Miles
    29
Everything posted by Miles
  1. Welcome You may find this information useful: · Download a Factory Service Manual (FSM). http://www.xenonzcar.com/s30/reference.html · Download electrical schematics for your car. PDFs are easier to read than those found in books. Some are in color. · Buy the book How to Restore Your Datsun Z Car by Wick Humble. It will save you hours of searching for "how to" info. · Focus on searching Hybridz as 99% of questions have already been addressed. · Start bookmarking Z car parts suppliers - there are many! · For SU carbs, parts and instructions go to Ztherapy. Buy the "Just SUs" video. · Remember these are 40 year old cars and will need restoration to be safe and drivable. · Join ClassicZCars.com website and search there as well. · Become well informed about modifications before asking questions. People will be more inclined to answer informed questions. · Search the Hybridz forums. · Read all of the new member guidelines and FAQs Links: https://www.datsun-240z-upgrades.net/ Recommend the headlight relay harness http://zhome.com/ https://www.zcar.com/ https://www.classiczcars.com/ http://www.zcarparts.com/ http://www.arizonazcar.com/ http://www.jagsthatrun.com/index.html http://www.ztherapy.com/ http://www.xenonzcar.com/reference.html
  2. In your part search contact Eric Neyerlin at https://zparts.com/ 541-670-7310 Eric has been collecting and selling Z parts for over 20 years
  3. The part number you gave is for a relay inhibitor switch. You sure it is part of the light circuit? https://www.nissanpartsdeal.com/parts/nissan-relay-inhib-sw~b5230-89985.html The right half of your schematic is missing. Here is the complete schematic which shows the combination switch (lights, wiper, washer and turn signal). The combination switch is located on the steering column:
  4. Contacts in the TS switch need to be cleaned and/or adjusted . Common problem for all Z cars. You can repair the TS switch. Search for turn signal repair. Start here: https://fiddlingwithzcars.wordpress.com/2012/12/04/turn-signal-repair/
  5. You measure from the face of the aluminum spacer on the booster to the tip of the push rod. So, if you replaced the stock 7/8 MC with a 15/16 MC, which has a deeper socket, you adjust the push rod out 0.53"as measured from from the face of the aluminum spacer. The 0.53" is a starting point. You may have to fine tune the push rod length by making small changes and then road test the car to make sure the rod is as close as possible to the bottom of the MC socket without pushing the piston too far inward which will cause the brakes to drag or lockup. If the push rod is adjusted too long, the piston will block the return port in the MC and the brakes lock up after 2 or 3 stops. If this happens, open the MC bleeders to relieve the built up fluid pressure, limp home, and adjust the push rod a little shorter etc etc. If the pedal moves too much before engaging the MC you will need to lengthen the push rod in small increments. Note that you do not have to remove the MC to perform this adjustment. Just remove the mounting nuts and then pull the MC out and push it aside. There is also a tool to measure push rod length.
  6. Look here: http://www.classicperform.com/TechBook/BrakeTroubleshoot.htm
  7. Again I ask, what size MC did you install? Calipers require a larger volume of fluid. So the pedal goes low because the MC has to pump more fluid. You may have to install a 15/16 or 1 in. MC
  8. one more thing to check. There is a push rod between the booster and the MC piston. The rod is adjustable. When you change MCs you have to adjust the push rod because the piston socket depth is different between the 7/8 MC and the 15/16 MC. Look it up. If the push rod is adjusted too long the brakes will lock up because the longer push rod prevents the piston from retracting all the way which blocks the fluid return port inside the MC. This will result in your brakes locking up after a few stops. If this happens while road testing just open the MC bleed screws and limp home and readjust the push rod. If the push rod is too short you will experience a long pedal because the piston is not pushed far enough to fully engage the brakes. That is, the piston is not pushing enough fluid. Your brakes will feel mushy and you will experience a pedal with long travel before engaging the piston Do a search for push rod adjustment. It is critical to properly functioning brakes and brake feel.
  9. Do your speed bleeders work with your Motive power bleeder ?
  10. Yep, p/n 639560 for the front calipers https://www.ebay.com/itm/Russell-Brake-Caliper-Speed-Bleeders-Front-Rear-for-1970-1973-Datsun-240Z-/192230009783
  11. Edit Earl's speed bleeders from Summit. They come in several lengths. https://www.summitracing.com/search/product-line/earls-performance-solo-bleed-brake-bleeders?N=4294909157
  12. See my last post. If you gutted the PV you may have now tied the front and rear brake circuits together which would explain fluid flowing between the tanks.
  13. You gutted the OEM proportioning valve? The 240Z PV can be gutted as it only effects the rear brake circuit. Not sure about the 260Z and 280Z PVs, but you may have just tied the front and back hydraulic circuits together. Somebody chime in on this.
  14. ^^Yep ^^ Like this.....................................
  15. Bench bleed the MC properly and repost. I Assume you installed a 15/16 or 1 inch MC.
  16. I have swapped the 240z push rod with clevis into the Tilton/Wilwood MC. There is a snap ring that holds the rod in place.
  17. https://fiddlingwithzcars.wordpress.com/2012/12/04/turn-signal-repair/ https://www.classiczcars.com/forums/topic/34330-72-240z-turn-signal-stoped-workining/
  18. Look at the rocker inside the TS switch in the video. See the center stalk that pushes the rockers? There should be a small ball bearing with a spring in the center stalk.
  19. https://www.jegs.com/i/JEGS/555/631013/10002/-1
  20. Jegs, Summit and Speedway show a brake booster clevis 3/8-24 thread. Not sure of thread type for the 240Z/280Z. They also sell push rod extension kits. I seem to recall (10 years ago) that the 240Z and 280s push rods were of different diameters and he clevis pins were different . When I swapped in a 280Z booster into my 240Z I swapped the 240Z push rod into the 280Z booster so I could use the 240Z clevis. My pedal has some slack, but the clevis is adjusted all the way out. If you find a way to lengthen the clevis post your solution here.
