MAG58
Everything posted by MAG58
  1. Do you get any popping? I have the XR700 on my car and it runs well. Bring it up to tdc and look through the shutter plate. The eye should be uncovered to shoot through the shutter, and at 5-10btdc (depending on what your initial timing is), the eye should just start to be viewable through the shutter. Also make sure that the cap and rotor are engaging at the ignition events as this was a problem I ran into as well. Hope this helps
  2. Friends!!! Hi. I'm Bob. I summer DD a mini with a full race 312 duration cam and 1.6 rockers. Good company I see...
  3. Engineering is the new business. That's why I went pre-med. There is no room left for innovation I feel. At my school it was just a bunch of cookie cutter engineers getting chucked out one after another. I felt that I was being shown how to fix other people's problems and pitch some meaningless idea to a bunch of accountants than actually doing something useful. With pre-med, it really is as much technical information and all that jazz as ME, you just have a chance to actually make something of yourself. ...At the cost of being poor, FOREVER.
  4. The T5 I liked much more than the Z tranny just because I thought it was much more simplistic to set up lash on. But it was a hugely different beast.
  5. Congrats Mr. K! Thank you for all that you've done.
  6. I feel I've been violated.
  7. Ahh... Two days in and my junior year isn't too bad. Microbiology & Lab Orgo Lab Statistics II Greek Philosophy & Composition (ew.) Piano Hopefully the MCAT's wont completely occupy my life, though I fear they will. But alas, I've accepted the fact I will have no friends until I'm hitting the strides of graying hair.
  8. Well expect to lose all practical bottom end and have a real cool lope. Is it streetable, most likely not. Would I put it on the street? Most likely.
  9. I put it in 5th and had a plain driveshaft yoke sitting around. A big pipe went through that so I had a pair of 6 foot long bars doing my work for me. To Hold it still, I just re-bolted the front housing on temporarily so I could hang the tranny on the engine stand.
  10. Good stuff. I'm only 20 but this pretty much describes my life experience in bullet points. Thanks for a chuckle.
  11. So if a 54R is a 426, what in God's name would this equate to?
  12. It's called a detroit diesel 2 stroke. God help you.
  13. Where's flatty? Time for a pictorial story. Swapped into this... Gives you...
  14. Lot's o Searching. The RB is rapidly becoming one of those beat to death engine swaps. ...Not to say that's a bad thing Anyway, plenty of serchable help here. Step by step instructions courtesy stoney can be found here http://forums.hybridz.org/showthread.php?t=77962
  15. I've seen shims that go between the block and head. They're designed to maintain the compression ratio after it's been decked. I would follow the directions and use copper-coat for your sealant.
  16. Both are nice, but I'd have the Savage. It's crazy accurate and the 308 I shout was surprisingly docile. You can even get one in 300WSM
  17. Probably an oil tanker, IIRC oil tankers prefer one giant motor to a whole battery of smaller ones as it is more efficient to do so. and look at that starter
  18. I will wear my user title proudly... I think.
  19. False, All you need is a 100 shot of naws and my stock block 2JZ will be making 1200whp all day long. ...yo
  20. I think it's an LT in a V6 camaro. But still, why did you pick HBZ for this question?
  21. All about preference. I can see this quickly become a which is better thread, but when it boils down to it, it's all about what you know best and what you're most comfortable with. Getting the mounts back should be super easy provided they didn't hack up the tranny tunnel and even then the T5 would require a modified trans mount anyways (if you wanna go that route). I really like my L6 and with a light turbo it should give you comparable performace to a SBC. I just wouldn't go back to an L24, just because L28's are so plentiful relatively that it'd probably end up the same price. Past that it's preference. You can get a 4 barrel, EFI, Side-drafts on either motor so at this point just go with what you feel most comfortable with.
  22. Dear God, Is that turbo rated for bird strikes? I hope so.
  23. Woah, did you buy them like that? I'd definitely have a talk with whoever sold you those, I would NOT use them in my car, that rust is starting to get into the fine machined surface, you would no longer have a constant contact patch between the rocker or the valve and wear on all three would be accelerated. That's just my opinion though.
  24. You best bet here is to call MM, they're not Z31's because those are 4 bolts and not 6. You would notice that. My bet is that either your half shafts are not going in all the way for some reason (into the differential) OR the companion flanges (i'm guessing you got the ones welded to the companion flanges? ) have not seated properly. Either way the ZXT tri-pods are already a tight fit.
