madkaw
    28
Everything posted by madkaw
  1. Might as well do both ignition and fuel . It's a steep learning curve but it will click if you keep reading. There's lots of reading on this site under the MS section. . Some shy away from ignition but I did it first. Getting ready to do fuel myself. You need to get a direction of where your heading and then come up with specific questions
  2. When you say this mod has been effective - are you saying that you couldn't run this much boost or timing before this mod ?
  3. madkaw
    Ms3x install
    On the subject of venting tank. The original system of the flow valve on the inner fender seemed to work well enough. I was actually thinking of running a (new ) vent line from the tank to the same old valve and connecting it the same way. I'm going to run a CAI so there will be plenty of places to plug a line in. On the subject of fueling: Getting really close to starting up as a FI motor. I cleaned up the intake real well after grinding out the "bumps" in the runners left by the casting . I also need to science out my PCV system . After seeing all the oil inside this N42 intake and my experience using a catch can- I think it's warranted to put the catch cam in the PCV run. As I get closer to getting the final pieces together I realize I still have more to do. This is now the time to change over my thermostat housing to accomadate the GM sensor. I have a 81 housing that has 5 holes ! I only need two right now, but I'll have options . For now I will run the stock sensor for my stock gauge and the MS sensor will be right beside it. I will plug the other holes .
  4. Might want to read up on the whole p79 shave/swap - I think your skipping some steps or leaving out some stuff. I think you need to shim for that .080
  5. It's about the same work, but your not taking .080 off the head so no chain issue . You have to swap out all valves on the 79 if you take .080 out, but the MN would just be intake seats and valves .
  6. I'd take it but I have too many now. Let me know if there's anything I could possibly trade for it:)
  7. There easier to find than you think. Just look at sites selling used car parts . There's old Maxima's engines laying around. Usually cheaper than sourcing a z head .
  8. My approach will be a MN47 head on a 54 block. At 39cc stock, no shaving required. You could put larger seats on the intake and run your 47 valves - done . It might have too much pop and need MS to keep it under control. Just another option
  9. Looks like you picked one already that should be pretty good for your goals.
  10. Sounds like a good plan. Build your 31 head and don't be shy about the cam, it will still drive good and idle fine with that cam. I'd shave down the head to about 39cc or less if you get 91 octane . And yes to bigger valves - intake and exhaust .
  11. I didn't want to mess with resistors - pulse width , ect... Just hook up injectors and done. Change out pintles so you can use 14mm and you can pick from countless domestics for cheap
  12. I hope Zedd Findings rear valence panel is better than the one that MSA used to sell. I would personally think about splicing in a new cutout before replacing complete panel . The deal with the panel I got was it wasn't formed quite right and it was like 16 gauge metal- terrible to try and form. That rear panel is actually a compound curve . I'd try and find a donor
  13. Get some high impedance Boschs off of any domestic or get some new ones. I ordered new Boschs for about 39$ each or something around that cost . I got 270cc I believe
  14. Intake ports notched for injectors . Little wider than stock, but within limits of the gasket . Drilled holes are tapped . Got my seals back in and a quick valve lap and installed valves back in head.
  15. Head is back from the machinist with a fresh cut. CC the head and came up with 37cc , so I should be around 10.5:1 now . Need to finish cleaning up things and putting some new stem seals on.
  16. Drilling the head at home was a bit of a challenge . I think I got'er done though. Notched for injectors and a fresh cut on the head and I should be in business
  17. I think you should stay away from sequential right now . It's more learning for not much gain. Find some easy way to get your timing right by using MS only and go from there.
  18. Might make starts a little easier - though the MS primes every time before start anyhow. Having fuel everywhere in the fuel system keeps things a wee bit cooler also . Keep things from vapor locking
  19. Sorry for the delay answering- I've kind of let this thread slip. No surge tank, just Tank Inc set up. That's the one thing I wanted to avoid was running two pumps. I finally pressure checked everything. Turn pump on-see leak-turn off pump-fix leak-turn on pump-see leak-ect... In haste I left some Swageloks a little loose, and had to add some Teflon in other areas. When I finally had all the leaks fixed I noticed after shutting off pump pressure would drop to 0 fast-WTF! It then dawned on me I had no check valve in the system-oops. Ordered an inline check valve from Summit. Lucky for me I timed all this while the wife was out of town, because the house smelled like one big gas can ;-o Next step is to throw the head on-but I don't have one ready and my MN47 is under the knife. I am really hurting for time and place to work since in process of building a shop. Quick plan is to convert the E88 for FI. Need to drill for bolts and notch and should be good to go. Of course easier said- than done. Have to make a jig to drill the head. If you look at the head there is no real square surface to sit on a drill press. Bolting L brackets to head surface so I can lay her on her side and drill holes. PITA since I have a puny drill press with very little table surface.
  20. A guy I work with keeps me up on the latest as far as newer engines ( I'm stuck in the dark ages of Datsun), but he was telling me about this particular engine. A simple head swap and other stuff and you get a screamer NA motor ! Sounded like it was pretty easy to get 300 NA. I guess I need to crawl out of my cave- lol
  21. So why was it lean? Didn't you have the mixture wheels close to same adjustment ?
  22. Whatever you are searching just include Hybridz in the title or phrase
  23. Another thing to check. I once had problems with the Float bowl to nozzle rubber lines collapsing under heat. They were collapsing at the bend . I could actually reach under there after the engine was warm and feel a flat spot in the hose. This cut off fuel flow to the carbs
  24. Haven't ran the pressurized version of the Mikunis , but I would agree that I would drop the main air down a couple of sizes and maybe even bump up the pilot one size . Maybe too much fuel but better than too little
  25. On my P79 head I was considering drilling into coolant passage between 5&6 and tapping it for the sensor
