sharing options...
clarkspeed Posted June 6, 2022 Share Posted June 6, 2022 I was going to resurrect this thread soon also. Once I pull the chassis off the roterssere I plan to measure every component I install. I have a set of digital corner weight scales that seem pretty accurate. Quote Link to comment Share on other sites More sharing options...
AydinZ71 Posted June 6, 2022 Share Posted June 6, 2022 @JMortensen yessir. 1/4” front (rules call out 6mm). 1/8”/3mm everywhere else. i have more weights. Just need to dig up old photos of my scale with stuff on it. clark, looking forward to your weights as well. This stuff helps determine where the time and money should be spent. Quote Link to comment Share on other sites More sharing options...
jessejames Posted May 9, 2023 Share Posted May 9, 2023 Has anyone weighed the factory 240z brakes ? Quote Link to comment Share on other sites More sharing options...
manimal Posted November 2, 2024 Share Posted November 2, 2024 (edited) On 5/9/2023 at 4:16 PM, jessejames said: Has anyone weighed the factory 240z brakes ? Probably not helpful for you at this point, but Iron front caliper w/new pads, 2x mounting bolts(54g), and the stubby hardline(26g) - 4.53kg 260/280 front rotor, new - 5.27kg Front brake shield w/hardware - 0.505kg Rear aluminum drum, pads, backing plate, hardware, short hard+soft line, worn ~30% - 5.92kg Complete front brake assembly weight per side - 10.3kg(22.65lb), rear - 5.92kg(13lbs) My setup for reference added 18.32lbs compared to the OEM disc/drum setup Front - Z32 aluminum caliper(2.795kg), pads (0.735kg), Odyssey 296mm rotor(7.7kg), adapter, and hardware - 11.73kg (25.81lbs) Rear - VW aluminum caliper(2.55kg), pads (0.38kg), Z31 84-86 NA rear rotor(4.96kg), adapter, and hardware - 8.64kg (19.0lbs) Seats aren't 35lbs. The stock vinyl seat is 11.65kg(25.6lb) without the sliders and 13.70kg(30.1lbs) with them. Antigravity ATX30 restart battery, no terminals 2.45kg Front subframe, no hardware - 4.95kg Front subframe with engine mount risers removed - 4.28kg Brake booster with aluminum clocking plate - 2.78kg Wilwood 1" master w/Z reservoirs - 0.90kg Front tow hooks pair with 4x bolts - 0.88kg Stock 240z/260z spare - 17.1kg 07-12 Sentra 16" spare - 12.28kg Konig Rewind 16x7 with 205/55 Firestone Indy500 - 17.56kg Factory scissor jack 3.21kg Front early 260z bumper mounts with hardware, pair - 4.80kg Front early 260z bumper, no rubber trim panels or end mounts - 4.67kg Horn pair with hardware - 0.96kg Steel splash pan with hardware - 1.71kg front control arm w/rubber bushing- 1.20kg Outer tie rod - 0.61kg front ball joint - 0.70kg TC rod, no bushing/washers - 0.785kg 240z front spring - 2.175kg front spring top hat - 0.26kg Eibach 10" 225lb 2.5id spring - 1.135kg OEM strut top isolator w/hardware - 0.82kg Strut top bearing - 0.145kg 260z Front hub with bearing and grease, no studs - 3.04kg 4x ARP 2.7" extended studs - 0.223kg Rear control arm with poly bushings, spindle pin, and M20(?) bolt - 5.46kg Rear strut, shortened 1.5in w/5" aluminum coilover sleeve & adjuster, bilstein VW MK2 insert, stub axle - 11.78kg Bilstein VW MK2 insert with gland nut and top M14 nut - 1.60kg Front Diff/control arm mount w/4x bolts - 2.06kg Front Diff rubber mount(inc 2x M12 bolts, 245g) - 1.33kg Diff hold down strap w/hardware - 1.10kg R180 mustache bar w/rubber bushings - 2.75kg R180 260z with axles and fluid - 38.75kg Subaru R180 3.91 torsen lsd, dry, no stub shafts - 25.40kg 4spd 260z driveshaft w/hardware - 4.25kg 4spd trans w/clutch fork & TOB, no fluid or shift lever - 34.90kg 260z trans mount beam, M14 bolts, and rubber isolator - 2.15kg clutch disc and pressure plate - 5.20kg OEM flywheel + crank bolts - 10.05kg OEM chonky starter, not gear reduction version - 5.70kg Champion aluminum radiator 2.25" core w/mounting hardware - 5.52kg MSA aluminum dual fan shroud w/2x 12in fans + hardware - 3.07kg 260z steering wheel and horn pad - 2.33kg steering column shroud w/hardware - 0.17kg half dash cap - 0.60kg 260z console w/fat arm rest 2.53kg Rear side/taillight panels - 2.00kg Fender "assembly" with headlight bucket, hella H4, and side marker - 8.50kg Hella H4, old west germany stamp - 0.505kg koito H4, 2024 production 0.675kg datsun headlight bucket and retaining ring w/wire harness - 0.60kg Cowl - 2.09kg early 260z grill - 1.07kg Washer fluid bottle and pump - 0.225kg hood prop rod and hardware - 0.16kg Charcoal canister + bracket and hardware - 1.37kg Edited November 2, 2024 by manimal added brake pad weight 1 Quote Link to comment Share on other sites More sharing options...
