Dayz
Everything posted by Dayz
  1. Yes one is really bad...I could do something with it but I am doing a full rotisserie restoration, I should change those !!! Thanks
  2. Hi. I need the Strut bearing Upper number that goes on top of the front struts. VB is selling them for 20$, Nissan for 55$, I went to timken cross-reference and can't find it. Thanks Dayz
  3. Front Bearing numbers Part / Type Location / Timken Part Number Seal (Inner) 1188S Set (Inner) SET6 Set (Outer) SET2 Rear Bearing numbers Part / Type Location / Timken Part Number Seal (Inner) 224270 Ball Bearing (Inner) RW116 Ball Bearing (Outer) RW117
  4. Thanks Jon, This site is a keeper. This will save me a lot of time, Dayz
  5. Hi, Does someone know the front bearings number? I have the rear numbers but not the front. I need the number for the bearings type and size, not the Nissan part number. Thanks Guys Dayz
  6. Just finish taking everything out... 1- I had to drill both side of the nut so I can hammer it out. They were stuck like $%^&. I will re-tread them, i havent damaged them to much. 2- My Hydraulic press save me a lot of time. 2 hours for both struts out and back in. Not bad
  7. Ezzzzzzzzzzzz is right, just call your bearing shop !!! You pay around 1/4 of the price. Just keep your bearing so you have the number, same thing with the seal. Remember, they make the part to fit around the bearing, they don't make the bearing to fit around the part.
  8. once the tape is off, It will look awesome. i beleive the white line ( the tape) makes it weird. Nice combo in my opinion!! EL
  9. Here you go, You guys in the US don't have to pay some taxes!!! It is cheap for you, lucky guys. http://zero-rust.com/ Dayz
  10. Racerx, From their application guide: "A reduction of 15-20% Xylene is typical. Recommended thinners are xylene, acetone, lacquer thinner and acrylic enamel reducer..." I wanted to use xylene at first, didn't have any close by. I called the support service at ZR and they told me that acetone worked well. I will show you some pictures, you will be able to tell me if it is OK !!! Why xylene is a better than acetone for instance in this case?. I am pretty new to paint, but I like it. Thanks
  11. I finally painted the underside of the body with zero-rust. I had to thin it with acetone and it went very well. This is the second time I paint and I am surprise with my performance. Now, I need to paint the engine bay in red and topcoat the underside of the body. I was thinking of using the 3M undercoating product !! I will post some pics later. This paint is very hard…good thing !! Dayz
  12. That is exactly what I have been thinking for the last year. Since I moved here in the big town, let's say that people that work on their cars are far and few between, I haven't been able to find anyone yet!!! I remember those days where we were putting a tranny at night, finishing everything, going for a spin that lasted a couple of hours and closing the bar at the end of the night. Those are great memories !!! To answer your question, we are working alone on our car, we don't want to meet the car club because it is boring and our passion is into building!!! If you stay at home, you won't meet anyone and if you go out you lose your time !!! It is like finding a girlfriend. LOL Open up, show to people what you have, teach them...etc !!! I wish I had the answer. We are all in the same boat, too bad we live in different states.
  13. Fastzcars, Why is there a huge spacer between the Viper cross member and the frame? Won't this change the alignment, or maybe change the location of the pivot point? Dayz
  14. I would call your bearing place with the seal number and get it fast and alot cheaper !!! Next time I pass by Ottawa, I will make sure to stop!!! Dayz
  15. Dismantle your lock and go to a locksmith...They will make you a perfect key, or just change the lock !!! Cheapest way. Dayz
  16. Thanks to you all, thanks Ernie. 1-As for my surface, I will do as you said, clean it the best I can with Acetone the disolver I found that works the best. 2-I will shoot 4-6 light coats , in order to get 3-4 mils as they say. Should I spray more coats ? 3-Why don't you use the metal prep powder? Just for information. I have been working on redoing all the floor boards, some support here and there.. I guess I didnt too bad !! I wanted it too look like factory so I spent more time to build exactly the form and curves as the original. This car is for my father, at his age no need for too much power.
  17. Buy some good winter tires, Snow or ice depending on witch you have more. Here in toronto there is always black ice and in Quebec always a lot of snow. It is so much more pleasurable with good tires. My Stealth 4wd is great in the winter...just need good shoes !!! Without those and the 340 hp I am in the ditch in no time. Have fun, Dayz
  18. Hi, I am now ready to paint my floor boards, fender wells, underside of the body and... There are some pictures that are attached. I would like to know how clean does the surface have to be to paint ZR and have the best results. ZR gave me a metal prep (powder) with the paint and gave me some steps. 1- Is my surface clean enough, please explain your steps when you are painting ZR? How do you clean your metal before painting. 2-If I paint over existing undercoating, will the paint adhere to it? 3-How long do I have to wait before painting a topcoat? I have read that after 2 weeks you should be fine. This is the rear underside. You can see that I clean the metal on one side but the rear part is in great condition. I just want to paint over it. How should I handle this job? http://img.villagephotos.com/p/2006-2/1147634/IMG_3339.jpg This is my floor, need to clean it a little more. http://img.villagephotos.com/p/2006-2/1147634/IMG_3349.jpg http://img.villagephotos.com/p/2006-2/1147634/IMG_3343.jpg Any advise would be really appreciated. Thanks Guys Dayz
  19. Nice car, I beleive those Graphics and that paint scheme is to attrack a little bit of attention in order to repay this quite expensive toy !!!
  20. It won't go that fast for sure with no gas pedal !!!! Hihihi
  21. The cheapest way to go for piping is your truck parts store!!! Those truck intercoolers are pretty much all 3", I believe I paid 10$ per feet of silicone hose..It was written Caterpillar in Yellow ...Lol
  22. This is perfect for us, we are also builiding a RV7, same thing as the guy !!! I will keep this info. Thanks Dayz
  23. J, Beautiful website !!! Picture is one of my hobby as well. I wouldnt use the Gator guard, from previous experience, the corrosion started from between the bedliner and the metal. You could do like 240zhoke or me and spay Zero-Rust and use 3M product as undercoating. You can get the product number in one of 240zhoke posts. Dayz
  24. I t I were you, I would keep your Z32TT original, buy used engine from japan, they cost almost nothing and would take you a week-end to change the engine. Cheapest solution, easyiest solution. Good Luck Dayz
