madkaw
    27
Everything posted by madkaw
  1. I have a n42 ready to install and it will be NA motor. MS3x already installed , just need to swap out . The hardest part will be saying good bye to my Mikunis
  2. Its easier horse power vs. installing a new programmable ECU . Most guys opt to throw triples on then bigger injectors and a method to tune them. In the end the cost probably even out , and even the learning curve for some might be the same. Myself- I am about ready to do away with carbs and go for power the other route. There isn't that many builds here that I have read that go for NA FI power with a programmable ECU . Most stuff is turbo style
  3. So you were running how much CR and wanted how much boost? Seems that the n47 head might be first issue. Why that head ?
  4. It actually ran pretty decent with no noises . The chain was eating into the tensioner , plus it as stretching . Engine had less than 100k. Obvious lack of oil changes didn't help.
  5. So what do you think was happening with the valve timing on this motor !
  6. Here some pics of the stock sway bar in relation to the pump. The car is off the ground. So does this look like stock position for your bar? If the stock bar doesn't sit right ,then the bigger one won't and I have other issues. The one bolt from the oil pump hangs over the back half of the bar diameter. Stock spring perches with ST lowering springs
  7. That's what I did- 1/2" . My point here is that it is advertised as a bolt on sway bar - NO MODS. So what if I had not noticed the bar laying on the oil pump at droop and when it was on the ground it cleared. I'm thinking I'm good until either I hear it banging or it takes out the oil pump . Don't want anyone falling into this mess if ST didn't put the kit together correctly. Or if I'm just doing something dumb, I want to know.
  8. Thanks for the feedback guys. Again I ask how the engine mounts could affect this other than failure . I measured thickness of mine compared to brand new Nissan mounts on a 72 I am redoing. if the end links were taller - yes that would help- but pretty tall already. My plan today- if I have time - is to pull the sway bar and lay it next to the stock bar. It seems to me that the bends are not at the right angles - especially for the end links. These sway bars are hand bent , so always room for error.
  9. For what? The mounts look solid and the front end isn't falling off. I could see how someone could miss this issue if they install this bar. Might not see the bar hitting the one bolt on the pump while its jacked up and then when on the ground the bar twists and clears the bar
  10. If I had a place, I would take it for the head and trans
  11. Actually it's a 1" bar and I contacted ST and sent them pics and dimensions of the sway bar and they say the dimensions are correct. So why am I having to run a spacer . They want more pics of sway bar and any mods to car. So what mods would affect the clearance ?
  12. New ST kit and the 1 1/8" front bar under full droop ( jacked off ground) hits the oil pump bolt pretty hard . It took about 7/16" worth of spacers to clear the bolt by 1/8" . Seems wrong to me. I know full droop would be basically airborne , but worst case scenario it seems that the bar would smack the oil pump pretty dam hard . Feedback please . Let me add that weight on the wheels and clearance grows to 1/2"
  13. Called Futofab and verified play in axle. More than necessary for our cars , but shouldn't negatively affect anything . Also questioned the torque requirement on the bolts and he said he will revisit this. 35lbs is too much for 8mm bolts.
  14. You can buy them new all day long for cheap also
  15. I figured it out a long time ago. Glad to see someone carried the torch on this. Good work!!
  16. Get the AFM in there very first thing to see if your not way lean or something . Plugs look okay?
  17. I have read that putting a rear sway bar on does not improve handling- even make it worse if using the stock front bar. I have not found much info on it searching in general. There's not even much to read that is subjective. Love to see some testing done at an autocross from an experienced driver . So many factors involved between shocks , springs , etc...
  18. There are clips on the very ends . After I thought about it - I figured they couldn't move once torque was applied to the splines . Wasn't a big fan of the Allen heads and trying to get 35lbs or torque on them. Had 2 bolt heads strip out. I know their tight I guess . Now the safety wire job- this ought to be time consuming :0
  19. Got some clearance by shortening bushing. Question regarding axles. With everything mounted on I can grab the shaft and slide it back and forth enough to hear it banging the adapters - is that normal ?
  20. Even if I increased my bar up front?
  21. Shouldn't it clear from any position?
