AK-Z
Everything posted by AK-Z
  1. I wouldn't worry, unless you drench it. people paint their IC all the time with stencils. Look at the sti rally car. just mist the paint on
  2. I would be interested, but I live in alaska. I'll probably fly down to AZ sometime in the summer, buy a Z and/or S13 (maybe 180SX) and drive it back up to Anch. Or ferry it/them up there from WA.
  3. uh.. I don't think that his car had a key'd filler cap, or else this wouldn't be any issue. not all 280zx came with that.
  4. If you say that. I say before anything, check the AFM and make sure that the connectors on it and to it are clean. Might be just an easy fix. Also try adjusting the distributor.
  5. I glued a magnet to mine. I use to do the same thing. After losing 2 gas caps, I decide to put a magnet on it and covered the contact area with felt. When I fill up, I just stick it next to the driver side door handle. Idk what I'm going to do, when I have my Z running , since its on the other side.
  6. So, this is going from the stock nissan R200 to the subaru R180? How difficult would you think it would be to put one in a datsun with a nissan R180? Great writeup BTW. EDIT: BTW how can you tell if an sti diff is lsd (i.e. ebay)?
  7. Hmmm. interesting. Also the S15 diff had the speedo sender on it instead of on the tranny. So you could use the S15 speedo gauge with it. Part of the reason why most people don't swap engines/trannys with a S15 SR20 w/ 6 speed.
  8. AK-Z
    1000hp G35
    Once they started talking, I couldn't stop laughing roflcopters
  9. Thats what I use to do, but my dog just started to be afraid of newspapers . She would refuses to do her business on paper now.
  10. Old wiring and copper corrosion. corrosion causes more electrical resistance on the wire, the amperage to spike (I'm not sure if thats how it works, but seems right ) then causes heat in the wire.
  11. Incorrect. If what you say is true, then I would check to see if there is a vacuum leak/clog somewhere. disconnect one of the vacuum lines and see if it idles better.
  12. I would go with the "rubberized bumper coating" version of the 3M spray. Seems to be a lot more stiffer than the undercoating labled version.
  13. Wow, rough. But seems to be a lot better off than my car
  14. They won't. as soon as something funny happens, someone's going to complain and then they won't do it again. A couple more sequences like that and then it will be as bland as toast. I hate it when people complain.... guess I'm a hypocrite lol
  15. I would just make a separate x member just for the engine mounts and hack off the engine mounts on the original x member so they don't get in the way. IDK toyota engines well, just realized that you might have clearance issues with the oil pan
  16. He seems to be wanting to work with you. So I say, go by what he says that he's going to do to make it right. Metallics can be tricky. If you're not consistent with the gun angle when spraying, it can also also cause striping (more like the metallic doesn't relect evenly )
  17. I wish I had SPACE and a WARM garage <_< Winter just freezes everything for me BTW where do I get some of those arms? I can't reuse my mounts
  18. I always that it was Tiff Neddle for some reason . But watching the "original" Top Gear and Fifth Gear, Tiff seems to be the type that always needs to talk to someone.
  19. Contact Apple Steve Jobs will tear him a new one lol
  20. Dude. you need to get up and start doing something with your car lol
  21. hobo gangsta w/ ejection seat fo yo b*tch
  22. I've got a Chihuahua sheds like crazy, but one of the best dogs I've had. With small dogs, you "have" to spank them to make them behave, or else they will get territorial around strangers. That is why chihuahuas a notorious about being mean, the owners are afraid of spanking their tiny dog. You have to make it clear that YOU are pack leaders
  23. Are you sure? That is the whole reason why they came out with the whole MIMO tech (multiple in, multiple out). As far as blocking ports, it won't stop them from downloading, it will just slow it down. Most, if not all, torrent programs will going in NAT mode, which means the program can't get efficient traffic because its behind a firewall (blocked port).
  24. Your niece wants to come out kicking and screaming Just had to say it to lighten the mood. Adding more stress to an already stressful situation is never good. try to lighten the mood when talking to your sister.
  25. I'm not going to say how things should be done, but thats borderlines on harassment. It may be considered net bullying in some perspectives. Not saying you should or shouldn't do it, just a word of caution. And if I was a admin of a forum and more than (a set number of people) complained about it, I would have to "ban" him. I would feel bad about doing so, but it would need to be done; I wouldn't stop him from joining under another alias though, as long as he didn't do it again EDIT: Have you tried contacting ebay directly? They can lock his account or any accounts associated with the IP addresses used.
