Not sure if you are looking for one for a turbo, but I can tell you they dont work very well. I have larger fuel lines. (240z w/ 75 efi tank), If i dont keep at least 1/2 full i will go lean under boost and its ugly ... plan is to install surge tank
I assume this has been answered but I could not find anything clear . So I have a 240 swapped with a zx turbo. It looks as if the PO cut and bent the original linkage to make it work. Can I just start over with a 280z linkage and bolt it up to the fire wall? Seems logical . I have a 240sx throttle body on there now I have seen people using a cable with the linkage on the outside of the intake . If I go this route can I flip the throttle body upside down ?
I am looking at a set of wannabees wheels 15X8 +40 offset on a lowered (eibach/illuminas set up) The price is fair but I not sure if they will work. I know I would need spacers but I also have read some negative things regarding bolt on spacers. I am running 250-300hp. Any advice would be appreciated. I searched but did not find much on running that much.
Thanks
DC
I had the 3076 w/ a 1.06 turbine. did not build boost till 3000rpm. then took off like a rocket. Moved to a borg warner efr series. Be ready in few weeks let you know how it goes
Like to find one front and one rear for a 71' 240 Early if it makes a difference. Need to be in good shape since I have rusty ones.
Thanks
can trade or buy
I am no means an expert but... Why did you take the head off ? not because of an intake leak I hope . I think that kind of boost will blow it up pretty quick. I bought mine already built, Forged pistons and shot pinged internals metal head gasket and the build sheet says built for 20lbs. I have run about 1 bar. I think your goals are pretty lofty but as said I am no expert. Better get to some porting and polishing
I I got mine from wolf creek racing. i think viscous LSD. not sure if its the same spline count. I got lucky and found my sti rear on a Subaru form I think at 200 shipped with a stripped oil drain bolt.
