- Yesterday
IMSA GTU vintage racer build
It is just insane how many hours I have put into mounting the hatch. The simple things always take the longest. And I already had brackets fasteners from previous install. Had to fab up my own support strut setup. And I am still fine adjusting the entire thing so someone can remove and install quickly. - Last week
Anyone running a Schneider 270-60F-14? Questions about idle
juggernautjoee replied to juggernautjoee's topic in MegaSquirt
They never gave me an answer to exactly what idle vacuum I should be getting. Just a suggestion to open the lash a bit. I do not have any EGR remnants. I've sealed off the EGR plate and the bottom is plugged. I've bumped up my advance to 25 degrees in the idle range and can get a steady 16in of vacuum now at the same RPM. But obviously that doesn't leave a lot of room for me to advance the ignition through the load ranges. I've got a set of home-made detcans that I've been using to detect pinging/detonation. I advanced the ignition at idle up from 25 and didn't notice any difference of vacuum, but did notice some stumbling around 30 degrees. I can live with the 16in of vacuum at idle if -
Tach is struggling below 2,000rpm
BoostLee replied to Luzifer's topic in S30 Series - 240z, 260z, 280z
I had a lazy tach, and taking it out and disassembling it and cleaning it helped. -
Will do. I’m going to go with some wide wheels and tires up front, somewhere between 305s up to 325s. With all that rubber the power steering will be a huge help. -
10-09-2025, This morning I trial fitted the tight 90 turndown on the turbo, clearanced the boss on the head that was touching the turbo compressor housing, and then masked and painted the engine. Once dry I can then mask and paint the crank pulley. See pics:
4200 Progress, 10-08-2025: Finished the cleaning of the engine today, using a can of gas (not recommended) and an old toothbrush and a shop cloth to wipe it up, razor blade on gasketing surfaces and other spots as needed.......then I mocked up the turbo header and turbo.....yep, my turbo is a bit bigger than what was expected I guess. I can get some space with another flange stacked up with the aluminum plate gasket for the second one, will probably need to put a wrap of header tape just in that spot as well. Also have a small boss sticking out on the head touching the compressor housing. I can just carefully grind it down a tad for clearance. Big T-76 turbo sticks up there huh? Good thing I will run an intercooler huh?
Working on PCV again, I am going to try for the exhaust. My basic plan is, valve cover to stock pcv valve, to a catch can, then block to the catch can, catch can to the exhaust.
jeffer949 started following L28 Front sump conversion
Im building a l28et and im converting it to front sump. I've already drilled everything and I know what im doing there. Wanted to run how im sealing the oil galley off. I the picture you can see my new pickup hole and dipstick hole. I have already put a Welch plug to the left of the small hole and plugged the old pickup. Next im going to put the aluminum plug i made that has a npt plug inside of it between the new pickup and dipstick hole. When I tighten down the npt plug it will spread the outer wall of the aluminum plug and seal it off. I will theb back that up with another Welch plug. Im almost sure it will work but I wanted to get some more eyes on it to make aure. Because if it doesnt work. Ill suck air and take out the bearings. Any recommendations on a sealer I should use if any?
Today was a cold snap, but I managed to get a job done I have not been enthusiastic about doing..... removing the oil screw in plugs from the block. Metal plugs in an aluminum block and have been in there for 19 years. I had to use a pipe wrench, hammer, hex wrench, PB Blaster, a MAPP gas torch, and a cold chisel. I found that the cold chisel is the most effective at getting them loose and off, but it will take several cycles of PB blaster , spraying it where the bolt face touches the block and letting it seep in, and then MAPP gas (2000 degree F or close to it, maybe more) held around the bolt to heat up the aluminum and get it to expand, then hitting the head of the bolt a few times hard with the hammer, and then putting the chisel on an angle and beating on it with a hammer to shock it loose and turn it. These bolts are M16X1.5 thread, with the exception of the bolt facing the side at the oil filter. The bolt facing straight ahead is the same size, M16X1.5 but the one to the side where the sensor normally is..... is a coarse thread bolt, M16X2.0 thread. I have ordered brass plugs from Auto Meter to install into each port that are drilled and tapped with a 1/8 NPT center. I will put brass plugs in #1-3, #4 is for the oiling system re-route from the front facing port at the oil filter, number #5, the last port on the block at the very end is for Turbo oiling feed. The side port at the oil filter, the bolt will be drilled out in the center and tapped to 1/8 NPT so I can use it for an oil psi gauge. Sure feels good to have this done. In the pics you can see how the factory really gooped up the threads when they installed them. Pics follow. Cheers!
Mitchel0407 replied to FastFloridian's topic in S30 Series - 240z, 260z, 280z
I’m curious as to how the electric steering kit will hold up and what you think of it. No power steering isn’t that bad but it might be a nice upgrade down the line. Please keep us up to date once you have the car driving. -
You are 100% correct, thanks for pointing that out. You don’t know what you don’t know. The new steering kit lets you attach the u-joint in any configuration, I wasn’t even thinking there was a right and wrong way to install them. Quick google search and see what you mean and how to align them properly. Glad to be able to fix now, rather than find out later, love everyone’s help on this forum. -
Just looking at the picture that you posted of your steering shaft, it looks like the u-joints aren't phased correctly. It may be an optical illusion from the angle of the picture. -
I removed the cylinder head, N47, didn't find any torn pieces of the gasket. After ordering a new set of valve springs and valve seals from zcardepot, I took the head to the machine shop.
After several weeks of various distractions, I was able to commit a bunch of hours to working on the "track car" this weekend. I recently purchased some nice tools to make fabrication projects easier. Here are some pics of tools: And with those on hand, I was able to make a nice battery tray for the new Braille battery. The spot welder I bought several years ago was awesome to use as well. I, am very happy with how this part came out, even if it did take me about 9 hours to make it (!) I still have to design a battery clamp down mechanism to hold the battery to this new tray, so I will work on that soon. With the battery tray temporarily in place, I again mounted the dry sump tank, and started figuring out all the fittings I will need for the lines for the dry sump system. I plan to order those soon and then mock up some hoses.
Toiletduck34 joined the community
I worked on making the forms for the valve cover today. I can now use them as templates to cut them out of some 1/8" thick aluminum plate I got off of Amazon, and it should be here tomorrow. Also stuck the dip stick in a little bit to get an idea. It also comes with the oil pan and pickup. Lastly, I am getting ideas on alternator fitment.....pics.
- Earlier
Upgrading with a 8 1/2" Power Brake Booster Sorry for the delayed posting, I was doing renovations on my house. I am upgrading my 7 1/2"with a larger 8 !/2"Power Brake Booster. When I added the 8.8 Super Duty Differential Conversion, the Large Discs Brakes called for a Larger Brake Booster to be added. I bought the booster from Z Depot as my local parts supplies did not have in stock. Comparison Pics of the 7 1/2" and 8 1/2" Boosters As you see with these pics, the Mounting Lugs are spread out more than the old one. Roughly about 3/4" or 1 1/2" across. Luckly, the Brake Master Cylinder Assembly does not required disconnecting the brake lines. You can just loose the brake line mounts and Proportioning Valve Assembly. This will allow the removal of the old booster and room to install the new one. Now, plenty of room to work on the Booster Mounting Holes is available. However, I found that making the wider mounting holes would occur close to edge of the Brake Pedal Assembly on the opposite side of the Firewall. So instead of just putting large washers in would not be strong enough. So I decided I would remove the Brake Pedal Assembly and would weld up some steel plate on the pedal assembly to give it more strength. First, I made a Template for a Rubber Gasket behind the Booster Body. Then, Cut the gasket from a !/8" Flat Rubber Sheet. Masking tape applied on Rubber gasket material Test Fitting the Gasket. Rubber Gasket on Booster I decided that it was better to removed the Brake Pedal Assembly to work on it. So I had to remove the Steering Column and Electric Power Steering Motor together. So I constructed a 4 Foot x 1 x 1/2" Foot Plywood Platform so I could work easier than bending my back on the rocker panel. Also, to remove the Brake Pedal Assembly, there are Two 12mm short Hex bolts on the top of the assembly. To remove these bolts, you must remove the Tachometer to access these bolts. There is only a couple of inches of space above the bolts so 12mm Ratcheting wrench or small Ratchet is recommended. the Two Hidden Bolts 12mm Ratcheting Wrench aids bolt removal. Mig Welded 1/8" Steel Plate over the Mounting Holes to provide additional strength. Firewall View of Modified Pedal Bracket After Test Fitting the Pedal Assembly, I found the Clutch Master Cylinder was very close to the new Brake Booster. I was thinking that, in case, I needed to install a Larger Clutch Master for a Bigger Clutch, a Larger Master might be needed. So I decided to move the Clutch Master over while i got Pedal Assembly apart now. Next - Modifying the Pedal Assembly to move the Clutch Master over. -
10-04-2025. I got some more 4200 work done today. I installed the modified pickup that came with my T oil pan from Forever Fabrication, and then installed the oil pan. It came with new bolts, and I used Permatex Grey to seal it. After that I jumped on the valve cover. It is a common thing on 4200's to cut down the valve cover on if you want to use it in certain cars, as the height of the engine causes issues. You either cut a hole for it to poke through or cut it down. the 2006-2009 4200's have a cast aluminum valve cover, so pretty straight forward. Using my die grinder, I cut the top out and then ground most of the other stuff off I didn't want on the cover, and drilled the hole in the back for my oil fill. I picked up this sweet cap and threads on Amazon for under 10 bucks. So, after the initial cut I then used a marker and drew some lines for further cutting and then drilled small holes so when I took it off I could draw a pattern. as the pics show it took off a bit too much where the intake cam is.....but no worries, I kept some of the cut off aluminum, and can cut strips to put there it will all be welded in Next, I will use a cereal box to make forms for how I need to cut the plate aluminum, and get it all welded up, sanded down and off to polishing. Block is about 90% ready for paint, just more corner cleaning. Going to go ahead and paint the block silver....I don't want to be tied down to a color, a neutral color is best, and the silver makes it easy to just use a thin coat. I will also probably use clear engine paint over it to give it a little more pop. Pics follow.
Got the electric power steering installed. You have to the-use original shaft that ties into the steering rack, was a huge PIA to get out of the upper universal joint and into the new one. Got brake pads in, ordered some brake fluid. -
My photo album for the build is located here: https://photos.app.goo.gl/FEXaWgYEMedA2FJv9 My first project car is a 1973 Datsun 240Z. Like many cars, it was mostly stock with a lot of rust when I bought it around 5 years ago. I taught myself to weld and did all the rust repair. I replaced floorboards, frame rails, and many small patches in the fender wells. Then, I rebuilt the braking system and replaced numerous broken or rusted-out parts. Next, I re-gasketed the engine, drained the fuel tank, and cleaned the fuel system. I took the car down to bare metal and tried a DIY paint job. After that, I drove the car for about 3,000 miles around town and on a couple of road trips. I had my fair share of trouble. I had to replace a fuel pump, the alternator only puts out about 12.5 volts, and the wiring harness is starting to show its age, and the previous owners that created a rat's nest. Recently, I purchased another project car that came with a lot of parts and swapped them on. I added TTT coilovers all the way around, Arizona Z Car lower control arms front and rear, Arizona Z Car tie rods, upgraded front sway bar, new front valance, fender flares, and trimmed fenders for clearance, Watanabe wheels, and Toyo R888s (215 front and 235 rear.) I also cleaned up the interior a lot with new door cards and interior trim pieces. Recently, I replaced the billet diff mount with a new polyurethane one, fixed a lot of my early welding, did a full engine service, got the door handles working promptly, and modified the exhaust because it hung about four inches too low. After this, I put about another 2,000 miles on the car. All this work has the car in pretty good condition, but there are still a few things left to have a true daily driver quality car: 1.) Fix the exhaust. I got it tucked up nicely, but between my poor welding and previous owners, there are several leaks, and it sounds terrible. 2.) Rewire the car. I have the brake, reverse, and running lights working. However, I have never been able to get the turn signals to work, and the gauges work very seldomly. I have purchased a 21-circuit harness from EZ Wiring and will rewire the whole car in the next month or two. https://www.ezwiring.com/product-page/ez-wiring-21-standard-wiring-harness 3.) New gauges. EZ Wiring sells new gauage kits. I'm not sure if the 50-year-old gauges are broken or if the wiring harness is bad. So, I think I'm just going to replace the gauges with a set I know will work with the new harness. https://www.ezwiring.com/product-page/shark-mechanical-gauges 4.) Re-attach the skid plate. I had cut the plate off because the bolts were rusted and stuck in the car. I fixed the plate by welding some washers on the bolt holes, but I need to drill out all the old bolts and tap for new ones. I don't have the car lowered that much, so I'm not too concerned about it, but it would be a nice piece of mind. 5.) Alternator. Ever since I have owned the car, the alternator has not worked properly. Recently, I had the alternator rebuilt with quality parts and bench tested. I know it works, but the car is only putting out 12.5 volts when running. I have played with the wiring and got the alternator to put out 14 volts, but then you can smell the wires burning from too much juice. Like I said, there is a rat's nest from the previous owners. I am at least the fourth owner, but I don't have a full history of the car. I have an FSM, but the wiring guide no longer matches because of all the other owner's work. This is why I plan to replace the whole harness. I'm hoping the new harness with better relays with fix my charging issue. 6.) Alignment. After I put the new suspension on, I did a garage alignment, and it is pretty good, but I would like a professional to take a look. I have that scheduled for next week. 7.) New Dashboard. My current dashboard is pretty rough. It has several cracks and looks pretty bad. I have a newer, crackless dashboard. When I rewire the car, I'm hoping to swap the new one in and put some sound deadening behind the dash while I'm at it. I'll post my progress if anyone is interested, and I'm sure I will have a couple of questions. I know the last finishing touches take the most amount of time. I'll also answer any questions anyone has, but I'll warn you that I'm a hobbyist. My full-time job is as a lawyer, and I'm by no means the best mechanic in the world. My welding has also gotten a lot better, but it surely isn't that good. Thanks!
Novice Petrol Head changed their profile photo
Any of you guys have had a driveshaft made up. I need the name of a shop that does datsun driveshafts.
I am planning to fully restore the body, repaint and preform upgrades but I was hoping to al least enjoy the car a few seasons and to take it at a slower pace. If it is in any way possible I would like to keep the car for as long as I can. The S30 Z’s have and always will be THE dream car for me and now I’ve driven it for a bit the bug has only bit me harder. I would love to just throw a bunch of money at the car as I do have some reserves but those are supposed to help me at least the next 50 years. For a bit of background, I’m only 25 and my right leg got crush in a motorcycle accident about 3 years ago. I’m doing good now and am walking on both legs again but the question is for how long that will be the case. -
jhm replied to Mitchel0407's topic in S30 Series - 240z, 260z, 280z
Oh, that is so unfortunate -- sorry to hear about the rust and structural damage. I hope you are successful in the legal claims against the seller and auction company. Sadly, that is all too common on these old cars....it's quite rare to find one without those types of issues, especially in climates like yours. This project suddenly got a lot bigger; but it sounds like you are up to the challenge!
Who's Online 1 Member, 0 Anonymous, 1402 Guests (See full list)
