Everything posted by S30TRBO
Make sure it's legit and has full documentation. Just a thought, maybe you can flip it and or JWT will buy it back then use the funds for another powerplant. Good Luck,
Swapping My LS1 into another Z!
S30TRBO replied to EvilC's topic in Gen III & IV Chevy V8Z Tech Board
Good I want to do the same thing.... Ideally I'd like to paint mine to match if possible. Glass or plexi on the hatch? Did you get the cowl too? -
Driver's side headlight went dim...
S30TRBO replied to capt_furious's topic in Trouble Shooting / General Engine
Paul is correct, Nissan designed it so if the fuse blows at 10pm you won't be completely dark, its enough so you can still drive to get it repaired. Freaked me out the first time it happened to me. -
Wow sounds like you had an all around great experience with raceonusa.com Are you using the stock hinges or pinning them on? Oh yeah -
Clive, IMHO I would color match to the centers and have the letters "polish writing" like piston said. The polished wheel lips alone set it off! Looking awesome, do you have another set of 240z Euro taillights?
Is my Master Cylinder Toast?
S30TRBO replied to Cable's topic in Brakes, Wheels, Suspension and Chassis
Have you tried to bench bleed the master first? If not since it is mounted already unhook the lines on the side and poor fluid in the reservoir and let it come out of the sides (gravity feed) getting all the air out then re-attach the lines up and bleed normally starting from farthest away from the master. You can also take the lines off and have someone pump slowly while you put your finger over the hole to see if you are getting any suction on your finger. If not I would just buy a new master for gp sakes. Good Luck keep us posted. -
Nice John...haha
watanabe r type?? are they worth it??
S30TRBO replied to nazgule6's topic in Brakes, Wheels, Suspension and Chassis
If that doesn't pan out you can try these: ~http://wheelchoice.com ask for Joji (this is where I got my first set from) ~http://datsunspirit.com/ Eiji Hosomi (this is where I got another set from) ~http://forums.club4ag.com/zerothread?id=57598 http://www.watanabewheel.com/ -
Wow very nice!! It will be nice to see what the final numbers will be.
Nissan Sport Issue #12 on Newsstands Now. Death to Hackers!
S30TRBO replied to NissanSportSarah's topic in Non Tech Board
Yasin, I did talk to Dave and he told me to write some articles on my projects and get them in. I just need to find the time. If they want to do a projects section that would add tons more content. I hope its not the sign of the times. -
Do Our Cars Hold Up Well To The Houston Climate?
S30TRBO replied to slownrusty's topic in Non Tech Board
Come to Atlanta you will be closer to me. -
Does anyone have this and using SDS to control it? If so how did you wire it in? I have the white wire and relay from them but need to know what else I need. I also have the harness for the fan plug and it is cut behind the pig tail. I just emailed SDS for clarification to see if the EM4-6F can even control a multi-speed fan. Any help would be appreciated. Thanks,
Clive who did you go with? -
I spent 5 years in Japan back in the early 90's and I could pick up a set of used wild offset JDM wheels for a few hundred bucks. It was funny to see it grow in the states starting on the west coast and migrating east. Fast forward into the 2000's when the hype of the JDM craze was going strong, in 2004 I paid $2300 shipped for my 16x8.5 -6 with center caps, lugs and locks. Yeah it's a lot of money but living in Japan I wanted nothing else. Now if you look on RS-Watanabe's Japan webpage they have gone up around $80 each new from $500 to $580 (for 16"). Add the costs of finding someone reputable to order them from Japan, shipping and it is a pretty penny. However, to each is own. I completely agree, pros and cons from different points of view. Good info. -
George, Just do it man come join the club, get the lugs, locks and center caps too. BTW I will email you back tonight. -
Let me say that this is your opinion and I respect that. I am curious “overrated†how have you come to that conclusion? For those in the Japanese community and others like myself (in the States) that respect them for what they have done as a company and the history they have carved in stone among the racing community and the weekend tuner it speaks huge volumes with there styling and looks. Overpriced I don’t think that is a fair statement, general but not fair. We should then throw in every other wheel manufacturer foreign and domestic in the same boat. They are out of reach for some buyer’s yes, so others resort to the less expensive “knock-off†versions which is fine and their right. Unless you are looking for a tire size over a 265 then sure it will be limited. If you run a 225/xx, 245/xx, in a 16†you can find them all day long. In my opinion 13,14,15 are hard to find in some cases. You may or may not have noticed there are more and more people purchasing CCW's over RS Watanabe's. Don't get me wrong they are a very nice wheel and comparable in price to RS Watanabe's. I guess it all boils down to your budget and what style you are looking for. Period correct or not some people want to copy others and some want to have there own style and look. Just my two cents. -
Been there done that, then I bit the bullet. Also been there done that. The price is about the same. Flares on stock suspension with camber kits...NO it will hit the lower spring perch. For that size yes. I run 16x8.5 -6 all around with 225/50/16 w/ sectioned struts, GC springs and Tokico Illumina's, camber plates and NO flares. Any bigger you will need flares. Good luck, -
Better yet Joe and Clive need to make a PSA about it. -
Clive, Maybe you should POR-15 Black the inside of the wheel wells? If it was as red as the outside I would say leave it and hit it with some clear POR-15. Other than that simply stunning!! Can you say MEATS!!! -
Glad you all enjoyed it! So many of these are so damn true.
Try not to laugh out loud... I dare you!! Random thoughts from people 25-45 years old: • I wish Google Maps had an "Avoid Ghetto" routing option. • More often than not, when someone is telling me a story all I can think about is that I can't wait for them to finish so that I can tell my own story that's not only better, but also more directly involves me. • Nothing sucks more than that moment during an argument when you realize you're wrong. • I don't understand the purpose of the line, "I don't need to drink to have fun." Great, no one does. But why start a fire with flint and sticks when they've invented the lighter? • That's enough, Nickelback. • I totally take back all those times I didn't want to nap when I was younger. • Is it just me, or are 80% of the people in the "people you may know" feature on Facebook people that I do know, but I deliberately choose not to be friends with? • Do you remember when you were a kid; playing Nintendo and it wouldn't work? You take the cartridge out, blow in it and that would magically fix the problem. Every kid in America did that, but how did we all know how to fix the problem? There was no Internet or message boards or FAQ's. We just figured it out. Today's kids are soft. • There is a great need for sarcasm font. • Sometimes, I'll watch a movie that I watched when I was younger and suddenly realize I had no idea what the f was going on when I first saw it. • How the hell are you supposed to fold a fitted sheet? • I would rather try to carry 10 plastic grocery bags in each hand than take 2 trips to bring my groceries in. • I think part of a best friend's job should be to immediately clear your computer history if you die. • The only time I look forward to a red light is when I'm trying to finish a text. • A recent study has shown that playing beer pong contributes to the spread of mono and the flu. Yeah, if you suck at it. • LOL has gone from meaning, "laugh out loud" to "I have nothing else to say". • I have a hard time deciphering the fine line between boredom and hunger. • Whenever someone says "I'm not book smart, but I'm street smart", all I hear is "I'm not real smart, but I'm imaginary smart". • How many times is it appropriate to say "What?" before you just nod and smile because you still didn't hear what they said? • I love the sense of camaraderie when an entire line of cars teams up to prevent a jerk from cutting in at the front. Stay strong, brothers! • Every time I have to spell a word over the phone using 'as in' examples, I will undoubtedly draw a blank and sound like a complete idiot. Today I had to spell my boss's last name to an attorney and said "Yes that's G as in...(10 second lapse)..ummm...Goonies". • While driving yesterday I saw a banana peel in the road and instinctively swerved to avoid it....thanks Mario Kart. • MapQuest really needs to start their directions on #5. Pretty sure I know how to get out of my neighborhood. • I find it hard to believe there are actually people who get in the shower first and THEN turn on the water. • I can't remember the last time I wasn't at least kind of tired. • Bad decisions make good stories. • Whenever I'm Facebook stalking someone and I find out that their profile is public I feel like a kid on Christmas morning who just got the Red Ryder BB gun that I always wanted. 546 pictures? Don't mind if I do! • Why is it that during an ice-breaker, when the whole room has to go around and say their name and where they are from, I get so incredibly nervous? Like I know my name, I know where I'm from; this shouldn't be a problem.... • You never know when it will strike, but there comes a moment at work when you've made up your mind that you just aren't doing anything productive for the rest of the day. • Can we all just agree to ignore whatever comes after DVDs? I don't want to have to restart my collection. • There's no worse feeling than that millisecond you're sure you are going to die after leaning your chair back a little too far. • I'm always slightly terrified when I exit out of Word and it asks me if I want to save any changes to my ten page research paper that I swear I did not make any changes to. • I hate being the one with the remote in a room full of people watching TV. There's so much pressure. 'I love this show, but will they judge me if I keep it on? I bet everyone is wishing we weren't watching this. It's only a matter of time before they all get up and leave the room. Will we still be friends after this? • I hate when I just miss a call by the last ring (Hello? Hello? Dammit!), but when I immediately call back, it rings nine times and goes to voicemail. What'd you do after I didn't answer? Drop the phone and run away? • I hate leaving my house confident and looking good and then not seeing anyone of importance the entire day. What a waste. • When I meet a new girl, I'm terrified of mentioning something she hasn't already told me but that I have learned from some light internet stalking. • I like all of the music in my iTunes, except when it's on shuffle, then I like about one in every fifteen songs in my iTunes. • As a driver I hate pedestrians, and as a pedestrian I hate drivers, but no matter what the mode of transportation, I always hate cyclists. • Sometimes I'll look down at my watch 3 consecutive times and still not know what time it is. • Even if I knew your social security number, I wouldn't know what do to with it. • It really pisses me off when I want to read a story on CNN.com and the link takes me to a video instead of text. • I wonder if cops ever get pissed off at the fact that everyone they drive behind obeys the speed limit. • I think the freezer deserves a light as well. • I disagree with Kay Jewelers. I would bet on any given Friday or Saturday night more kisses begin with Miller Lites than Kay. Happy Monday!
Pic Request of tires on 16x9, 16x9.5 Wats!
S30TRBO replied to shika805's topic in Brakes, Wheels, Suspension and Chassis
I have the ZR1's on my 8.5 -6 and my old 9.5 -19. Good tire thus far. Here are pictures from the horses mouth. Click on the pictures to reveal the tire and wheel sizes: http://www.rs-watanabe.co.jp/userspage_new/nissan.htm Example: F:R16-85 -6 R:R16-90 F:205/45 R:225/45 BS GRIDⅡ -
Looking awesome as always Yasin! Nice pair you have Have you had the current wheels on the white ZXT for a while? I remember the ones on the silver one that were on the white one last time I seen it.
Thanks man, heading back out soon to make more progress this weekend.
but BGPHIL is
