yo2001
Everything posted by yo2001
  1. I've been searching around for clutches. I'm going to go with ACT I think. I've not heard nothing bad about them yet. $300 bucks for HD pressure plate with modified street disk rated at 400ft/lb.
  2. Suppose, you can restrict the compressor side with a restrictor. I don't know, I've never actually seen one done like that.
  3. Even with aftermarket gate, the lowest springs are 6-7[si. I guess you could cut it or something
  4. 280 minus crash bumpers and bumper supports weight around 2600lb. 8)
  5. probably too much fuel at WOT. My turbo Z was going dippind down to below 10:1 AFR at WOT on the dyno. Since you loose torque on with too rich of fuel mixture, you feel it sluggish.
  6. How about a link guys? Who makes on ethat's moldable?
  7. what are you guys tuning the MAF with? I searched some lastnight and found that the HKS S-AFC works on Z31 ECCS.
  8. MSD, BBK, Holley, etc are all Walbro 225 I would upgrade fuel pump. It's a cheap insurance IMO
  9. Probably not, since if you got a actualtor that loose, it'll leak under boost (creep)
  10. I heard that the GT series wheel got smaller diameter shaft. I'll go ask about it sometime
  11. 2.22x" exducer is stage III I think.
  12. Yeah, I had to get my head welded so there would be enough metal for the center two EFi intake mounting holes. It can be done but not worth the cost. IMO. I do have a .080" milled E88 head with N47 valves and steel seats that I used to run on EFI motor.
  13. I can't tell you much about the diff strap but I'm working on urethane diff bushing out of OEM unit. I think it's going to work better without much road noise. I'll let you know how it turns out.
  14. No EFI provision on the E88 head inless you machine the head. 8)
  15. Leaded race gas will leave white rasidue. I don't know about NOS.
  16. It's cute but can only carry one one woman at at time
  17. I had a girl keep talking to me about my "Z28." I had to correct her after about 5 times, "it's 280Z." Lately, I've been getting, "your car is cute, who makes them?" "it's written all over the car, "Datsun" !!" I should start telling people that it's an exotic from Europe
  18. Yeah, it won't take much HP to get a 240Z in 13's to 12's. Good luck
  19. I'm running headstuds now since it was only $125 for a set. I was worry about water leakage as Scottie mentioned but I've have not had any problem with the studs on L6. I just got them torqued to 60ft/lb. Only thing I had problem with was trying to get a 12 point 12mm deep socket. It was impossible to find a 1/2inch drive that fit on the cam tower side head studs. So ended up with 3/8 drive (I think that's the size) socket with an adapter.
  20. what do you do if you are forced inducted? I'm goingto go get me a 12 inch one.
  21. only wideband 02 is metric thread I think. It's standard corse thread on my one wire 02.
