DuffyMahoney
    14
Everything posted by DuffyMahoney
  1. I love it when a plan comes together. Happy Friday! Vintage SK ITB is coming along nicely
  2. Got them cut. Next is more test fitting and then surface finish to match.
  3. From idea to test Fit in a week. Cnc cut next week. Only tweak is matching the step and radius of the step to the throttle bodies. This will be a decorative mount for a single piece fuel rail.
  4. with the injectors not being in an ideal spot, I really am trying to find the best spray pattern.
  5. 315-450 cc or 30-40lb. But I still haven't figured that all out yet.
  6. Well this looks good! Next project is to figure out is the single piece fuel rail and mounts plus injectors. Then they are ready to go on.Vintage SK ITB is coming together.
  7. Making vintage 40mm SK throttle bodies into 45mm. Machinist was amazed on how square they are. .003 off of true center. These are for Andrew Kazanis as a thanks for taking such good care of my 3.1L IMG_0189.mp4
  8. Pretty proud of how these vintage SK throttle bodies came out. All new zinc, shafts and butterfly’s. I can’t wait for them to sing on my 3.1L
  9. I rebuilt this 82-83 turbo distributor today. New bearing, all new zinc and a new z31 cas. only issue so far is the Cas disk I have might be bent. also Cas turbo upgrade method #2. This is for a 82-83 turbo distributor. Instead of using long nuts and bolts. I thought this would be a cleaner install. Drilled out the base to allow m5 jis screws. Then threaded and tapped the maxima cas
  10. Stroker update! Paint and finishing touches.
  11. I decided it was a great idea to become a dad at 40 and renovate a 100 year old building to become a brewery/ restaurant all in the same year.
  12. Sorry I’m under slept from my son thinking that 4am is a perfect time to start the morning. Lol.
  13. The fittings on the top are from a Toyota. I’m guessing they are originally toyota carbs. 40s are a great carb for even a fairly built 2.8L. But they aren’t as easy to sell, no clue why. I have sold 28 mikuni’s in the last few years. All but one set were 44s. I don’t know if I agree on the intake or not. But maybe I’m wrong.
  14. We call those S5 mikuni 40s. They are worth around half what 45s are. They have center pull linkage, which is worth around $100-150 each. So a added bonus of 200-300 to the total value. The intake looks to have been cut apart? Which hurts it's value.
  15. Standard Motor Products S2099 https://www.amazon.com/Standard-Motor-Products-S2099-Connector/dp/B009IZRYFC
  16. I know their valves aren't Kameari. Maybe their springs?
  17. Tps adapter for throttle bodies or carbs. The idea is to turn the stock throttle shaft down on one end to 6mm. Then this threads on. IMG_9238.mov
  18. Dual V spray is pretty much all that is offered in the newer injector styles. I went back on which one I am picking, I found a ford GT injector that meets my demands, I have one coming to test fit. It's a 20-30 degree cone style spray. So slightly better. I don't think I need the long nozzle. I think the spray pattern will exit fine without. I am curious if the spray angle for the OER/ SK will overall hurt performance slightly. Maybe it will be a wash with the taper bore? Polishing some stacks.
  19. Nicely done. Those are great numbers.
  20. Wow, subscribed, nicely done!
  21. Vintage Sk throttle body update. I think I found a injector style I like and a oring I like. The injector has a long nozzle and 8 tiny spray holes. The O-ring is some Porsche 16.5mm one meant to adapt newer style injectors, but fits perfectly. Almost too tight, but firmly presses in. Shouldn’t leak air at all and remain snug. I also picked a fuel rail for my vintage ITB. It’s the stock that Tsumori uses in Japan. I couldn’t find anything I loved. I will be doing clear anodized on the fuel rail parts.
  22. 9k is a lot of RPMs. 7000 sounds wild in a straight six. I have all the fancy valve train parts and I plan to never go above 7500.
  23. Sort of soft boot gets pressed over a rigid bump in the coil. Very snug and very water resistant. I would say outside of submerging the car, it would be sealed against cleaning and rain.
  24. We went through 5 N42 blocks before we found one that sonic tested and the machine shop said could take the 88.5 bore.
