- Today
Got it off Amazon: https://amzn.to/4aS32Br And picked up a male pigtail off eBay: https://www.ebay.com/itm/134129914749 I actually replaced the wiper arms too. I used 93 miata arms which bolt up to the stock datsun wipers mechanism. Passenger arm is a little long so I may shorten it. For wiring, I followed this guide: https://www.electronixandmore.com/resources/automobiles/datsun/index.html Note this is very specific to the later wiring for 1978(maybe 1977 too) and would not be applicable to earlier years.
- Yesterday
Best looking convertible I've seen https://bringatrailer.com/listing/1971-datsun-240z-345/
MONZTER started following Turbo Intake Plenum
Last week my order from Apex Engineered came in so now I can start stripping down the car and prepping her for the body shop. Money is a bit tight right now so I’ll install all my suspension parts first and probably send the car of to the shop in February. In the meantime I decided to strip out the interior and see what’s hidden underneath. It doesn’t look that bad but for a car that has been quote on quote “restored” only 10 years ago they sure did a shitty job. Lots of surface corrosion sports throughout the interior, lots of missing bolts, fasteners and rubber plugs and unpainted parts from shotty repair work. I cleaned up the surface rust and sprayed a generous amount of rust converter on everything. I will order some more rust converter, primer and color matched paint soon to clean up and protect the inside parts. I’ll also look at some spray wax to protect the hidden parts and crevasses of the chassis. A guy on YouTube I follow (M539 Restorations) uses one from Liqui Molly I believe which seems pretty good so I will give that one a try. It's not all bad news though. It looks like that in all these years the wiring harness stayed unmolested by all the previous owners. I also found out that the car has 4 pretty big and new looking JBL speakers! They didn’t all work when I tested the radio but I believe that might be the head unit itself. I will probably replace it with a Bluetooth capable retro looking one in the future. I also found a full and intact box of original Nissan glass 10amp fuses in the trunk! - Last week
Got a little bit of work done, ran brake lines to the rear, waiting on a fitting for the front to plumb up my line lock and should be done. Also fuel cell, gauge and black box surge kit/pump came in. -
DAT26OZ started following Speed Forme Kit
12-13-2025. I installed my new water pump, repainted pulley and new hardware, and then re-installed the tensioner bracket and the aluminum plate needed for the additional of an idler pulley to make it all work right. I was able to use a drill bit to hold the pulley in place and measure for the spacers needed and the length of the longer bolt needed. I went to install the alternator, but the kit I got sticks out just a tad too far, and thus the alternator hits the rail.....so I will have to grind down the bracket to bring it in closer to the engine and then it will be fine....also found that my new drive by wire throttle body does not clear in standard configuration, So I was able to get it to work by turning it 90 degrees. Here's to hoping that will work. Then I quickly installed my new 4 core radiator and dual fans to check the fit. because my engine has the radiator spigots on opposite sides, I will be taking my radiator to my fab guy to cut the hose ports and welding on tight 90's with a length of pipe to the other side and then another 90 to make it a nice-looking remedy. I will make some nice aluminum brackets to hold the piping stationary. At any rate, I was able to verify that my radiator height is sufficient to maintain its place as the highest point in the system. After this, I cleaned out the garage, and went through a lot of boxes and prepped the car by covering the engine and front end to begin the sanding and block sanding, to get the rest in paint. I pulled the windshield, but after 51 years, it just didn't want to let the windshield go, and so it came out broken and in pieces. Not a crisis, as I wanted a new windshield anyway....just thank good ness the rear hatch glass came out just fine. I pulled the old hatch off, gutted it and to the dumpster with that rotten thing. I was also able to get a bit closer on the front blinker restoration, getting the housings painted white with rustoleum white. spray paint Only thing left is to lengthen the wires. I tri4d to wire wheel the headlight buckets, but decided they really just need to be sandblasted out. My mobile welder didn't make it today, so welding the clothes hangers in pieces to the front edge of the doors to close up a big gap will have to wait. Here comes sanding and blocking.
I have two Datsun 240Z cars both with stock body running 245 45's on 16" x 8" rims with no flares. I find it funny where people flare their car yet do not make use of the extra space. I also like Z cars with flares but why do it unless you get the right offset to maximize the tire size?
I purchased some gauge mounts from a seller on eBay for mounting the new Speed Hut gauges in the middle of the dash. They are 3D printed items. The design is pretty good. The plastic seems sturdy. And they incorporate metal thread inserts. The screws have a taper head, so they self center, and fit of the various parts is very good. However, I found that the gauges were loose when fitted to the housings with the backplates (which hold them in the housings) bolted tightly in place. The gauges rotated easily in the housing as there was no clamp force against the back of the gauge to hold the gauge forward against the "stop" portion that the bezel of the gauge is supposed to fit up against. After thinking about solutions for a bit, I pulled out some ancient Gore-tex I have. Basically, it is rubber gasket material with an adhesive on one side. It comes in handy for a lot of things. In this case, I cut a strip and ran it around the back of the bezel on the gauge. I fit the gauge into the housing and then pressed the backplate against the new Gore-tex rubber gasket to seat it into place. I then briefly removed the gauge from the housing and took this second picture (below) which shows how the new gasket deformed under "crush". Third pic shows that as well as the metal insert in the gauge housing. Another issue to overcome though was that the backplate only has two screws to clamp it to the housing, 180 degrees from each other. After I put the gasket in place and assembled the gauge in the housing, the backplate only pulled tight against the housing where the screws bolt up to the housing. See the first and second pics just below. I realized that I could take the aluminum mounting brackets I had already made during an initial attempt to mount the gauges in the dash, and flip them (back to front) and use the Speed Hut gauge mounting rings to resolve the situation however. See the third pic (above). While I thought I wouldn't need them any longer, these aluminum brackets ended up coming in handy. I simply screwed the Speed Hut mounting rings tight against the aluminum brackets... and this pushed the edges of the aluminum brackets against the plastic backing plate at the points which were not seating against the back of the housing properly. So, with this distribution of force at the non-secured parts of the backing plate, I was able to resolve the issue. I see now that I didn't take a picture of the other part of the gauge mounts. There is an arm that attached at the top and the bottom of the housing in the same way that was done on the stock 240z gauges. I hope I won't have any issues with that part bolting up, or with the gauge housings fitting in the dash holes. I will probably check that out this weekend.
I was talking about the dashboard frame, that the dash pad attaches also to. It's HEAVY. 12-11-2025. I got a nut and bolt run in today, got some painting going, ended up with a run on one side of the cowl, so once dry I will sand it out and repaint that side. I also started on a restoration of my front turn signals. PICS:
dont swiss cheese your frame bro. the weight savings is not worth the time and you need that strength. Hell, with the atlas power your going to need more frame rigidity. look into some rectangle tubing for frame to rear body of car frame rail extension. i dont know what its called but theres a lot of info on the frame rail upgrades on these cars. i bought bad dog frame rails but by the time i did it all and the time spent on fitting etc, your better off just fabbing your own imho you may want to have some 8-10" long angle iron welded to the front sway bar mount area for extra support. thats an easy mod. just a piece of angle with 2 holes drilled in it.
you may want to look into sourcing new Spal or Maradyne fans to replace those. I bought a similar setup for my c10 ls swap and the fans did not perform good enough. i was running 220+ and then temps climbing in traffic. This was dead of summer in Cali central valley heat so 105 hot as ballz. If it doesnt get as hot where you live you may not have that problem. I ended up going to the wrecking yard and getting slightly larger spal fans and enlarging the shroud holes a little larger to fit the fans. The Spal fans sucked WAY more cfms then those off brand. They dont pull/push to the specs they claim. I will be running dual pass 2 row on my z build. i currently have the 4?3? pass on the truck and i'll be redoing that again in the future. more passes is not better imho. bigger tubes for more heat displacement is what i'll be going for. live and learn lol. The powder coating looks great! if you dont mind me asking, what did that set you back? Powdercoating is expensive where i live. i have often considered this amazon setup. https://a.co/d/6zwvorr I think a turkey deep fryer base with a metal disc blade with grooves plasma cut into it to use as a heat deflector and then a metal trash can wrapped in rockwool, for the oven may work! idk. ive got all kinds of whacked ideas. Seems like that gun setup works best for budget setup though. i also seen where a guy used a shop diesel heater and then blew that into a metal duct into a box and that worked also. you only need to hold 400 degrees for 20min to set the powder coat. I was thinking sheets of plywood wrapped in tinfoil would work also. i've seen pigs roasted in those for hours and thats similar temps. also was thinking that if door hinges were used on the corners to hold it together you could just pull the hinge pins to dismantle and store all the pieces. still would need to wrap in rockwool i think. anyways, sorry to ramble at you, i just got a lot of parts i want to powder coat also lol i like the color you chose.. Rustoleum has a similar spray can color called "dark steel". ive been using that a lot to. i did my engine block and motor mounts in that so far.
I picked up my bellhousing and serpentine bracket for the 4200 engine today from the powdercoaters. The finish is called "polished aluminum". I had them done because frankly both pieces were ROUGH....really rough. R&S Powdercoating in Colorado Springs came through for me again. Sandblasted it out, masked off the gasket surfaces and did their thing.
I bought the same parts to do DBW months ago - my AEM Infinity ECU supports it as does the RusEFI ECU that I'm also playing with. Got harnesses built, just haven't installed the hardware - so that video is going to be very helpful.
Could anyone tell me the total length of a 350z pinion cheers
thanks. I just picked up that drum sander they sell. It comes with a 40 grit drum but I also grabbed a 120 grit drum for it also. I got a good deal on this. 4 core with dual fans made to fit the 260Z I am building. It's an eBay buy. Read up on and decided to try the sanding blocks and tape sold by Eastwood that connects you your shop vac and is supposed to eliminate most of the dust from blocking. Here's to hoping THAT works!
Hello everyone, I’m reaching out to see if anyone has a set of SSWorxs flares for the S30 that they ended up not using and would be interested in selling or trading. I’d also be open to acquiring patterns if someone is willing to share or help out. I’m planning to weld on metal flares and really like this more squared-off (non-tapered) style. Thank you!
- Earlier
Hi, I'm trying to swap my rb20 head to rb26 camshafts. I noticed the hydraulic lifters have an oil hole on top for the cam lobe but solid lifters do not have the hole. Do rb26s have a different cam oiling design than the hydraulic rb20? Similar to how the L-series can have a drilled cam or an oil spraybar? Also are valve springs different from factory between hydraulic and solid lifter rb25s? Thank you
Fantastic! Excited to see how this project unfolds.
Really cool stuff....very nice. I like the "refurb" on the front crossmember, as well! 👍👍
76_280Z started following Has anybody used the CX racing turbo kit?
I want to turbo my 280z using the CXracing turbo kit that includes the turbo and intercooler, but I can't find much about it. Any help? Link:Turbo Intercooler Intake Manifold Kit for 75-78 280Z Fairlady Z L28 L28E Engine 500HP
Been a while since I posted any updates. Been moving along. For the Turbo car I decided to build my own wheels. Ill CNC machine the center sections myself and have the lips and barrels spun for me. I really like the old SSR RS8 wheels but finding them in the correct bolt pattern, offset, and caliper clearance is impossible. I fould a set close, from Japan and had them shipped over. Since this car uses Z31 hubs and such, the spacing is out much more than a standard Z so I need a bit more positive offset. I dissasembled the wheels and scanned the center section into my computer and reverse engineered the shape. Next I re-assembled them and had the 245-45-16 tires Im going to use mounted. I test fitted them to the car, and close, but not good enough. This is the fist time this chassis has been rolling on its own wheels in 27 years. Its been on a cart or a lift. Felt good to see some progress now that the suspension, brakes, and cross-memeber are finally complete Scanned this complete assembly and put it in CAD. Now I have the exact shape of the tire on the rim. Cool cross section of it. Finally I scanned the side of the car, put it into CAD. Now I can adjust my wheel center offset for caliper clearance, and adjust it to work with new Lips and Barrels I will order for the proper offset and fit to the car. Having it in CAD alowed me to look at it from every angle and check all clearances, for calipers, springs wheels lip, ect. Even compressing the suspension to make sure I have fender clearance at full travel Final wheel spec is: Rear - 5 lug = 245-45-16 on 8.5" width rim- 27mm positive offset, 2.25" outer lip on the rim Front - 5 lug = 245-45-16 on 8.5" width rim - 31mm positive offset 1.75" outer lip on the rim Next I need to find some time to program the CNC and start cutting chips. But I got distracted on the NA car, so that update is next.
At Harbor Freight they have carbon stipping discs for the angle grinder. It takes the paint off like nothing and does not damage the panels at all. it actually polishes the metal so don't forget to hit with some 80 grit to get the mechanical bond back. I also have the drum sander version from HF also and it strips paint like nothing!! https://www.harborfreight.com/4-12-in-non-woven-paint-and-strip-abrasive-wheel-70419.html great job on the progress!
Just from those photos, I'd say you've got an R180. The 200 has a much more "bulbous" carrier case and rear cover. This video does an quick and dirty job illustrating the differences and distinctions: https://www.google.com/search?q=identifying+r200+vs+r180+with+pictures&client=firefox-b-1-d&sca_esv=b960a84cc5c43ab2&ei=haU1afOCFb_m5NoPmuGuoAY&ved=0ahUKEwiz2Zen7auRAxU_M1kFHZqwC2QQ4dUDCBE&uact=5&oq=identifying+r200+vs+r180+with+pictures&gs_lp=Egxnd3Mtd2l6LXNlcnAiJmlkZW50aWZ5aW5nIHIyMDAgdnMgcjE4MCB3aXRoIHBpY3R1cmVzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigATIFECEYoAEyBRAhGKsCSOYbUNoGWOUZcAF4AJABAJgBdKAB5wqqAQQxMS40uAEDyAEA-AEBmAIPoAKQC8ICChAAGLADGNYEGEfCAgUQIRifBZgDAIgGAZAGApIHAzcuOKAH0zGyBwM2Lji4B4ELwgcIMC4yLjEyLjHIBz2ACAA&sclient=gws-wiz-serp#fpstate=ive&vld=cid:1284de3c,vid:s3egG-klPBg,st:1151 For a more detailed and in-depth discussion of the technical differences between differentials, see this Pinned post here: Just as an FYI -- you have posted in the "FAQs" section, which is typically reserved for posts of an informational/educational nature. Kind of like a repository, or library, of technical information. I would suggest moving this thread to the "Drivetrain" section down below: https://forums.hybridz.org/forum/11-drivetrain/. These sub-forums are intended for open and freeflowing discussions. You can move the thread yourself; or I can do it for you, if you prefer. Your choice. LMK if you need any help. Hope this answers your question. Cheers.
greetings: I have a 74' 260Z manual transmission. I'm not sure if it has R180 or an R200. attached pictures...thoughts?
OKGMC4 joined the community
12-06-2025. I have boxes and boxes of stuff I have bought for the car, and today was the day to start throwing all the stuff on and make some room back! First, I had the mobile welder stop by and weld my radiator support back in, and while here, I had a thick steel plate welded on to the top. It is stronger now than it ever was. Then it was time to start installing parts on the engine, getting the hood on, rear suspension back in and all 4 new wheels. I took the dash down from the rafters so I could start on it on very cold days indoors, and it is a lot heavier than I remember......I am going to swiss cheese the frame and lighten it up a bit......I don't need that weight! Pics:
do you have a part number or year for the Civic wiper motor? thank you!
Who's Online 0 Members, 0 Anonymous, 740 Guests (See full list)
