madkaw
    27
Everything posted by madkaw
  1. Actually that is incorrect . The P79 is the head with liners and has similar combustion chamber to the P90. N47 head is usually close to the bottom on preferred heads . Removing liners should be last resort . There have been successful turbo builds with liners , but the liners were better installed on later model heads - p79 and Maxima N47.
  2. General rule is the liners are bad for turbo charging . You could just run a small amount of pressure on the L24 /88. They aren’t that high of CR. 300HP is a nice goal , but maybe just go for 200+ and get your feet wet learning these motors . Learn on your first motor and invest bigger $$ when your knowledge gets better
  3. Did a dyno run today . 226 HP and 226 torque . pretty happy considering I’m running a stock N42 intake .
  4. So it’s optimal at 9k - so that doesn’t mean you build an engine around them. I’m quite sure they are very efficient below that . What ID are they? Start shopping for a billet crank at 3500$ plus and then throw in another 10k on the engine build and you might get there
  5. I’d bet that head has been cut , maybe not . Wouldn’t be very stellar CR - but maybe over 8:1
  6. Do it . Hell - go to #3 . I suggested to my buddy to do his in his 78. It is tired motor too. He was surprised how much a difference it made . It should give you a bump in CR .
  7. I have a knock sensor module installed , but have yet to use it . My max CR is 10.5:1 and we have 93 octane here . I have a N42 block so there is no knock sensor hole in the block , so I need to come up with an alternative . Currently running 35 timing , but have ran as much as 37 degrees .
  8. 3.90 gears and about 7200 rpm shifts . 8B4867CC-29D6-428F-A1D7-5F72482973E3.MP4
  9. It’s hard to figure your goals . The L motor can handle about any rpm range . The torque allows for lugging along just fine and cruise at 3500 also . 3.90 is nice for getting up to speed quickly . These cars are 50 years old and keeping up with fast highway speed there is other considerations besides just rpms. Noise, stability , aerodynamics. The 71C would be worth the effort because it’s a better trans and rebuilt parts are more plentiful . It’s a stronger transmission period.
  10. The automatics - some of them- had 3.54 gears and it was 3500rpm at 70. These engines like a cruise at 3k , it won’t hurt it . I have very close to your scenario with a 3.90 gears from a subbie. If you have a little higher rpm cam it would be nice . 3.70 is a nice compromise , but not the easiest gear set to find . There’s a drone zone for some Z’s I’m that 2500 rpm range
  11. madkaw
    Ms3x install
    Not 100% that this was necessarily a fix , still tuning . When I searched on EFI support the recommendations had changed to 4ms for the D-585 coils. Someone actually got the GM dwell tables and copied them . Another guy came up with 3.7ms based on GM tables . Anyways MSextra recommends 4
  12. So a cup that slipped over the output shaft ?
  13. I tried that laser deal, but didn’t get the right laser and didn’t have a precise mounting jig for the trans . I think I trust my angle reader , but it doesn’t verify if the there’s a lateral issue .
  14. Well it’s harder to get an appointment with a dyno than my doctor . I’m booked out to November . Business is good enough that most shops don’t want to give up there dyno to walk ins , they have so much in house projects . It’s all corvettes and Mustangs , etc.. I did upgrade my injectors to 42 lbs and re-tuned with success. Did another 4.77 split , so happy . Might play with valve timing a little to get more top end, but I think I’m at the end with the N42 intake . My buddy is converting a diesel intake for me to run EFi . I’ll go from 31mm runners to 35mm and looonger runners . It will be interesting .
  15. madkaw
    Ms3x install
    Well the new flywheel worked out well . I also bumped up my injector size to 42lb Bosch’s. Made the change in fuel requirement and it fired right up and idled well. Drove it around for about an hours and let Tuner Analyze do it’s thing . Most cells were a bit rich, but not off a bunch . Now I won’t have to worry about pushing my 26lb injectors to their limit . I even did a 0-60 time to verify tune and it was the same exact time down to the 100th second 4.77
  16. I guess it also depends on what the builder decides is the safe minimum wall thickness too! Maybe Dave pushes the envelope or is basing it on his experience . I told him I would be pressurizing , but it would be lower psi , higher CR build if anything . Maybe I just got lucky
  17. I am currently converting a diesel intake for my 3.2 . Be curious how it will run with those long runners . If anything , it will look beautiful on there - lol. It will be on the other end of the spectrum of my N42 intake
  18. Rust that needs chipped away ? Are diesels more plentiful over there ? Very cool project
  19. Well- NA or turbo ? Keeping the dished pistons or going flat ?. Purpose of build , rebuild for stock EFi or modified ? Budget? Power goals ?
  20. The junk yards have them , but you got to dig deep
