JSM
    4
Everything posted by JSM
  1. Phil, 1. Ask for the dimensions and weight on the box. 2. Get his address 3. Go to http://www.fedex.com/ratefinder/home?cc=US&language=en And do your own quote. Ebay just changed their policy too. Sellers can no longer leave negative feedback for buyers if you decide to bail, but you will get a non-paying bidder strike. ------------- I made this up but used the above site using Fedex Ground Home Delivery insured for $100.00 From: Hialeah, FL 33010, U.S.A. | To: Waxahachie, TX 75165, U.S.A. 25 LBS - 70x18x18 It was $127.22
  2. I day dream about winning the lottery and what I'd do with the money. It always puts a smile on my face . A 6 to 8 car garage would be an ABSOLUTE must.
  3. JSM
    rebuild L-6
    What would you want to spend on a block w/ flat tops, N42 head and Cammed? Sorry, miss read, mine is a 280z block., NM.
  4. JSM
    Date in the Z
    I’m sure you all know this, but you must recognize that men and women see things totally differently. I can rarely convince my wife of my views, but she deals with it and vice versa. Were just different people. I think the key is realizing you can’t change anyone, male or female. If you want to be together you must accept them for who they are or move on. To me, I think there is more positives about the girl you mentioned then negatives. It’s good to have hobbies together, but it is also great to have your own. I still laugh at what my neighbor said to me before he moved away, “…I’d be gay if it wasn’t for the sex.”
  5. If it is flooding have your verified your fuel pressure? If it is too high it will flood.
  6. :ass:Where do I sign up!
  7. I really like this design that jgkurz posted earlier:
  8. I think were still stuck waiting for a donner header to copy still, right Jeff?
  9. LOL, Yep I've done this pulling a motor and trans together once. I felt really dumb afterwards.
  10. You may also want to try jacking it up just a tiny, tiny bit and then try sliding it out. Sometimes the weight of the trans will cause binding.
  11. -Just make sure you didn't miss any bolts -Make sure it is supported well so you don't get hurt or hurt the trans Suggested Methods -Wigle the tail of trans (closest to the drive shaft input) vigoroursly and pull -Use a pry bar if you can between block and the trans -All else fails use a come along to pull it out Something like this:
  12. I wouldn't. Spend the $50.00 and get the thermostat controller. Cheap insurance just in case you forget. I forgot once and almost regreted it.
  13. Holly cow Batman! Thanks for that link. Is that a new site?
  14. Maybe w/Flat top pistons, but dished why would there be a problem? As long as the boring isn't took extensive to weeken the cylinder walls.
  15. I say this everytime to my wife and experienced it first hand again recently, but when coming back into FL on the return trip, people get stupid. I don't know if people are excited to be in FL or what, but courtesy and common sense go out the window. They completely forget how to get out of the fast lane, drive slow and make dumb decsisions. No other state that I've driven is as bad as FL. I look forward to driving outside of FL when on vacation. I loved driving in Chicago, I fit right in w/ the taxi drivers!
  16. Was security tight? Could you walk up and talk w/ him?
  17. When I get the Z insured will have to hook up for lunch one day. I work in Maitland.
  18. It's all good. If you stay around here for awhile, you will realize (at least I did) how dumb some of our questions are. Good luck on your build.
  19. Can relate to almost all of those. I've been in FL since I was 18 months old, now almost 39. After Charlie, we get out of the State now. Nothing like a forced vacation.
  20. Oh sweet! This was the thread I was looking for. I just picked up a 60mm Weber TB this weekend. Ebay here I come!
  21. Why not disconnect your fuel pump for a second and give this method a shot. If this works you know it is fuel related. Or try and start it like it is. If it gets flooded, then disconnect the pump and see if it wants to start. To much pressure will cause it to run rich and will be very hard to start. Your AFM is good?
  22. From the seller .... "i found this at a junk yard in an 87 300zx turbo. because of the smooth cover and build date i figured it wasnt an lsd but i think the previous owner swapped the differential out because the pre 4/87 models had open differentials and this one you can see it doesnt have an open differential like it should. "
  23. LOL! To funny, I don't think it is. I emailed him and told him to check. My thinking is the real LSD went out and they swapped in a Non-LSD R200. Are you still looking for one?
