240zRacer- My goal is mid 9's.
An Update:
It looks like the wastegate was a limiting factor. I blocked it off with a metal plate and I now hits 18psi. I took it to the dyno again and laid down 695hp and 595tq sae corrected. I also tried out the spool valve again. It works! The car will now hit 5 psi on the foot break. I plan on trying co2 in to the ams1000 boost controller to see if I can achieve the same results as blocking off the wastegate so I have some control. I am very excited to see what I will do once the track opens up again.
Ignore the spike in torque, the dyno was haveing issues with the tach signal. It didn't make 800+ torque. It was more like 595 when you scroll the curser over peak power. To give you an idea of the power band; the power and torque intersect at 5200 and redline is 6600.
here is a picture of the spool valve.
and a dyno comparison with (blue) and without (red) the spool valve
I finally got some time to work on the car again. I Fabricated and installed the parachute mount and bracket.
Mocking up the bars
Welded in some gussets
Under the car between the rear axle and rear sheet metal. The trans cooler bolts over it.
Now with it all mounted up.
I still need to mount the cable and release handle inside the car.
