RB26powered74zcar
Super Moderators
    23
Everything posted by RB26powered74zcar
  1. I guess / think so.... Here are some pics for reference (measured from ground up).
  2. I went ahead and picked up one of these off Amazon dot com, and must say, it's pretty stout. I have a couple other methods to prevent starting the car, so this should add to the layer of protection... http://www.prohoist.com/denver-wheel-boot-lock.html
  3. I have a perfect 280z set, blasted and painted. $150 plus shipping via paypal
  4. Do you need R200 Diff side stub shafts, or do you need larger spline count 280z stub axles with matching companion flanges?
  5. Yes, they are the extra wide bamf cf flares. They are unbelievably crappy quality though... I will try and get a measurement for you soon as possible.
  6. Yes, I did the rear so far... They are not on permanently yet.
  7. WOW.... now that's impressive! Your Z is one badazz ride Can you take a pic from the sideish / rear, so we can see the width on the tires/wheels ?
  8. You scored.... Not many left in that good of shape.
  9. Marcus, Sent the stub shafts to you today via UPS Ground. You will get them Jan. 12th. joel
  10. I have a pair of 4 bolt R200 input stub shafts [shown in pic]..PM'd You.
  11. Rossman is correct, but if you decide to use a cap, I may have one Give me till this eve. to check my stock, I may have an extra one I can send you.
  12. I have never compared them against L6 dowls, but they may match up. I have several dowls but no way to know which you need....
  13. Please search here for the info you need to know about zforce. It's plentiful here, and Google.
  14. 1st thing causing no heat is vacuum leaks most of the time. Check all vacuum lines going to heater / air con unit.
  15. That's what I used them with, a coil over set up lowered about 2" or so.... Here are the struts
  16. I just noticed you said > Looking for a pair of rear struts for my lowered 74' 260z(late). Tokico, koni, whatever that can hanlde being lowered 2"-4" and is not STOCK !! These are for stock length (not sectioned) strut tubes..... paypal >> rb26powered74zcar@gmail.com Send as "Gift" pleeze.
  17. I have a pair of rear Tokico blue inserts I just removed to upgrade to 5 way adj. off my early 260 (same as 240 size). They are in perfect, low mileage cond. $75 shipped
  18. I might have mistakenly closed it thinking part was sold....
  19. Nice job on the install Mike!! Your Z is impressive...
