Michael
    7
Everything posted by Michael
  1. I've also heard that starters of Type 1 above are less reliable, because the starter gear is cantilevered. Can't confirm that from experience, though. One advantage of starters of type 1 is that some models have adjustable orientation; the motor casing can be rotated relative to the rectangular mounting block, allowing for adjustment of header clearance.
  2. Recently I built a custom nose-piece for my '78 280Z, integrating the headlights and radiator upper-support. I used polyester resin and cheap fiberglass cloth, both available from home improvement or generic autoparts stores; also, plywood ribs and foam between the ribs, with aluminum glassed-in here and there for hard-points. In functionality it's similar to a G-nose, but it's much shorter and follows a different philosophy. From that experience, for my next trick I'd like to build a custom hood. It has a slight bulge to accommodate a standard 14â€-diameter, 3"-high air cleaner atop the big-block. [with a Performer RPM intake, BBC’s are too tall to use the stock Z hood]. Again I'm using plywood ribs and wood stringers. The framing is coming out pleasingly, but I am concerned about underhood heat. The fiberglass cloth should be OK, but conventional polyester resin, as well as similar 2-part epoxies, would soften and possibly melt. So here's my question: any advice on brands/methods/retailers for high-temperature epoxy or polyester resin? I'm not expecting something that would survive a direct flame, but good stability at 250 deg F would be nice. I also plan to use a heat-insulating glue-on blanket, of the type used to wrap starters to prevent heat-soak. BTW, a search such as http://forums.hybridz.org/showthread.php?t=83659&highlight=epoxy+high+temperature is pretty much a dead end, but I vaguely recall discussions on this topic some years ago.
  3. My 1991 Corolla (rest in peace!) had a 1.6L 4-cylinder with 16 valves, but SOHC
  4. I'm one of the victims of the BBC cam lobe wipe problem. It happened to me with a very mild hydraulic roller from Comp Cams, DESPITE following proper break-in procedure. Since then I've learned of lots of people having trouble specifically with Comps Cams hydraulic flat-tappet cams. The other day I spoke with an engine builder who flat-out said that he no longer trusts Comps' off-the-shelf build quality (he says that their custom grinds are still OK). In the new iteration of my engine, I've got a Milodon high-volume oil pump and a Hamburger 8-qt pan with windage screen. However, the only oil-system mod that I made was radiusing the oil passage in the rear main cap - I didn't make any mods to the lifter bores, and now that the short block is assembled, it's too late. Crank main tolerances are quite loose, at least by Pyro's recommendations: 0.0025". I am going with a mechanical roller cam, partially because I want to hedge my bets on the cam-wiping issue. I'm getting top-of-the-line roller lifters and a custom-ground cam from Isky. The required valve spring pressure worries me a little, though; about 200 seat pressure, 500 open.
  5. I'd go with mechanical. They're harder to plumb, but are more reliable; no worries about a broken sender unit or poor electrical connection. BTW some years ago there was a thread on the accuracy of Autometer water temp gauges. As I recall, they can be off by some 10 degrees at room-temperature boiling point (212 deg F). I ended up with mechanical temperature and oil pressure gauges from Suntune (sp?) - from Pep Boys. Yes, they're cheap and cheezy-looking, but they are full-sweep and the water temperature gauge is dead-on accurate.
  6. Even with a brand new bushing set, thorough cleaning of the strut casting and sanding of the spindle pins, and liberal use of anti-seize lubricant, I found the "installation" of the spindle pin by hammering to be impossible. Eventually I used a hydraulic press, and with much creaking and moaning, the spindle pin finally seated. Indexing for the lockpin was comparatively easy, as the interference fit was much tighter in the A-arm bushing than in the casting, so that the casting could rotate relatively free. Definitely a poor design, and the most unpleasant mechanical repair on the Z.
  7. Project_BBZ, any updates? I still haven't decided on the heads, but am leaning toward the Brodix Race-Rites. Aluminum is important to me (more a personal preference than a rigorous engineering judgment), and small-port BBC head choices in aluminum are quite limited. Cam choice is shaping up to be a custom-grind from Cam Motion, or a very similar (both are mechanical roller) cam from Comp Cams, PN 11-770-8, XR274R series. I might use Comp Cams "beehive" springs, PN 26120
  8. Never mind the styling – I’m just disappointed that this thing is so heavy. Muscle cars were never particularly light, but they were lighter than “full size†sedans and wagons. And now the so-called muscle cars are themselves the largest passenger cars in the fleet. The same thing happened to the Mustang – weight kept creeping up in the 1990’s, and now lard has been piled extra-high for the new generation model. But at least Chrysler and Ford have SOMETHING that’s RWD and “moderately pricedâ€, bloated as it may be. GM still doesn’t have a RWD car, unless you count the Corvette and some Cadillacs.
  9. Mikelly makes an excellent point – if you’re going to spend $25K on a Z restification, to bring it up to (say) comparable performance levels to those of a modified C5 Corvette, why not just get the Corvette? However, considerations of “am I getting a good deal†and “am I buying the right parts†– which make or break any project – apply to both the Z and the Vette. Here’s what I mean…. First, the $25K modified Corvette figure makes two assumptions: that you have enough skill as wheeler-and-dealer to find a suitably-priced, good-condition specimen; and you have enough skill to select and install the performance add-on parts yourself. Well, the latter might be easy, but I would argue that if you can get a $20K 1999 Corvette in GOOD CONDITION, you probably have good enough street-smarts to score a comparably good deal on a Z – thus reducing the cost of a HybridZ from that of the above-posted estimates. I mean, apples to apples! You could just as easily spend $30K on a Vette with an engine that’s about to blow, a slipping clutch, dinged bodywork and shoddy electricals. Second, the Corvette is a heavy car with a long wheelbase. Sure, the handling might be great, and extensive mods might be required to the Z to achieve comparable performance. But the dartiness, the “tossability†that comes from a light car on a short wheelbase is very difficult to beat! In this sense, the Chevy CHEVETTE handles better than the Corvette. Third, the cost of making mistakes with the Corvette is higher. Remember, the real cost of a V8 Z swap isn’t in the parts that go into the car – it’s the parts that don’t fit, don’t work, or break, or are mismatched. Compare the costs of a cracked junkyard 350 block from a Caprice, vs. a cracked LS1 in the Vette! Fourth, the Corvette will always scream, “high performanceâ€, whereas the Z can remain somewhat subdued. That’s important in terms of insurance costs, attracting police attention, unwanted street racers, and so forth. And fifth, the Z swap is emotionally more satisfying, in the sense of an achievement of personal craftsmanship. The real apples-to-apples comparison is not 1972 240Z vs. 1999 C5 vette, but 1972Z vs. 1972 C3 Vette. Now compare the costs, the relative performance levels, and the mods involved!
  10. I have a 454 in my 78 280Z. It was A LOT of work, but my “swap†erred on the side of excess, in terms of structural rigidity and weight distribution. BBCs have a declining aftermarket support, especially for the middle of the road that’s neither all-out racing engines nor stocker muscle car restorations. In contrast, the aftermarket offers good options for 400+ cubic-inch SBC builds. The principal reason to build a big-block Datsun is that you’re personally familiar with the BBC engine, and prefer to work on it rather than the SBC. Then do the BBC swap – you’ll enjoy the car more. If you are starting with a clean slate, and especially if you’re inexperienced with Chevy engines, I can not recommend the big block. For an all-out drag car the BBC is an interesting option is you’re interested in 600+ cubic inches and 4-digit horsepower with nitrous. But I don’t think that there are any such cars on this board. The most powerful belonged to a member named Ron Jones. He had, if I recall correctly, a 502 making about 800 hp, good for 8.6 in the 1/4-mile. There are (or were) about 4-6 BBC Z’s on HybridZ. One belongs to Brad Barkley (Ratsun), one is the “blown blue Z†which is since been re-converted to SBC, one belongs to Corzette, one was a work-in-progress posted by a recently-joined member who decided to build a BBF instead. To my knowledge, all of the successful drag BBC Z’s are back-halved. Mine has the firewall set 6.25†aft and what some people might consider a tube frame, but the suspension is essentially stock. All of the BBC cars have some form of automatic transmission, typically a Powerglide or TH400. Mine is the sole exception (as far as I know) – a Doug Nash 5-speed. Bottom line – if you’re particularly enamored of BBC’s do the BBC swap; otherwise don’t. If you don’t have an engine yet, go SBC instead.
  11. Mike, just be wary of the 0.120â€. Much of that tubing is only around 0.118’, and if your race sanctioning body requires >0.120†tube thickness, a persnickety tech inspector might fail you. I went with 0.134†in the critical areas, just to make sure.
  12. Most things that we do, we do because we’re told to, or because we feel compelled to. Most things that we do for amusement and recreation are silly and soon forgotten. Unless they get us into trouble. Accomplishments? Like what? Cars rust, houses rot, fortunes crumble, muscles turn to flab. One thing that’s starting to become clear for me – and this Z project is contributing to the clarity – is that goals can be grouped into two halfs: those that can’t be achieved, and those that aren’t worth achieving.
  13. ‘Baddriver’ has an excellent summary of the cost picture!!! It answers, in a nutshell, the basic question of “how much does it cost to do a bare-bones conversionâ€. The answer is: if you already have your Z, and it runs OK, and you’re reasonably happy with the ride quality and the aesthetics and the suspension and the brakes, and so forth – and NOW you want to do the conversion, but for a “daily driver†that will have no particular place or purpose at the track – well then, the typical cost of “just the conversion†will evidently be around $4K. Another curious observation – if you pay a professional to do specific jobs (not the whole conversion, but merely specific parts thereof) – typically, you’ll pay about the same for the professional’s work, as you would for doing it yourself + buying the tools + buying the wrong parts + breaking things + starting over and trying again. Of course, that’s assuming that you’re not a mechanic and that the professional is honest. On my car, nearly everything that I built is hamfisted garbage. And nearly everything that the professional built is elegant and functional. If only I realized that 5 years ago...
  14. Car $600 Roll cage/frame $2000 Engine mounts, etc. $500 Firewall relocation $1000 Brakes replumbing $300 Radiator relocation $300 Fuel cell install $200 Fuel cell $200 Seat and misc install $400 Other welding $300 Engine $800 Shortblock rebuild $1300 Intake, carb, etc. $500 Exhaust $400 Suspension $300 Transmission $700 Clutch hydro $250 Clutch assy $300 Flywheel $300 Bellhousing $350 Seat $150 Belts $150 Bodywork (ghetto) $200 Electrical $100 Oil pan and pump $300 Plumbing $100 That adds up to $12K – give or take. The car is “rust freeâ€, but hardly attractive. It does have a brutal roll cage, though. Broken, obsolete, incorrect or dead-end parts: about $2000 Still necessary for engine†Heads $2500 Cam $400 Lifters $400 Rockers $300 Pushrods $100
  15. Some good points made above, but that doesn’t assuage my frustration.... The trouble with crate or OEM big-blocks is that they’re towards one or the other extreme: 3500-rpm truck engines that don’t make much more torque, let alone horsepower, than a mild 406 SBC; or radical race-only engines with 13:1 compression and 360 cc rectangular-port heads. Have you ever seen a crate BBC with a flywheel? Well, it if comes with a flexplate, and (I dare say) ALL of them do, and the crank is externally balanced, often the right way to rebalance the engine is to pull the crank, take the whole rotating assembly to the machine shop, and reassemble the short block. But if you’re going to do that, what’s the point of buying a crate engine? You’ve just disassembled what you paid someone to assemble for you! So what about starting with a crate short-block, say a Gen VI 502 from GMPP, and adding your own heads and valvetrain? Great, except that chances are that the piston dome volume is all wrong. Options are: angle-mill the heads to deal with the BBC’s monster 119-122 cc combustion chambers; run a mild cam; run a big cam but end up with inadequate DCR; or rip apart the short block and get pistons with larger domes (see above). So what’s the right dome size? It depends, of course, but for a stock-stroke 454 with 119cc combustion chambers and a mid-0.6†lift roller cam, it dome volume comes out to around +25cc. Ever seen a crate shortblock with a 25cc dome piston? Oh yeah, and then there’s piston to valve clearance issues. Bottom line, THERE’S NO GOOD SOLUTION! The BBC world has split into 3 camps: muscle-car restoration with nearly stock engines, trucks with nearly stock engines, and dragsters. Building a street-performance BBC (about 1.1 hp per cubic inch) isn’t getting any easier, despite the superficial appearance of lots of new aftermarket parts!!! Don’t believe me? Call up AFR, Pro Topline or Dart, and ask them about their oval port heads. Listen to the laugh at the other end of the line.
  16. If it’s not street-legal according to your state’s DMV, then it can’t be a street car... but that doesn’t necessarily make it a race car. If it’s entered in organized motorsports competition on sanctioned tracks, then it’s a race car... but it could still be a street car. Just because your car is too unreliable, too rough and too temperamental to survive a 300 mile drive on public roads, doesn’t necessarily make it a race car – it could just be a beater! And what if you started building a dedicated “race carâ€, only to later realize that it’s not legal for competition in any class in which it would be competitive? This often happens to V8 Datsuns. The car might have “race-car-like†performance, but it’s technically not a race car – street-legal or otherwise. Then there’s Hot Rod Magazine’s definition of “street carâ€. It seems that if you rip out the carpeting and don’t replace it, then it’s no longer a street car. But it’s OK to run on drag slicks, provided that they’re DOT approved. Go figure… Hey, while my car is still under construction, it’s a race car. But if I get it running, and its performance turns out to be disappointing, I’ll go around saying that it’s only a street car.
  17. As seen above, the general reply to such questions: Get the JTR manual, do a search, study the posts, and only then start asking targeted questions. But I would like to add this: while there are many excellent reasons for doing a V8 swap in the Z, please keep in mind that it's a major undertaking, even with what on first blush appears to be a "bare bones" swap program. Unless your dad has the desire and the skills to guide you step-by-step through the program, or unless you're a mechanic-in-training yourself, the cost/benefit ratio of a swap in your circumstances probably isn't favorable. Yes, there are exceptions; but they're just that - exceptions. So perhaps under the circumstances the best approach is to wait, and postpone the swap until some years down the road, when you have a reliable daily driver, a garage of your own, and so forth.
  18. Not to be too abrasive, but I’d opine that this falls into the category of “if you have to ask, you probably can’t afford it or can’t do itâ€. In other words, tube-chassis cars should only be built by people who have built such cars before, or by their apprentices. For aggressive mods to truly be worthwhile (as opposed to exercises in creativity, to phrase it politely), tremendous work and experience is required to get the details right. As a rough guess, getting the chassis (structure, suspension, drivetrain mounts, body mounts, systems integration) right would take a pro about 500 hours. At $100/hr, that’s $50,000 – body work not included. Also consider that with mods that extensive, it really doesn’t matter which car is used as the foundation of your project. It could be a Z, or a Porsche, or a Pinto.... ....So, if I had a deep desire for a full tube-chassis car (and at one point I did), I’d buy a used GT1 race car (never mind the make), which has been retired because class rules changed and it’s no longer legal.
  19. I'm working on it (454 in a '78 280Z)
  20. Could some one please post links to sites featuring Honda Civics that have been converted to RWD? An 800 hp engine just cries out for such a conversion. Im sure that some one has done this before. Unless... would a RWD conversion violate the Honda religion?
  21. I’ll straddle the middle between the ebullient optimists and somber pessimists. Yes, it CAN be done in reasonable time with a reasonable budget. But it’s very easy to get carried away, to allow the project to spiral out of control, and to end up with years and years down the drain and nothing to show for it. First, costs. Costs will vary enormously depending on your skills and luck with “wheeling and dealingâ€. Example: Awd92gsx says that he scored a 1977 donor Chevrolet with 350 engine, evidently in running condition. That’s the engine, transmission, accessories, and all sorts of “nickel and dime items†all in one package, for $500. If you can find deals like that, your budget could be quite reasonable. But that’s a big IF!!! And, you have to be satisfied with the constraints of your purchase (in this case, the automatic transmission that came with the car). Personally, I have more than $500 just in the bellhousing, flywheel, clutch and throwout bearing in my car – in fact, it’s around $1000. Second, skills. Theoretical knowledge is great, and it’s too often deprecated by shadetree mechanics. In doing a relatively basic swap, of the type that you propose, the main area where practical knowledge is so precious isn’t the swap process itself, or even custom fabrication, but familiarity with the donor engine. Things like setting the timing, tuning the carburetor, and so forth – elementary, perhaps – but essential. And the JTR book won’t explain them. Third, time and resources. Even if you have access to a garage and spare money, finish your university degree first, then worry about a Hybrid Z. So here is a suggested plan: (1) see item 3 above; (2) buy a decent, inexpensive donor vehicle, and drive that vehicle for a while; (3) constantly be on the lookout for Datsuns. As you already know, Datsuns are next to extinct in the midsection of North America, and Ontario is no exception. By the way, I’ll be in Ottawa next month (doing some research at NRC).
  22. I don't think that we have enough modified Z vs. motorcycle threads. No, really! OK, how about this: 632 cubic inch BBC Z (figure ~700 hp), tubbed - vs. Hayabusa. Standing-start 1/4 mile. Who wins?
  23. Pondering the price difference between the aftermarket aluminum block (about $4000, from what I’ve seen) and a stock cast-iron block... Even with torque-plate honing, align-boring and decking, the stock block comes to under $1000. Of course, it won’t go past 4.310 bore (typically), or accommodate beyond 4.25†stroke. But the price difference is still huge. HOWEVER, the heads, cam, valvetrain, oil system, intake, exhaust, and so forth are essentially the same price, because they’re essentially the same parts! Those $2700 heads become $2100 heads, for example. Now the cumulative price difference isn't all that huge any more. So, a 600 cubic inch all-aluminum, all-aftermarket BBC making 700 hp ends up around $15K, on the high end. But a stock short block, with the necessary machining, displacing only 460 cubic inches and making... 500 hp or so… ends up at around $8K, on the high end. Here’s the quandary... in terms of dollar per horsepower, the stock-based option wins. But the all-aluminum, all-aftermarket option is so much more... satisfying!
  24. Well, I AM lazy! When I get behind the wheel of my hobby-car, I want instant, brutal, uncompromising thrust, right off idle. I don’t want to work hard to find the engine’s power band. I work hard enough during the day – so, the last thing that I want is to “become one with the machine†or listen to its palpitating heart beat at 9000 rpm – and worry about sounds of rod bolts about to break. My desire is for the torque of a steam locomotive, propelling the mass of a skate board. Actual racing results – like quarter-mile times – are irrelevant.
  25. I think that it's important to make the distinction between: 1. Serious performance engines built by professionals or knowledgeable amateurs 2. Amateur jobs done on a "budget", generally lacking the proper experience or tools 3. Bone-stock engines. Mostly we've been debating engines that fall under (1) - and there, indeed, the turbo vs. displacement debate will rage on forever. But I would argue that in category (2), the larger-displacement n/a engine has an advantage: it's easier to half-a$$ your way to a reasonably well-running n/a engine, than a turbo. Now for an example from category (3). I used to have a 1987 MK III Supra turbo, 5 spd. 3600 lb car. High 15's in the quarter mile, with 110,000 miles on the engine and me driving (first time at the track). Very unfortunate combination of high weight, small displacement and laggy turbo. That was the car that motivated me to do a V8 Z. By way of comparison, some years ago I drove a stock turbo Eclipse. While not as powerful as the Supra, the throttle response felt much smoother, and turbo lag was far less. What applies to amateur engine-building also applies to amateur driving. Off-idle throttle response and a smooth, flat torque curve may not be critical for an expert driver in carefully-controlled circumstances, but they're important for an amateur driving an all-around car.
