jeffer949
    9
Everything posted by jeffer949
  1. yeah i have the starion one and while it works im going to upgrade... wanna buy mine??? lol
  2. ive done the same thing. i actually got mine bent decently correctly but then when i went to take them off to paint my car they just got all bent to hell. so do your self a favor and just buy the squeegee part and just get some weather strip adhesive and just glue them on. mine have been on that way for a good 4 months and are fine.
  3. ive been curious about this also. is the 280zx power steering pump up to the task of running the Subaru power steering rack??? if so then i need to look for a Subaru rack..
  4. isnt his car dropped lower than 1 inch?? cause i dropped mine 2 inches on my 74 and its not as low as his
  5. im in daytona beach and am going home to kansas which also got hit by the ice storm for christmas. dang i hope its gone by then lol i called my mom and told her it was 80 out today and i was in shorts and a t-shirt she didnt think it was too funny
  6. i bought the cheap RS type blow off valve and it worked but i noticed i had a slight vacume leak. so i took it apart and found out that the o-ring wasnt thick enough to seal so i just put slightly bigger one in and it works great
  7. there should be bolts that hold the flex plate to the converter i think 4 of them maybe 5 just take off the bottom access panel and take them off you will have to spin the motor to do so.
  8. aww my good old home state.. i love the long streaches of road. lets just say i maxxed out every vehicel i ever owned untill i moved. my dad would get so pissed when i would tell him how fast i got his car or motorcycle up to... then i would just rememind him of the stories he told me of how fast he went on his dads cars when he was my age lol
  9. i know on bikes its been done both ways.. either picture a rocker arm that has one follower on the cam and then splits into a Y after the pivotand pushes on 2 valves and then the cam is inbetween the intake and exhaust valves so one side has the exhaust and one side has the intake with 2 y shaped rocker arms. if you ever run into this set up and are adjusting valves you have to have 2 sets of feeler gauges so you can measure the clearances of both rocker arms at the same time as to not cock the rocker arm up on one side.
  10. allright got it back in place and everything bolted up. and it fixed the problem thanks
  11. yeah i know the symptoms i read one of your posts while searching. and it was out. i was able to take out the push rod with the seal and its nto in there and i can see it bouncing around. now to just get the dang thing back in place.. thanks a lot
  12. hrmm was it tough.... well this was the first time i had ever done any body work but im the type of guy that will dive into almost anything and after i put enough sweat blood and tears into it it comes out ok(yes i had all 3 of these on this project, it was hot out, and i cut my self on some sheet metal and i guess i cried a little bit about it lol yah yah im a cry baby i know lol) but basically take your time making your patches for the indents on the sides and then just start tacking them in place and then a thin coat of body filler over every thing and then SAND SAND SAND SAND oh did i mention sand? till it looks the way you want. and if you sand to much add more filler and keep going.. good luck there is some better write ups on here on how to do it though
  13. ok ive been having some problems with my brakes and through searching have learned about the reaction disk coming out. so i took off my brake booster to check it out Then i realized i didnt know what to check for. some one said something about it rattling around would this be like a washer rattling around in the booster or more of a faint rattle... Also does anybody have the messurement for length the 2 shafts going though the booster is supposed to be? cause it would be shorter if the reaction disk had fallen out correct?? Last but not least what is the best way to take it apart if the disk has come out with out the special tool that is in the FSM? i tried a pry bar and a large screw driver but i dont think i was getting enough force by myself.. any help would be appriciated thanks Jeff
  14. ok was at the junk yard today and saw a 240sx with the hicas rear wheel steering. and did a little bit of research and found that it could possibly have a lsd in it.. is this correct or am i wrong? Any body have any insight on this? because i would love to put a lsd in my car. thanks jeff
  15. honestly thats like probably 8-9 coats with wet sanding between every 2-3 coats and then i wetsanded with 1000 grit and then put 2 final coats on. i was just tired of wetsanding and it was zfest here in daytona and i just threw my car back together so i had it that week.(i also shaved the sidemarkers and the rear end at the same time) and thats my own color i made. i think its like 3quarts royal blue to 1quart black or something like that.
  16. here is a few pics of my car that i said i would post some pics but i never did so here ya go. these are actually of me being lazy and not doing my final wet sand and buff this was just how i rolled it on..
  17. yeah ive pulled many pistons that looked like that out of my old race 125 two strokes. can we say detonation?? lol. i had one that actually had a hole worn into the center right below the piston. then i guess ive also had the pistion come out in chuncks also
  18. here is my 74 that i did a few months ago. also shaved the complete rear end and bumper indents
  19. what about the steering shaft binding for a second? or more precisely the u-joint thing. i know ive had swivels for a ratchet get worn out and then they would bind up and wouldnt turn.... just a thought.. but glad your safe... and dont you think its time for a subaru forester rack and convert to power steering??? lol i think thats a great "while im at it"
  20. felt doesnt work that well if you have complex curves cause it doesnt like to bend as much ive used it and had to cut and splice it and didnt work out that great
  21. peroxide while its good at cleaning the wound it is actually not that good for the heeling process it actually helps make keloids(abnormal scar tissue) and can make you have some pretty bad scars.. i have tons of them i have more scars than anybody i know from years of racing motocross. and just being a onry kid growing up
  22. 2 of the biggest helps ive found in getting the tranny to slip in would be the spare yoke to turn the input shaft and then make sure you have the engine on the same plane as the tranny. i use the jack that comes with the Z and a block of wood and if it doesnt go in i can raise or lower the rear of the tranny till it slides in.
  23. and he had alot more room to work with because of his crossflow head and the fact that his car was RHD
