10
Everything posted by Exposed
Work has slowed down abit so currently have my sundays back! Got started on the front fender. Did a quick mock up with tape and installed my new turn signal then started laying out some lines on some sheet metal. The plan is to try to have the front fender blend back into the orginal fender and the door, fingers crossed i dont have the remake this peice a whole bunch of times. I ended up notching out the one sections for the turn signal and folding the metal back. After taking another look at it im not to sure I like the cut out section. Might decide to remake it and go for something that feels more fluid. Thoughts? opinions?
Heavy Duty frame rails and connectors
Exposed replied to toolman's topic in Gen III & IV Chevy V8Z Tech Board
@toolman great job on the pie cuts! Looking forward to seeing the finished product -
thanks everyone! appreciate the words. @AydinZ71I had a lot of it, just need to hammer and dolly it.
Where to Order Stainless Tubing and Vbands
Exposed replied to Dat73z's topic in Fabrication / Welding
ace race is good, stainless bros are also good. I always use one of these two. -
@AydinZ71 all mild steel, just ground down some of the welds for now. Still need to hammer them out but limited on time at the moment. @NelsonianThanks! Hopefully start the other side in the next couple weeks. Glad to see everything finally coming together though.
Excited to follow the build! Any pictures?
Slow progress but any is better than none. Hammered out the passenger side rear. Still need to do some trimming but its better than how it was. Need to finish up the passenger side rear quater then weld them to the back.
Great job on the progress! gave me some more motivation to work on mine. Glad to know the new panel was such a great fit.
rear out came out nicely, where did you guys buy your replacement panel from? I started making one this weekend but works gotten abit to busy was thinking I might buy one.
Looking good! Did you paint it??
After fitting the rear quarter panel on the driver side I didn't like how the rear dog leg was aligning so I decided to cut it off and remake a new one. I ended up making the radius section a little more defined the second time around.
@AydinZ71 ya typically ill do a paper template, tape it all over the car and if I like it I'll either make a wood or wire buck.
@AydinZ71 Saw your build its coming along nicely. Can't wait until the rust is all gone. I'm going to need to do some research to see how I'll tube the back.
@Bobendid you ever get this complete?
Great job on the motor mounts, what thickness of material did you end up using? -
Exposed replied to Jboogsthethug's topic in S30 Series - 240z, 260z, 280z
Great update, good amount of pictures. What are you planning on doing with the dash, something custom? Do you have plates on the other side (inside) of the firewall or are the tubes all connected to one another?- 168 replies
- rb25det swap
- 1971 240z build
- (and 4 more)
wheels are 12in outside to outside, cannot recall what the offsets were at the moment. Tires are 225. 45 i think
ya thats the hard part, doing mine right now. Trying to have eveything flow is a pain.
Small update, been trying to finish up the driver side rear fender. Have it roughed out but it still needs to be shaped beside the door and the rear of the panel needs to be brought down another 1.5in after that I can finish welding, hammer and dolly, knock down the welds and then to try to find all of the highs and lows. The panel currently sits past the edge of the rim so that the wheel is tucked in when the car is lowered, I havent decided if I want that or if I would prefer it to be flush.
Yup thats them.
Great progress so far! Are all of the tabs in good shape that hold the bottom of the rear light panel? If not do you plan of making some, buying them or just leaving it as is?
