jeffer949
    8
Everything posted by jeffer949
  1. hey derek look around i think zedd findings has them and if i remember they are cheaper else where also
  2. ya what would cause the cats to blow apart like that??
  3. i think im going to see how hard it would be to return it. but i also think im going to install the lights too at a later date. i did find them for a good price on ebay.http://cgi.ebay.com/ebaymotors/NEW-AUTOLOC-TRI-BAR-STREET-ROD-HEADLIGHTS-w-TURN-SIGNAL_W0QQitemZ310011941765QQihZ021QQcategoryZ33710QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  4. the thing is i kinda like the idea of taking the turn signals out. didnt somone on this board do his that way??
  5. ok for christmas my friends got together and ordered me a xenon urethan air dam off of ebay. the only problem is they ordered the one for the late260/280z and i have an early Z. my question is... should i just stick with this air dam and rig up some custom turn signals/running lights. maybe with something like this. that have the "city lights" in them and then use those for my turn signals.. http://cgi.ebay.com/ebaymotors/75-82-DATSUN-240-260-280Z-DIAMOND-CUT-HEADLIGHTS-H4-NEW_W0QQcmdZViewItemQQcategoryZ33710QQihZ020QQitemZ300187011448QQrdZ1QQsspagenameZWDVW or should i hassle with returning the air damn and getting the early one that is actually for my year which is an early 260z the one i need http://cgi.ebay.com/ebaymotors/Xenon-Body-Kit-240Z-260Z-280Z-Front-Air-Dam-Brake-Ducts_W0QQitemZ150144559276QQihZ005QQcategoryZ38658QQrdZ1QQssPageNameZWD1VQQcmdZViewItem?_trksid=p1638.m118 he one im getting http://cgi.ebay.com/ebaymotors/Xenon-Body-Kit-240Z-260Z-280Z-Front-Air-Dam-Brake-Ducts_W0QQitemZ150144558137QQihZ005QQcategoryZ38658QQrdZ1QQssPageNameZWD1VQQcmdZViewItem?_trksid=p1638.m118
  6. ok how do i change that? or find out what is on my ecu??
  7. but i have it set for the MS1 original BG code and isnt that what the 68HC908 processor comes flashed with??? and it also does it even if i dont have the board connected to the serial cable... make sense??
  8. ok im getting an error message when i start megatune after i select which code to use which at the moment is just ms1 no msns yet(just assembled it) and then this error message comes up before it opens. any body have any ideas??? also it comes up regardless to weather or not i have my ms connected through the serial cable with the stim on or not
  9. i thought that the cas plug was the same for the 81 to the 82-83 dizzy??
  10. hey austin where did your gf get those dvd's and the book???
  11. i say get another one... and keep the current also. 2 Z's is always better than one right?? i mean take out the j in 2jz and what do you have??? 2 Z's i think its meant to be!!!!
  12. i got MS1 V3.0 unassembled kit, unassembled stim board. assembled relay board, diyautotunes engine harnes, GM open iat sensor with pigtail. and a LC-1 wide band meter. and i also got a set o door handle cover things that go inside the handle and are plastic. i cant complain thats all i know. i allready have the stim board assembled and im going to go get started on the main board here in a min.
  13. merry christmas eery one!!!! just got done opening some presents and i just got MEGASQUIRT!!!!!!
  14. do you have anything to back this statement up other than obx is junk???
  15. yeah i have the starion one and while it works im going to upgrade... wanna buy mine??? lol
  16. ive done the same thing. i actually got mine bent decently correctly but then when i went to take them off to paint my car they just got all bent to hell. so do your self a favor and just buy the squeegee part and just get some weather strip adhesive and just glue them on. mine have been on that way for a good 4 months and are fine.
  17. ive been curious about this also. is the 280zx power steering pump up to the task of running the Subaru power steering rack??? if so then i need to look for a Subaru rack..
  18. isnt his car dropped lower than 1 inch?? cause i dropped mine 2 inches on my 74 and its not as low as his
  19. im in daytona beach and am going home to kansas which also got hit by the ice storm for christmas. dang i hope its gone by then lol i called my mom and told her it was 80 out today and i was in shorts and a t-shirt she didnt think it was too funny
  20. i bought the cheap RS type blow off valve and it worked but i noticed i had a slight vacume leak. so i took it apart and found out that the o-ring wasnt thick enough to seal so i just put slightly bigger one in and it works great
  21. there should be bolts that hold the flex plate to the converter i think 4 of them maybe 5 just take off the bottom access panel and take them off you will have to spin the motor to do so.
  22. aww my good old home state.. i love the long streaches of road. lets just say i maxxed out every vehicel i ever owned untill i moved. my dad would get so pissed when i would tell him how fast i got his car or motorcycle up to... then i would just rememind him of the stories he told me of how fast he went on his dads cars when he was my age lol
  23. i know on bikes its been done both ways.. either picture a rocker arm that has one follower on the cam and then splits into a Y after the pivotand pushes on 2 valves and then the cam is inbetween the intake and exhaust valves so one side has the exhaust and one side has the intake with 2 y shaped rocker arms. if you ever run into this set up and are adjusting valves you have to have 2 sets of feeler gauges so you can measure the clearances of both rocker arms at the same time as to not cock the rocker arm up on one side.
