74
Everything posted by Tony D
I'm going to point out this much, All jesting aside: If the car realy and truly has blowthrough CARBURETTORS, I would throw a Cartech Plenum in the Trash. ITB's and Carburettors are like apples and oranges, and conclusions drawn from one setup in one condition can not be applied to another, and in this case carbs are VERY different than EFI when this particular piece is applied to them. Carbs will have a tip-in transient lean spot that WILL NOT GO AWAY unless you jet your car SO big your mileage gets shot to hell with a Cartech Plenum, or any of the simpler, cheaper, EASIER alternatives like home-made plenums constructed out of 2X4" Extruded Box Tubing. And even, jetted fatter than Oprah, that might not do it mask the transient lean situation. This may have been a combination of things including the flow rates on my compressor... but the Cartech, as well as 'knockoff boxes' and the owners I talked to ALL had the EXACT same problem with a transient tip-in from hikghway cruise that caused bucking, popping, and other ill drivability issues. At WOT, all three of the boxes subjectively felt the same, though above 130 mph, the smaller plenum of the Cartech seemed to be somewhat limiting in the 'punch' when boost came on compared to the HKS unit. Sure, you can make power with them, seen 425 at the rear wheels on some people here in So Cal with that setup...but they all had the same issue as me on transient lean during highway cruise. Your car does not live at WOT. It lives at or near peak torque with miniscule throttle openings most of the time...and the difference between the Cartech setup and the others is like night and day. For racing? Who cares...anybody can make big power, you can use PVC Sewer Pipe for your plenum with epoxied flanges if it holds together. That is not the issue nor the question. Being "JDM" has nothing to do with it. It has to do with the basic engineering behind the airflow into the box under pressure and the resultant issues of fuel metering flow through the main venturis as they transition from idle to main. You CAN use a simple box and pressurize the float bowls and it will "Work"... This is the Cartech Approach. But if you take a more nuanced engineering approach to the issue and want it to 'work' at more than just WOT then something has to be done to improve partial throttle drivability, notably tip-in and light throttle applications. After 30% opening, it works fine. But that transition is a bitch! I never got it right, and countless others had the same buggaboo. They chose to live with it, I'm sure you could too. Should you HAVE to is the real question. With the availability of HKS and SK plenums---the answer is 'no'! For EFI, it is somewhat more suitable. If you have ITB's then a Cartech box would work somewhat better than if you had carbs on there as you are using programmable EFI and can take out the transient lean issue with accel shot or some other form of precise fueling in the 100-120kpa range. (But I was under the impression that this unit was being spec'd for CARBS and not ITB's...) Mine incessantly popped between a manifold vacuum of "0" to 2psi, after which all was good and it ran like a raped ape. But running at cruise at 60 mph, you tended to use a lot more throttle with the Cartech box to make sure you quickly went onto boost at 3psi so the car wouldn't buck or pop. My final straw was driving up a 22 mile grade of some miniscule rate into a headwind, the car just would not settle on a attitude that didn't have it coughing and popping every few hundred yards. I drove this grade several times with the HKS box and NEVER had this issue. It was this annoying drivability issue that cemented my choice to go programmable EFI once and for all. 99.999% of the time, the car was flawless (other than the combined mileage of 17mpg in daily drive use---equivalent to what the car did with SU's when it was N/A!!!). Putting that smaller plenum on there screwed it all up. There is more to boosting a carb than simply putting a box on the inlet and jetting it fat (Which is what you have to do with the Cartech). At that point I simply wasn't going to get into making modulator rings and doing testing on them. I had had it. I'm sure with modulator rings I could have MADE the box work, and likely I would have needed 32 or 34mm Modulator Rings. But why screw with it when an EFI system won't have that issue at all, and instead of fixing a problem mechanically, I can tune it with the hardware currently on the vehicle. And if I cam it later, I simply click some keyboard keys and I'm done, instead of getting out the Bridgeport and machining aluminum sheets... Curiously, when I boosted mine for the first time using the HKS Style box with the jetting from the car in N/A state, I went REALLY rich under boost. I actually moved down in some of the jet sizes when putting a turbo onto the same carbs on the same car, on the same engine. Anybody who says 'carbs are easy' in reference to jetting under boost hasn't done it, or had the results quantified independently! But I digress... Even for EFI, as MONZSTER is finding out, the plenum selection for an ITB setup is more than simply a box as well, and baffling the inlet to allow for diffusion of incoming airflow makes for a more balanced and equal flow into all cylinders under boost, rather than starving the first two at the expense of overfeeding the rear two...which gives the nod to the HKS and SK plenums even in ITB service as well. You may think you want that Cartech Box....but when you try the alternative and do it over long enough of a timeframe you will see what I mean. A curious historical note, Jim Wolf Technology in the 80's was making blowthrough carburetted setups. He utilized the HKS Type-1 Box, and not the Cartech. With the HKS box ALONE selling for over $1000, why would he use that box over the Cartech system which I'm sure he could have gotten a big discount on as a volume seller? Why did JWT choose the HKS Type-1... Just a note in history that makes you wonder. I didn't know about this till two or so years ago when someone sold an 80's built JWT L-Engine and it was confirmed that was the configuration. I didn't think ANYBODY here in the USA was equipping these engines with HKS Turbo Components.
Yeah, the big number IMO is around 350. If you plan on running track days and making more than 300-350 getting beefier stuff inside is a good plan. Below that, and with less track use, it's like 'double-secret probation'---you're the only one that knows it's in there, and until something goes 'boom' nobody else will ever know, either. Most of Jeff's money is because he did that over the course of 20+ years. When taken in that light, and the fact that he recorded the thing scrupulously so he actually KNOWS how much he spent (including the original purchase price of the vehicle, as well as a major crash repair) the costs really aren't out-of-line with what the majority of the people here have spent really. It works out to around $2500 a year, give or take for years where things went 'crunch', 'Snap', or 'Boom'---to that, even myself, I must plead "Guilty"...and given how good his look, and how crappy mine look, that doesn't bode well for my cosmetic asthetic! LOL (Come to think of it, Pal Pal says I have 'reached my spending limit' which apparently is $10K...WTF? That couldn't be right....)
Like Greenmonster said, Type 1 can be either-or. Many times a forward facing adapter was put to the 'dual inlets' when intercooled. Though again, the pipe coming in from the bottom worked nicely in a 5-10 psi setup unintercooled. It was well over 200HP on a stock L28 in that form. I have seen the Type 1 boxes with over 600 HP (444Kw). Type 2 Boxes were used in later years and have some advantages in packaging, and slightly different internal airflow.
Were those standard sized journals, or 0.010" undersized? I have seen that kind of breakage 15 years ago in Japan in racing cranks, I don't think the parts age had as much to do with it as the conditions it was placed in. I have seen undersized crank journals break like this because of the improper grinding of the radius (or lack thereof). Was this crank magnafluxed before being put into racing service?
Crankshafts are plentiful, and cheap. Cheaper than the inserts, in fact here in SoCal. I think most junkyards like PYP are around $35-40 for a crankshaft. And it's not like there aren't hundreds of cranks out there waiting for harvesting. Unless this crank has specialty machining, or has already been magnafluxed or something, I'd skip it and just get another one and stick it in there. If it was $1500 for a crank, that's one thing. But for under $100....
Neat, I like old stuff like that. I can't imagine loading that thing. Normally naval guns were '10 pounders' meaning they could cast a shot weighing 10# a specified distance. That has to be some sort of Howitzer Round with a big loft to it, as I don't see a single man (like on a horizontal cannon) loading them alone. But a 'drop in Howitzer' could be loaded easily by two men with that load. I was boonie stomping near my house when in Okinawa, and ran across a 4" Naval Warhead just sticking out of the coral cliff. I left it alone... Two years later we got an evacuation notice, I figured someone found it and EOD was clearing the area...I was wrong. They were digging foundations for a hotel directly across the river from us, and dug into a 15" naval projectile, and then several other aviation-related bits of ordinance. From what I understand those 'clamshell' driveways you guys in MD and DE are happily installing routinely get small ordinance like Grenades and etc from the dredging operations. Apparently troop ships were not that far out before they got the troops practicing to stay sharp. And dumping from Aberdeen was done wholesale in the ocean. Mmmmmm, new driveway and pinapples start sprouting! LOL I'd roll it someplace to the front of the house, and use it for a conversation piece.
Maaaan, I tried to be circumspect and you guys went and gave me mental images that were worse than good old clean matted pirate beard... Thanks alot!
Yes, avoid #1. #2&3 are HKS Type 1 #4 Looks like a polished HKS Type 2, with 'HKS Surge Tank' ground off. The BOV is mounted exactly as my Type 2 is, and looks to be the same BOV as well...I would think if they were making a knockoff, they would use what they could find, rather than HKS Application SPecific Hardware. Note the Radiator support work on that Red Car! Ahhh, memories!
Oh dude, you're crucifying me for 25-30 HP?!?!?!?!?!? My dyno runs were only 17psi, I'm sure I was closer to 400 at 21-22psi, I just never verified it on the dyno... The old 'Shark Car' was daily driven with a Blowthrough Carb setup. And it was an N/A with 8.5:1 CR with a JDM N42 head/block... My drivability problems came after I stupidly changed the design for my plenum from something that was working, but hitting the hood lightly, to something that 'looked cooler'....BIG Mistake. I stopped driving it because I wanted to freshen up the car after 10 years of beating on it almost daily...put on some EFI, etc... Then 'Life Happened' and it sits, resting, waiting for the day I return to it with wrench in hand, ready to ressurect it. I'm not sure how well you know JeffP, I know he has commented on how nice your car is, and his car is well above that HP level and is really streetable. Totally. He'd drive it daily if he'd get the EMS system sorted out, but for daily drivability it's easily doable. That aside, to the question at hand: CR. Either is acceptable. If they have to dish the head to give you 8:1, MAKE SURE they replicate the combustion chamber in the crown of the piston, as you want that flat quench area in there if at all possible. My guess is 8 and 8.3 are their standard cuts, and that is why they 'suggested them'. The CR will depend on what Combustion chamber you currently have. If you 'spent a lot of money on the head already' then I can only ASSUME that the combustion chambers were welded and reshaped for higher quench and proper fastburn design---in which case 8.5:1 would not be untoward at only 400 HP. And if you are running Alky Injection...then the CR could be much higher as it really slows down the burn and cools it all down, preventing detonation with setups that would never live at the levels people drive them to. A Smarter idea is to build the bottom end to accomodate the power level WITHOUT the alky, and then use it as a detonant supressor for standard pump gas. That way if your tank has run out for the evening, you can simply knock off a pound of two of the boost, and drive home without worrying the thing will detonate when you get into boost the next time up the long hill home.
I can respect Ernie's thoughts on "old versus new technology" if he really thought the new technology really was a superior technique. But I also have to say that Metallicar's comments also hold great weight, and are along the lines of my thinking. My job requires me to update to new techniques almost all the time. Thing is many of the equipment I service and maintain are built 30 or more years ago. In many cases, buys ONLY taught on new techniques will have absolutely NO idea WHY any of the existing modifications are on any particular piece of equipment. I work with Engineers that have worked on this stuff in many cases for 30-40 years. They are continually amazed that I pick up stuff from old supersceded technical bulletins that are still applicable to newer equipment. It's referred to as 'institutional heritage'---at another site where 'technical information' can and many times is spurious at best, pulling an old post is not a big deal. But when the information is historically correct, there IS a place for it in the archives. Sure someone can say 'they haven't done that for 20 years' but if you are doing it on a 20 year old piece of equipment, and you KNOW IT LASTS 20 YEARS... See where I'm going with this? Manny techniques that are 'new today' may not be known to last more than 10 years...which is a commercially acceptable timeframe in the trade. But some of the old techniques have been known to last 20+ years... Which do you prefer to learn? Something that is current, new, and may last 10 years? Or something old, that you know will last at least 20 years? If Ernie really did think it was a technological update worthy of abandoning the former technique, I would say the preferred note would have been an '' notification at the beginning of the post warning about an updated superior technique that is available. That is what I would do, and probably is a better than simply removing the whole post or series of posts, as you can see what kind of impression that can make. As for printing in PDF, I don't know about 'Docucom PDF Driver' which came with my HP scanner software, but I have been VERY happy with my Nuance Software that came with Paperport 9.0 and above versions (up to V11 I believe). I have used it to print and generate PDF's for years. It's a driver that shows up in all your 'print options' and allows you to make paperless PDF's of anything you could normally print to a printer. Paper Port allows you to edit all PDF's as well, and it's OCR stuff with a companion piece of software works well from what I've been experiencing (Omnipage 15). Many pages and documents are 'printed' this way when I'm on the road, and it's a GOOD idea when archiving pages such as these.
lightening Bad Dog subframe connectors
Tony D replied to Pete Sprenger's topic in S30 Series - 240z, 260z, 280z
I wouldn't lighten them in any way, there is...as mentioned above...plenty of other non-structural areas on the vehicle to take weight from. Seriously, how much weight will you save? I have seen a 240Z where the fenders were reproduced from Nissan FRP pieces...only in Carbon Fiber because the fabricator thought they 'weighed too much'. After he got the CF pieces, he realized the aluminum bolts that attached them were now about .5mm longer than they needed to be. So he then cut all the bolts to length. While they were in the lathe, he also gun-drilled them...and then touched the heads with a ball mill to scallop extra weight out of non-structural pieces. The same car also had Titanium A-Arm pivot bolts manufactured, which were similarly gun-drilled to save weight. It's all a matter of where you look to save weight, curiously on the car above, the frame rails under the car were untouched in lightening efforts. If he skipped 'em, that tells me something... -
Wow, I thought it looked like exhaust tubing! 0.063 wall...not for me! I once had occasion (and believe I may have it on a VIDEO someplace) of seeing a Jeep CJ3B that went airborne, inverted, and landed on what LOOKED to be a substantial rool hoop. In fact, it was cast drain piping that was butt-welded from straight sections and elbows. Shattered on impact, pinning the driver under the vehicle. From all outward appearances it looked just like a brand-name commercially produced roll hoop. To think people do this kind of stuff is scary. Ignorance / Stupidity is one thing, but to do it intentionally whatever the reason is criminal. I hope nobody actually charged to do that job, and it was just some misinformed homebased hobby-builder who didn't know any better. I have teched some stuff where it was obvious someone welded washers into thinner tubing to give the appearance that the tubing used was 'specification'...that was a short tech session.
#12 in my case... When we were doing prep underneath the Hemi, the combination of a Santa Ana Summer Day, a Blasting Hood, and several hours of sweat matted me to look like Capn' Jack. Normally my Parakeets will 'groom' the strands when I return home and sit down, they got close, sniffed and fleww off---causing my wife and son much entertainment. So from a Parakeet's point of view, there is much funk in a day-old sandblasting beard. For myself though, I didn't notice a thing... Then again, bacon falling into my lap from breakfast is not an uncommon occurance, either, so maybe I'm not the best hygenic example...
There is a fuel pulsation dampener available (JeffP installed one on his car after installing the 720cc injectors) and for the price it really eases the job of the fuel pressure regulator. With that little accumulator/bladder arrangement the pulsations are evened out quite a bit meaning the FPR is not slamming open and closed to try and maintain the same line pressure---if you have smallish supply lines that will be an issue.
Agreed, the dash gauge is useless. Use a gauge that is known to be accurate. As long as the engine temperature is above 170F, all the stock ECU functions will be so near the 'normal operating temperature' status it will affect nothing (technically the magic number is 177F.....)
This is why I say 'chemical overall, and blast spots'... This did not stop me from snatching up a 185CFM Diesel Driven I-R Portable Compressor when I had the opportunity. Hey, it works, and can run those big commercial hoppers you see at the rental yards... Free is Free! It also makes a jackhammer/chipper work wonders on my clay soil and granite outcroppings in the back yard, especially when it's time to set fenceposts.
Hello' date=' Triple A? I need a tow from Tustin to Riverside. Yeah, my number is blah blah blah... Uh huh, what do you mean I don't have Platinum Plus Service any more? WHO cancelled it? WHEN? No, I'll just drive it home, I was hoping to save the turbo...but maybe I can get it home without using boost much... ______________________________________ Next Call: Honey, why did you cancel the Platinum Plus AAA Service? Oh, it was $100 a year instead of $68 and it was 'wasted money'? You do realize now I will have to drive my car home with a bad turbo, and it might burn up the bearings, it's howling like mad if I boost it. You saving $32 a year in tow service 'we never use' by cancelling it the month BEFORE MSA, will likely cost us $752 for a new turbo! No, I'm not paying for it! YOU cancelled the service, you are going to buy my new turbo, honey! There goes your Emerald Ring this June! (And no lie, that is EXACTLY where the money came from: Emerald Ring Fund! Took her 6 years to get that ring...) Every time she wears that ring, I remind her about how a Turbo as more metal than the ring, so it means more to [i']me[/i]! I digress.... "Stupid Tax" I turned it around on her that year. Take a woman's jewlery out of her grasp and make it clear it was because of something she did...and they will start thinking about 'saving $32 a year'! What I should have done was say "Well, at $32 a year, it's going to be another 20 years before I buy that ring!" But that would have had other consequences....
I have seen this in other places (sites) when people decide to go, they 'pull the plug' and go back and pull their posts as well. I understand why some people feel the desire to do that, especially if they feel they have been 'run off'...kind of a 'if you don't want me here, then I'm taking my knowledge (ball) with me when I leave'! Not saying one way or another wether it's good or bad. I probably have been tempted to do that at one time or another myself. Usually my [.] posts are after I have done things like called someone out to change one of their threads... Once they do it, I cull my own post. But that's something entirely different than undermining the estabilished, historical knowledge base.
How so? Set up a 100% Grade, and do a 7000 rpm holeshot with the car strapped to the Mustang, and I lay money something will give, and my thought is it will not be the drum or 5" Driveshaft on the Dyno's Braking Mechanisim!
I might be wrong on my calculations, but the formula I was using was from an old trades book for calculating fluid flows in piping. I am sketchy on the particulars now, but it involved using a steel square for determining the diameters of the two pipes you wanted to flow into a single, or vice versa, then using calculations derived from triangles to come up with the diameter of the third pipe. A2+B2=C2 kind of thing. You know, the diameter of one pipe is one leg of the (right) triangle, the other diameter is the second leg, and the Hypotenuse is the required piping diameter for the 'single' pipe. It's mathematically correct, and has been used since the 30's as far as I know for calculating fluid flow capacities on jobsites... i.e. Two one inch pipes would flow the same as "the square root of 2" piping if you follow that. Cross sectional area may be different than what some are talking about. Which flow calculations are being referenced for these last few examples? Speaking of 2.5" piping X 2, my example was 3.53" equivalent, not 4". What does the calculation for cross section come to show using that example? Using my formula twin 3" show approx the same flow as a 4 1/4" pipe... It seems in checking the math your examples are working exactly the same as my calculations and formula... Now curious... Matter of fact, now that I go back and read what I wrote, I suggested using twin 2.5" instead of a single 3.5" pipe, so what is all this cross sectional comparo stuff doing now when it is nowhere NEAR what I was suggesting or comparing? I would still say packaing twin 3" is STILL a lot easier than trying to fit a 4" in the back of an S30, or S-130!
Making a series of 0.030" sections and then submitting them to a rapid prototyping company to do a lost-foam process would not be that difficult... I second the idea of another thread to see that scale 13CID L-Motor! That sounds REALLY, REALLY COOL!
No, I never said that. I said that with 100 passes down the track, you have maybe 10 laps at a reasonably sized track. I don't know where the failure point is, but given most of the races they had were less than 2 hours in length, extrapolation of 'time under full load' could be done. If they didn't trust them for a 2 hour event... As for dragracing-vs-tranny failure. Torque. Bonneville is a nice place where people run stock trannies, and then find out stuff drag guys never find out....like the stock RX7 transmission has a flex in the countershaft that allows both 2nd and 5th gears to engage when passing through a turbocharged RX's torque peak at over 140mph... Made the car jump airborne, do a 360, blow the transmission out from under the car, and then do a series of flat spins... Depending on the torque you put it through, and how will determine when it fails, right off the line, or down the end where you're going much faster... Also, I believe I mentioned SMALL end deformation or elasticity. The gudgeon pins scored the walls. I mentioned nothing about the big end and loss of oil pressure. This is a function of piston weight, true...and of rpms and the length of time at the rpms. I would say the small end indeed stretched and returned to normal size as when checked it was all round and to spec size---the only way the gudgeon pins will move to the walls is if the small end stretched and let them move! Unless you are on a Mustang Dyno where you hold your peak HP rpms (under load) you will never replicate the conditions. The inertia dynos just pass through the rpm ranges too quickly.
When I knocked off the HKS Type 1 Plenum, my air entered the box on the fenderwell side, and hit an "L" Shaped baffle plate that directed it to the floor of the plenum, where it diffused through a seried of holes drilled in the 'foot' of the "L". This gave very nice drivability compared to the rough 2X4" aluminum extrusion I retrofitted to the engine years later with the air entering near the distributor end of the plenum, unimpeded. Packaging the piping was easier, but it just wasn't the same engine after the plenum change. I feel much better now that someone has acknowledged my years of rants and howls as more than just bluster...
At last, someone else who can speak on the 'twice pipes' workability. In the JDM, as many cars already had the 'header exhausts', HKS made a Downpipe for the stock turbo that hooked to the 50mm HKS Sports system for the S30, I ran that 2.5" downpipe into twin 50mm pipes for years on that system making 350hp. 2.78" flow equivalence. Now Ian has inspired me to make a twin 2.5" setup (making the closest approximation to 60mm tubes this side of the pond). Why fight trying to fit a single 3.5" pipe back there, when twins package so much more efficiently. As I recall, there was an S130 Exhaust that was popular that ran 90mm pipe in the center section of the tunnel, then branched out to twin 60's on each side of the car...easily passed above the rear subframe just like the stock muffler tubing! I believe the front section was set up at owner's discretion to either accept dual turbo downpipes or a 90mm turbo downpipe. They had such cool stuff in the JDM, and they weren't trying to fit it around a steering shaft!
"600 HP is all the stock rods are supposed to be good for? Hmm. I remember when people said that about stock 2JZ pistons and rods a few years back. Now people make an easy 800+rwhp on them." The difference is the 2JZ was people without any experience on the engine making the claims. The difference here is someone like John Caldwell of Electramotive found out failures firsthand in the 80's. They may have been detonation related at that power level, but they would not use stock rods in endurance engines, and those classes that required stock parts got changed regularly....like NHRA Top Fueler Parts. Making 600HP on a run down the dyno, and 100 passes down the drag strip is only maybe 10 laps of a road course. Drawing conclusions on durability this early in the development stage is foolish, especially when others with far larger budgets decided they were not going to risk their engines (or race winning record) on a properly-prepared stock rod. And this was the best in the busines making this decision... The rods were a compressive failure as I recall, splitting down the H-Beam beneath the gudgeon pin. JeffP does not have stock rods in his engine, either. Our Bonneville N/A engine walked the pressed-fit pins to the wall... Stock rods seem to get slightly 'elastic' on the small end above 8200rpms, and then have compressive issues at the BMEP encountered at or above 100 HP/ Hole. You freshfaced engineer-types should easily be able to calculate that BMEP point on the bore diameter, I'll leave that to you, see what you come up with! And remember this is true engine HP that can be extrapolated back to SAE standards. A Mustang Dyno can be back-extrapolated, most Dynojets are not set up for that kind of accuracy. So the type of dyno you run on will inflate the numbers as well. KTM will verify the difference between the HP shown on the Mustang at Dynamic in Lake Forest and the DynoJet at DRS in LaHabra can be startlingly different: 20-25% in some cases. Even Dynamic's Owner said he will warrant you show at least 15% more HP on a Dynojet than what you will read on his Mustang. But his Mustang is calibrated and traceable to a Set Engineering Standard set by the SAE, so take that FWIW. If JeffP wanted to do the brag thing, he would be using his Dynojet numbers, not his Mustang numbers...that would put him above 570 RWHP, misfiring like crazy about 6300rpms.
