zack_280
Everything posted by zack_280
Progress on my insane VQ35HR 240Z project
zack_280 replied to markrolston@mac.com's topic in Nissan V6 Forum
Mark, I'm going to be at COTA for the WRL race. Any chance of you running the open lapping HPDE on Friday, 12/3? Mostly, I just want to see the car in person. -
Twin cam head for the L6 from Derek at Datsunworks
zack_280 replied to Derek's topic in Nissan L6 Forum
Not sure this is a Champcar legal head, but I won't protest you if you run it. -
I like that post...I'd use the button, but apparently I can only react to one post per day and I already liked Tony's post. -
What Tony said...Not to mention the issue with oil buildup on the valves. I guess you could do what Subaru and Toyota and maybe others are doing and running DI and MPFI at the same time. Derek, Maybe you could whip us up a few heads with both in your spare time. -
Just run the turbo for 100 points and spend the rest on aero and suspension.
I currently have a P90 head that needs to be replaced on an F54 block. PM me if you have one available. Thanks, Zack
Speaking of V2...I assume it will use this. http://www.freevalve.com/ Not sure why you didn't go with this option in the 1st place...No issues with cams, gears, chains, VTEC, etc. It pretty much eliminates all of your challenges. You really should have consulted me more on this build in the early stages. -
Nice! The head that I had to trash was done by Jim Thompson (supposedly). Unfortunately it appeared that the PO blew a head gasket and allowed water to sit in it for a few years. When I took the motor apart, I found out both the head and block were toast. So I bought another head from a member here and have been having a few problems that I believe are related to it. So now I'm hoping this will solve all of my problems. I'm pretty sure complication and money are usually the best way to solve engine issues. -
Wow. I wasn't really sure what happened since my buddy didn't see it. He was just repeating what he heard. It's pretty scary to think about. Not sure what the actual cause was or if the Mustang driver had any safety equipment, but something like that definitely makes you think twice about safety. I don't think I would ever get on track again without a Hans.
Good luck getting it back together. My buddy was there and told me it was a V8 Z. I heard a guy in a mustang hit the wall pretty hard after he slid through the oil slick.
We are not going to VIR this year either...I really want to do a race there, but we have just gotten to the point where we feel comfortable that we have found all of the bugs...Maybe next year. Not sure about the 24, though. We've only got 4 guys on our team and the car owner doesn't really want to trust anybody he doesn't know. Also we are definitely doing Barber in August and there is no way we would sign up for both of those races since they are so close. This year has been mostly positive, so we might make it out to VIR next year. I'm not familiar with Shenandoah, but generally tight courses are better for E30s. I imagine that the E36s will do pretty good too. Just tell your drivers to be smart with passing and keep the shiny side up. Finishing is almost as good as finishing first. If you have good stops, you can make up a lot of time...I think that's how we ended up so far ahead at NCM.
Good luck. We just did the NCM race last weekend in my buddy's E30. Finally got a win on day 1. Day 2 didn't go so good, but we learned to make sure the oil dipstick is completely inserted into the dipstick tube. Unfortunately we have 3 penalty laps for the next 3 races. We won by 2 laps and get a 'margin of victory + 1 lap' penalty for the next 3 races. 3 races! That seems pretty harsh, but rules is rules. We weren't even the fastest E30.
Sorry to hear that Mike. I'm still looking forward to seeing this car on track (probably not as much as you, though).
To answer the original question...You have to put a set screw in the AZC rear LCA. Maybe some setups will be less prone to movement, but mine has pretty tight clearances. At an autocross my outside rear wheel/tire was pushed into my inner fender due to movement of the suspension. I tried to jack the car up and drop it quickly, but it wouldn't move back to the original loaded position. I had to add a set screw. I discussed this with CobraMatt and he said he installed a set screw from day 1 to keep from having alignment issues.
If you are going to install a programmable ECU, you will have some more money in sensors, wiring, etc than just the ECU. It'll probably end up costing over $1k (unless you find a complete or mostly complete used system). If you don't want to spend a bit of time on this, your best bet is to find a stock ECU (assuming you now have the sensors you need to make it work). If necessary, you could buy a wiring harness kit from MS. It is definitely worth every penny. If you do not have the sensors you need and you are planning to tinker with the boost, I would probably go the aftermarked route just for the flexibility of the system.
240z Wilwood proportioning valve fitting leak
zack_280 replied to Curtball's topic in Brakes, Wheels, Suspension and Chassis
I used a Wilwood prop valve...P/N 260-11179. I had problems with leaks for a while. I reflared my lines and it still leaked. So I ended up tightening/loosening the fittings and after a few cycles they stopped leaking. That was over a year ago and still good. -
I think the OP means miles on the odometer, but either way I don't think it's much of a factor.
Not a bad idea, but it will take a little bit of effort to do that. This will get me to tinkering on the car again (and spending $50 here and $25 there and $200 there). My wife will be thrilled.
The "better gun" I was referring to was an IR camera that could discern pretty high temps. I'm not sure what the range is, but it's more than I would need to worry about. Again, I see your point with the cheap one. It could definitely provide some more info (not sure if it would be useful). I can feel the "boiling" with the car off and the high pressure pump sounds like it's trying to pump air rather than liquid when I turn it on. However, the "boiling" is still there with no pump running. I'm not sure that it is boiling or if it could be fuel leaking down into the tank and air leaking up from the tank into the surge tank, but the surge tank and fuel lines get pretty hot and the "boiling" feels pretty violent. I'll get a gauge and verify that there is positive pressure in the surge tank. I thought the same thing about circulating the fuel, but that doesn't seem to work. I have tried it multiple times, but it doesn't seem to have a noticeable effect. The only thing that seems to work is to let the system cool off.
I am definitely making assumptions about what the cause is, although I believe it is either cavitation as Tony mentioned above or heat soak. I was going to buy one of the cheap I/R guns, but a friend of mine works at a place and said he could borrow a much better one. That was 2 months ago. So maybe I need to go and buy the cheap one. I am running megasquirt injection, but I don't believe it is in any way related to my EMS. Here is what happens: I start the car, it runs fine for a little while (less of a while with less than 3/8 of a tank of fuel). Then my AFRs start getting lean spikes, like there is air in the fuel line. Then it will basically completely lean out and die. The engine usually only dies under idle at a stoplight or heavy load at an autox or track event. I shut off the car, wait 10-15 minutes, start it and drive away. I have felt the fuel boiling in the surge tank and in the pump and the fuel rail. Tony, I'll check the pressure in the surge tank, although I would be surprised if that was the problem.
I have a modified L28ET motor. It seems like the head gets very hot very quick under any driving conditions. For example, this weekend I drove my car for about 5-10 minutes. I pulled into the garage, popped the hood and the valve cover was almost too hot to touch. It was too hot to leave your finger on for longer than 1-2 seconds without pain. Is this within the bounds of normal for these motors? The heat soak is leading to vapor lock issues. It will vapor lock while running even while driving under load. Obviously the vapor lock is worse with less fuel in the tank. My intended solution is to get a fuel cooler and install it after the fuel pressure regulator. I just didn't want to do that if it was only a Band-Aid for a potentially larger problem. Here is my fuel system... Tank->Low Press Pump->Surge Tank->High Press Pump->Fuel Rail->Fuel Press Regulator->Surge Tank->Tank Thanks for any help suggestions, Zack
I'm running a GTX3071R turbo. My car is running megasquirt and has not been properly tuned, but I have spent a bit of time messing with it on the street. I did two pulls on an eddy current dyno and it made 245HP and 240lbft at 10PSI (but it did creep up to about 10.7PSI). This was a conservative dyno. I have a 1.01A/R turbine housing and was at full boost at ~3500RPM. I am quite happy with it and it will have no problem supporting 400HP. Hopefully this info is helpful.
My Dream LS7GTZ.......project underway
zack_280 replied to cobramatt's topic in S30 Series - 240z, 260z, 280z
I'll be at Daytona in our E30 also. Really hoping the new motor makes more power than the old one. Granted the old motor didn't have perfect compression numbers and had about 250k miles on the clock. We were having trouble keeping up with a number of Miatas on the straights. We confirmed the low numbers on a dyno. We were 15hp below a spec E30 and another Chump E30 on the same dyno on the same day. -
Matt, After we blew up and realized there was no fixing the car, we went to 10a/10b and watched the cars coming down the hill through the turn and going up. It had to be you driving around 3PM b/c we watched you take the lead. Me and my buddies all said "whoever is driving that E30 can really drive." I was sure it had to be a pro driver. It was impressive watching you storm up the hill passing just about everything and holding off the SC300 and even pulling away. The battle with the SC300 for the lead that lasted for 5 laps or so was pretty awesome to watch. When you got by, you blew through a pack of cars and the SC300 was history. Definitely the best racing I saw this weekend.
