LLave
    5
Everything posted by LLave
  1. Correct me if I am wrong BMW guys but isn't that the new M6? Which has a flat plane crank yeah? Notice the single ratchet strap off to one side holding that beast down No thanks...
  2. Check out his distributor/magneto/fuel pump set up. Holy tubes batman. This is also the first SBC I have ever seen with 3 oil pumps
  3. I was doing a little digging on the internet for domestic flat plane cranks and I came across this: http://www.ferraris-online.com/pages/carintro.php?reqcardir=LL-332-BLANK A lola 332 with a flat plane SBC in it. I can't even imagine how fast this thing must be. Here is a picture of the 180 deg. crank used in this car. This crank is apparently made by Crower. Amazing. He says he only has a bit over $30,000 invested in engine parts.
  4. I am not 100% sure on this, but I believe that in CA you can only swap motor types that were offered originally for that model, ie you have a 6cyl mustang and want to put a v8 in it. I would look into the kit car laws and see what they say about smog. You may even want to start by going to your local ref and picking his brain.
  5. The torch is actually tig sized. The machine I have has a very nice water cooling system built in. Apparently they are very popular in the aerospace industry because they can weld all types of exotic metals. They also have the ability to weld very very thin materials. Like tin foil... My machine will only go up to about 1/8th inch. I payed $300 for it but now I don't know if I want to keep it or sell it and buy a new TIG.
  6. Jon, I know this is a bit of an old thread, but is there a chance you can post some pictures of the finished part. I would love to see it. Thanks, Mike
  7. Probably seen these before but they are 2 of my favorites.
  8. I just picked up a Linde PWM-9 plasma needle arc welder. It has all types of bells and whistles. I have no idea how to use it or if it is worth a damn. Anyone have any experience with these machines?
  9. His question has been answered and kindly pointed in the direction of the search function for future inquires. The thread is done, leave it be.
  10. Does anyone have any info on someone actually running a 180deg crank on a sbc?
  11. Take a look at these sweet little covers. http://cgi.ebay.com/ebaymotors/RED-Caliper-Covers-Set-Front-Rear-For-Honda-Toyota-Bmw_W0QQitemZ150122735115QQihZ005QQcategoryZ33563QQrdZ1QQcmdZViewItem
  12. :mrgreen:That is a great way to sum it up and get right to the point.
  13. When the whole thing is over you will have to post up some pictures. Great work and good luck.
  14. ooohhh once I rob that bank down the street I am so getting one. "We have a number of CK formula one engines available for sale. Due to the nature of these engines, we will offer complete track/build support. The CK engine is a 3 litre V10. Max revs 17,800. Max power 840 bhp. Weight 92.5kg. Lifetime 700 km, more at reduced rpm. This engine was fitted to the late Stewart Grand Prix chassis, and all Jaguar Racing chassis. Approximate cost of rebuild per engine £10k." Yeah!!
  15. Weird, I can still see it. Well here are some details from the auction We are offering an Indy Cosworth DFX engine assembly. The engine at one times lost a connecting rod, causing minor damage to the block and pan. This engine assembly includes: · One DFX 2.65 L Block with dry sump oil pan. The block had two damaged sleeves removed. Block will need an area the size of a quarter welded and two new sleeves installed (replacement sleeves not included). The area needing repair is non-structural and does not meet any of the machined surfaces. · Two Right side head assemblies. One needs minor combustion chamber dressing and the other will need a combustion chamber repaired. The head that is in better shape has the accessory cover with the cam assembly installed. Neither heads have valves. · One left head assembly. No valves or cams are included. It needs a combustion chamber repaired. · One Cosworth Magnesium Valve Cover · One Magnesium Accessory belt cover · One NOS DFX Crankshaft · One Used DFX Crankshaft · Two NOS sets of 8 Carrillo Rods 5.23 and 5.39 · Four used Cosworth DFX 5.23 Rods with Bearings · Four used Cosworth DFX Pistons · One Magneto Assembly with Driveshaft, Mount and Cap · One Forward Motor Mount · Two Cylinder Compression Rings Item is sold as Is Where Is. Winner is responsible for shipping and handling cost. Item can be seen in person.
  16. http://cgi.ebay.com/ebaymotors/Cosworth-DFX-F1-V8-Indy-Vintage-Race-Halibrand-Engine_W0QQcmdZViewItemQQcategoryZ140684QQihZ018QQitemZ280112509155QQrdZ1 Some one needs to buy one of these and make it happen...
  17. Looks good, nice and clean. It looks factory. Now you just need to get rid of all those threaded stand offs, vacume holes and extra junk. See you in a few months
  18. Great, thanks for the info.
  19. Maybe I am not understading the problem correctly, but it looks like you could simply grind or machine off just the little outter lip on the bolt heads and be just fine...
  20. I have the same feelings about 2x3 tubing. I was going to use .065 or .083 if I can get it. I think that should be more than enough. What do you think?
  21. naaa a bulb is a buld. I like silverstars a bit blue but really more white
  22. wow, it must take a lot of force to flatten the angle like that
  23. hmm sounds like I need to find myself a pick-up
