cygnusx1
    6
Everything posted by cygnusx1
  1. As good as the bodywork and paint turned out...I was disappointed when I saw that the colors were off. Â The basecoat turned out too dark and the clear coat made it even darker. Â When I had it in the sun it was too much of a difference to leave, after all that straightening I did. Â I just couldn't leave it. Â So today, I stripped it all back to the original layer of paint, and redid the glaze/sand/prime about five times to get the surface dead nuts. Â It's perfect in primer right now. Â I had a body supply store mix me up some paint that SHOULD match, and I bought one of the Preval cartridge guns. Â Tomorrow, I'll do my final sanding on the primer and shoot the base coat again. Â I hope it's a closer match this time. Â Damn that's a lot of work. Â I have a major respect for you guys that do your own bodywork and paint! Â Wow. Â Â Â Â I also bought a rattle can of 3M Clear from the supply shop. Â He said it should lay down nicely. Â We will see. Â I was happy with the Dupli Color clear so the 3M should be fine too.
  2. N/A motors have the sender directly in the block. Â Turbo motors have a dual outlet fitting that feeds oil to the turbo AND to pressurize sender.
  3. At the peak of my career as a shop floor sweeper (yes that was my favorite job so far - low stress  seems that nobody ever messes with a guy that pushes a good broom), I used to clean oil from shop concrete floors by throwing down some litter, or absorbant, and grinding it into the concrete with a brick or a block of wood.Â
  4. Condos and DIY people, can't coexist.
  5. Use your ears and your hands to feel around for vibration, knock, and movement. Â Grab each part of the drivetrain while someone else rocks the car. Â Your hands will "feel" slop much better than your eyes can see it. Â You ears will help pinpoint the location. Â I agree it does not look excessive but the noise it makes in your video does sound like something is loose. Â Check the two big nuts on the back of the diff.
  6.  The car was painted a single stage urethane back in 87 after a hailstorm. It was stripped to bare metal and the front panels were all replaced. It sat in a garage that was sunlit all these years.  So the paint was oxidized and a little faded in spots.  The repair is a shade darker than the rest of the car but I don't mind.  It's not a trailer queen.  The touch up paint came from http://www.automotivetouchup.com/  It's a base coat clear coat system.  I just bought the base color in a rattle can.  It happens to be a Ford 2H Medium Cabernet from the 87 Mustangs.  For the primer and the clear coat, I used Dupli-color products.  The fillers were 3M. http://www.automotiv.../paint-code.htm Mark, (moritz55) from over at ClassicZcars also gave me lots of pointers.  Check out this cool spray gun he told me about. CO2 powered and reusable.  If I hadn't already had the aerosol cans, I would have used these. http://www.tcpglobal...pot/preval.aspx
  7. It's not mirror straight because I should have used longer sanding blocks. Â It's still way better than a dent. Thanks for the beers! Â I think I'll pop one open with dinner.
  8. Â I had nothing to lose by trying to fix my door dent. Â I had met a guy at the car show on Sunday, that did his own bodywork with off the shelf stuff, and it looked great. Â He gave me a write up on how to do it. Â It inspired me to try my hand at it. I hammered out the dent as flat as I could, used body filler, 80grit, body glaze, 220grit, primer, spot glaze, 320grit wet, primer, 320grit, primer, matched rattle can paint, several coats of clear rattle can. Â I am going to let it cure for a couple of days and then either wetsand it with 1000 or 1500 and then compound it. Â I am very happy with my first venture into dent repair and paint. Â The local bodyshop quoted me $1300 to fix the door and a small ding in the rear quarter. Â I did the door for about $50. Â AFTER HAMMER AFTER FIX
  9. My 3 year old points out the parts on the floor of my garage and ID's them! Â He does get scared when I hit too much boost, but he keeps asking me to "go turbo". Â My wife has learned to trust my driving so she just whimpers a little when I hit warp speeds, mostly reminding me that we have a kid now. Â My son says he wants to build a yellow Z.
  10. I posted this the other day at Classic http://www.classiczcars.com/forums/showthread.php?t=38373
  11. I found this interesting. Â And we think todays cars all look alike. Â 1951 Ferarri 342 America 1953 Chevrolet Corvette 1955 Ford Thunderbird 1957 Ferrari 250 GT Cabriolet 1956 Ferrari 250 GT Berlinetta 1953 AC Ace This is an interesting read as well> Â http://books.google.com/books?id=glKW-Kh-lmcC&lpg=PA1939&ots=uD_m1Aigab&dq=1945%20alfa%20romeo&pg=PA1939#v=onepage&q=1945%20alfa%20romeo&f=false
  12. Â My friends 280Z stolen back in the 80's was recovered with it's hidden kill switch still in the off position. Â They don't need to get it running or make it drivable to steal it. Â In some cases the tricks work, in some they don't but it's better to have made an effort to protect it than not. Â Â
  13. Oh absolutely don't limit your swap potential to what I listed. Â Those are just search terms to get your mind rolling. Â But BE SURE the chassis is good before you bolt $2500 onto it.
  14. Condolences on the loss of your uncle. Â Welcome to the site. Â What is the current condition of the car? Â Pictures? Â $2500 can dissappear REALLY fast if the car is not clean already. Â You have identified realistic goals for the car. Â They are readily attainable goals using the knowledge on this site. Â Use the search feature and here are some keyword pointers. Search here for: Turbo Swap V8 Swap RB swap Read the stickies at the beginning of the suspension and brake sections. Â After you do some reading and some assesment of your 240Z, we can help you much more!
  15. You can come back now, all the Porsche haters are gone. Â We need Z updates, Miata updates, and Porsche updates!? Â
  16. I had most of the parts laying around, under grease, and since I "found" the time, I figured I'd put all those old Z parts to use....it took a lot of elbow grease. Â Elbow grease is free here. Â Â
  17. Sweet ZX! Â I only put about 2 miles on my 83 Turbo ZX before parting it out for my swap but it was so cool driving around at night (no plates or reg) with the T-Tops off. Â Good luck with that one!
  18. Â I am running the 2 row core aluminum radiator shown in the pics above. Â I paid $99 new, on ebay. Â I feel guilty because it's probably not employing anyone in this country....but hey I'm unemployed so I gotta resort to the cheap stuff. Â Anyhow, it works. Â I use the mechanical fan on it. Â It had a small microscopic pinhole in the corner weld of the top tank. Â I discovered it after noticing that the underside of the hood was getting sticky. Â A rat tail file over the hole and JB Weld fixed it right up. On the drivers side edge, the aluminum channel is a perfect size to wedge a snapple bottle into. Hold it in with a zip tie. Â I use one as my overflow/expansion container. Â Drill a hole in the cap and stick a hose to the bottom of it. Â Works great! Â You can see the snapple bottle in this pic.
  19. Yeah, aside from sounding like garbage when you time a bad shift, it's holding up. Â I figure, everything important is in good shape, so it's safe, and when it finally breaks or gets worse, maybe I'll actually pinpoint it. Â
  20. Good luck. Â I have been under my '76 280Z for 20 years, have changed/upgraded EVERY single drivetrain part at least once, and have never gotten completely rid of the clunk. Â Mystery to me. Â I think it's just a combination of tolerances. Â A little here, a little there, and it clunks. My '72 240Z bone stock other than the L28 motor. Â ZERO clunk, and I mean ZERO! Here is a little diagnostic tidbit. Â Put the car in 1st gear on level ground. Â Creep under the car as far as you can. Â Have someone roll the car back and forth, bumping it against the engine. Â You will physically see where the slop is. Â My 76 will roll back and forth an inch or more, in gear!
  21.   Nearly fully loaded 2010 Kia Forte SX.  Good looking, 175hp, back seat, 4-doors (coupe shown in my pic), 6 speed, 17" wheels, well under 20K, warranty.
