4
Everything posted by dsommer
Finally ordered my rotating assembly 383 stroker
dsommer replied to dsommer's topic in Gen I & II Chevy V8 Tech Board
I believe so. (not a billet unit) I haven't driven the 240 car with that cam in it very much, heck I don't drive any of my Datsuns (Scarab or 240) much at all. So no clue on the wear. What brand lifters were/are you running? Terry, It'll be a while before this gets on the steet but when it does we'll get together, yeah I'm still in Rogers. What kind of torque are you putting out? -
I don't know anything about that... They are called "rookie stripes". Here is my Scarab with them on. Drivers who are not known to the, organizers or who have limited experience, may be required to affix two "rookie" identification stripes to the rear of the car. This designation allows veteran competitors to exercise additional caution when racing/passing a rookie driver. I don’t know how often they are used now a days. The stripes on my car (and decals all removable vinyl BTW) came from the number kit I bought for my Cobra several years ago. Hope this helps.
There are lies, damn lies and statistics Holley Throttle Body Injection (TBI) 900 CFM TB 85 lb/hr injectors Support up to 550 HP Intake Edelbrock Torker (not Torker II) intake which has been thermal coated and had “hidden†direct port nitrous injection (under intake) for 100HP “shot†Rear end Rear end is LSD independent suspension with upgraded cv axels gear ratio is 3.70:1 Transmission Will upgrade my current trans to the G-force spec trans below. What I currently have World Class (Borg Warner) T-5 Gear ratios 1st 3.35 2nd 1.99 3rd 1.33 4th 1.00 5th 0.68 G-force rear ratios: 1st 2.94 2nd 1.94 3rd 1.34 4th 1.00 5th .59 or .73 From the G-force web site Normally the stock T-5 is rated at about 300 ft-lb of torque capacity. While this is fine for stock or lightly modified engine combinations, especially running small street tires, it isn't generally enough for most of today's high powered street/strip engine combinations, especially those running bigger, more aggressive tires. This is where the G-Force Street 5-Speed kit comes into play. Although we do not like to put torque or horsepower ratings on our products due to the vast differences in clutch, engine, chassis, tire, and mounting combinations, we can give a very rough estimate. There are simply too many variables to consider when trying to figure out how much power or torque a transmission will take in a particular application. Generally, it can be assumed that with the available upgraded mainshaft, the G-Force Street 5-Speed kit will handle roughly 600 hp or 500 ft-lb. or torque in a 3300 lb. vehicle running drag radials at the track with a moderate clutch upgrade. Obviously this is just a rough estimate regarding the power and torque handling capability, but it should give some idea as to what the G-Force Street 5-Speed kit will handle in your particular application. Our Street 5-Speed kits are currently available with the preferred 2.94, 1.94, 1.34, 1.00 ratios in gears 1 thru 4, and because most performance enthusiasts run a relatively steep rear gear, our synchronized kit utilizes a .59 overdrive. This is slightly taller than the stock .68 or .63 ratio and allows the engine to turn less RPM at cruising speed. This equates to less engine wear and better gas mileage while still maintaining incredible acceleration in the first 4 gears - amazing! We are currently working on more ratios for both kits, including a special dog-ring-only road race ratio. Camshaft Specification Table//CAM CARD Part Number 12-769-8 Engine 1955-1998 Chevrolet 262ci-400ci 8cyl. Grind Number CS XR268 R-10 Description Intake Exhaust Valve Adjustment 0.016 0.018 Gross Valve Lift 0.552 0.564 Duration At 0.015 Tappet Lift 268 274 Valve Timing At 0.015 Open Close Intake 28 60 Exhaust 71 23 These Specs Are For The Cam Installed At 106 Intake CL Intake Exhaust Duration At 0.05 230 236 Lobe Lift 0.368 0.376 Lobe Separation 110 Recommended Valve Springs 977-16 Scorpion billet roller rockers 1.5 ratio (consider 1.6 on exhaust side??) Trick Flow push rods (.010 longer) Trick Flow Heads Part number TFS 30400002 specs: Cylinder Head Style: Assembled Cylinder Head Material: Aluminum Cylinder Head Finish: Natural Combustion Chamber Volume (cc): 62 CNC Machined Combustion Chamber: No Intake Runner Volume (cc): 195cc Exhaust Runner Volume (cc): 75cc CNC Machined Intake Runner: No CNC Machined Exhaust Runner: No Intake Port Shape: Rectangular Intake Port Location: Standard Exhaust Port Shape: D-port Exhaust Port Location: Standard Spark Plug Style: Angle Intake Valves Included: Yes Intake Valve Diameter (in): 2.020 in. Exhaust Valves Included: Yes Exhaust Valve Diameter (in): 1.600 in. Valve Springs Included: Yes Maximum Valve Lift (in): 0.540 in. Outside Diameter of Outer Spring (in): 1.470 in. Damper Spring Included: Yes Number of Springs Per Valve: Single Retainers Included: Yes Retainer Material: Chromemoly steel Locks Included: Yes Lock Style: 7 degree Valve Stem Seals Included: Yes Valve Stem Seal Style: Viton® fluoroelastomer Rocker Arm Studs Included: Yes Rocker Arm Nut Thread Size: 3/8-24 in. Rocker Arms Included: No Rocker Arm Nuts Included: No Guideplates Included: Yes Guideplate Pushrod Size: 5/16 in. Valve Cover Mounting Style: Perimeter bolt Accessory Bolt Holes Drilled: Yes Intake Valve Angle: 23 Exhaust Valve Angle: 23 Valve Guides Included: Yes Valve Guide Material: Manganese bronze Valve Seats Machined: Yes Valve Seat Machine Style: 3-angle Valve Seat Material: Tungsten Steam Holes Drilled: No Oiling Style: Through pushrod Machined for O-Ring: No Heat Crossover: Yes Quantity: Sold as a pair. Notes: Will not fit centerbolt-style intake manifolds. Hooker Headers Stuck with these due to X-member and steering shaft interference Header Material: Steel Header Finish: Ceramic coated Header Style: Shorty Primary Tube Diameter (in): 1 5/8 in. Collector Attachment: 3-bolt flange Collector Diameter (in): 2.500 in. Tuned: Yes Primary Tube Gauge: 18-gauge Flange Style: Standard Flange Thickness (in): 5/16 in. Remainder of exhaust flows into 2.5†pipes into 3†pipe super flow type single muffler. -
Finally ordered it from Scott at DynoFlo performance in Henderson, NV. What I ordered: Eagle 4340 Forged Steel Steel Internal balance 2pc rear main seal 3.75†crank Mahle Forged Racing Pistons 11:1 compression ratio all Mahle Pistons in this kit are Phosphate Dipped and Teflon Coated 6†Eagle ESP 4340 Forged Steel H Beam Rods with ARP 8740 Bolts Mahle Moly Racing Performance Ring Set King Race Bearings Rods and Main ARP main studs ARP head studs Balanced Block is at the machine shop waiting for the arrival of the pistons (kit) going .040 over on am 010 high nickel block. Trickflow heads, roller rockers, Comp mech roller cam, gear drive cam, Torker intake with direct nitrous injection (hidden under intake) 100 hp "shot".
Its got a Corvette engine in it......shezzz
Did you have G-force build yours or did you have it done locally??? What parts/package did you install?
Why not the T-56 6speed? Lots of folks are running them. Personally I'm going to run a WC T-5 behind my stroker, I figure if I don't BEAT on it too hard it should last a good while. Check out racingjunk.com for leads on trannys. Good luck and post up some pics and an intro.
Can you guess who I for??? I get free oil, how cool is that?
"Sounds" like the test subjects were blind and DEAF!!!
Mid Americal Motorplex outside Omaha, NE
That was hilarioius!!! Even better because I just drove on that track Labor Day weekend with the Scarab.
Way to go Brian!!!! You're making me look like dirt
Sportmax002 wheels - they fit!
dsommer replied to bubbleguinea's topic in Brakes, Wheels, Suspension and Chassis
Guess you found your rims, saw your post on the GB and remembered somebody was selling theirs for a DEAL. Way to search dude:2thumbs: Sparks why are you selling??? -
Just a heads up, my 240z going for sale soon
dsommer replied to Poundz9oh9's topic in Non Tech Board
Hate to say I told you so Somebody got a sweet car. I saw your **Sold** signature before I saw this post, felt like a kick in the gut. Don't be a stranger around here and best wishes on your families' move to Hawaii. If you ever get around this way again look me up. David -
Marcus for that price I think you'll be kissing it good bye -
Sell the engine and buy Pound9oh9's z for cheap... BTW what engine do you have???? I'm in the market for one L-6.
Are you running an LSD or open dif? Breaking them huh? You're putting down some power. I better stock up when I rebuild my engine, so far I've got an LSD in the car, a 3.9 and a 3.54 sitting.
1. depends on which wheel you get see group buy pages on this forum. (gold=more expensive if avaliable.) 2. Group buy here at hybridz 3. yes. -
1974 260Z track car. Ground Up.
dsommer replied to MoNkEyT88's topic in S30 Series - 240z, 260z, 280z
Must be single ha-ha. Nice work BTW!!! -
Sorry but your brother is a dumba$$ for driving w/o insurance, PERIOD. What if he hit a person and killed them, then what? I pay and pay and pay for insurance just like so many others on this board knowing your brother drives around w/o insurance is like walking around with a loaded gun with your finger on the trigger and the safety off. Slap him on the head and demand he gets insurance before he gets back out on the streets again.
dsommer replied to k3werra's topic in Brakes, Wheels, Suspension and Chassis
SportMax002's 16x8 Several folks are looking for the gold ones, I think I got the last set he-he. 16x7 Panna Sports 16x7 225-50-16 they rub in the rear 71 240Z 17x7 Centerline Azteks 225-45-17 on my 240 -
I second that it can be done but you pull up in a 3rd gen F-body and tell me it can beat a Hennessey Viper....well that's nice but I'd like to SEE you beat up a Hennessey Viper in person but they aren't parked on every street corner. Basically you'll just be running with the F-body crowd and talking down about Mustangs and Corvettes. Speaking of Corvettes, that is the platform I would choose if you're staying domestic. It stacks up better against the Viper in that they both are "iconic" sports cars, two seaters big HP (not talking about stock vettes in some cases ie 1978 cars ug choke cough). Here is what I plan on building one day and I'll take on all comers. http://www.factoryfive.com/gtmhome.html
Spotted this little gem at fry's parking lot yesterday....
dsommer replied to auxilary's topic in Non Tech Board
He forgot to do the gas door he-he. -
Uh, OK. Good luck and best wishes!!! psssst......spell check
I've done 3 or 4 with RTV and they all leak!!! Get the gasket, call your local Nissan dealer. This should be your part number: 38320-N3111 In stock $3.81 +ship.
