68
Oh wait. You meant a skirt at the front of the splitter. I had that idea about 10 years ago and emailed Simon McBeath and he wrote me back and said don't. Also emailed Glenn Bunch with the road race Challenger, because he had pics of his on the track with a splitter with a dam on it, he gave it a thumbs down. I shared all of that in page 2 of this thread.
Yes, I did run a skirt. I have it set up on a pivot on the back and was going to run cables in the front, but as it turned out it didn't allow for much movement when installed and there was some other problem I can't quite remember so I ended up using AL fuel line smashed on the ends to make struts for it. Passes the "stand on it" test. 1/2" birch. 3/4 would be really heavy. I just went to Home Depot and found a flexible white plastic that I think is used behind showers or something like that to waterproof. Easy to trim to fit. Have a small 1/2" AL angle section on the splitter, and then it's screwed right to the fiberglass. It looked pretty nice before I drove it, but after the splitter hit a couple times the plastic warped and buckled. Oh well. Race car.
Guessing he found it when he was searching for "splitter." FWIW I ended up making one out of plywood. Didn't want to do it from CF and then break it immediately. Kinda glad I did. It has rubbed once or twice. I've been autocrossing with a club that has 3 classes: FWD, AWD, and RWD. Since the rules are wide open I've been thinking again about doing diffusers and all of that. Have a couple other projects going though, so nothing planned for the immediate future.
You can weld the skin. Just drill out all the spot welds and remove the old roof, weld the new skin in its place. Another option is to cut through the pillars and weld back together. There are differences in the 240 and 280 chassis. Not sure what if anything is different about the pillars. Should be dimensionally the same as the hatches, doors (some lock issues but size and shape the same), quarter windows, and windshields swap. I have a friend who built his roll cage this way, cut the pillars, did the cage, welded the roof back on. A lot of people were poo-pooing this at the time, but I think if I were doing another cage that might be a good way to go. Probably want to stay away from the leaded joints so that you don't make a mess, or melt it all out with a torch and deal with it.
There used to be a good variety of bubble flares that weren't bolt on. MSA had a couple different varieties IIRC, I had some from a company called MAS, Jim Cook Racing had some, there were others. You should NOT buy from this guy, has had a terrible reputation for decades, but he still has the pictures stolen directly out of MSA's old catalog showing some of the bubble flares: http://showcars-bodyparts.com/240z.html
I think I figured out the turn part. You're just saying the MN is superior because it has the port at the same level and the valves lower. OK. Point taken, but again, you're starting with a head with smaller valves, so one might have a better port shape, the other has bigger ports and valves... ???
I agree, it's good to keep hashing it out, although since switching to LS I don't care as much as I used to. It got pretty heated in those threads 20 years ago. I remember being particularly pissed off when Mack said something to the effect of "I can go half throttle and not have any pinging." LOL Here's a different angle: if it's not a race engine (at least a weekend warrior), then why bother bumping the compression up to the bleeding edge? If it is a race head, then why start with a head that has smaller valves and ports and liners when you could shave/shim and end up with something very similar and then have a better starting point to go crazy from? Re the turn from the port to the cylinder, it's not affected at all by shaving the P90, because you're shaving the bottom of the head, and the turn takes place in the port. Might change the distance from the valve seat to the piston, but IIRC the P90 has a deeper chamber and shorter valves, so you'd probably be returning that to a place where they would be more comparable. I think the MN valves would still be closer to the piston. I suppose that's going to matter most when the cam is big enough to put the valves into the pistons, at which point need some flycutting. If someone were building a race head though, ideally they'd raise the port roof and work on the short side radius, and you would do that on either head. Not sure if one has more meat there and can handle more porting, but you'd start out with more to do on the MN, plus installing bigger seats and valves, blending the bowls would require more work, etc.
I never bought the MN hype. Yeah, it has a small peanut chamber, but the ports and valves are smaller too and it has exhaust liners. If you really want that chamber, shaving a P90 seems to be in every way a better answer. I built an admittedly worse E31 that has less quench with about 11:1 and a bigger cam than most people run at .490/280, polished all the sharp edges in the chambers, etc. and needed 95 or 96 octane to prevent pinging. A bigger cam would have helped and I always tell people to go bigger when they start talking cams (stage 3 Schneider is not a good choice). Having been there and done that I wouldn't build an 11:1 engine again with the idea of running pump gas. Also, there isn't that much power in the last point of compression to justify the hassle that goes with it. You would do A LOT better having a 9.5 or 10:1 engine that can run 91 or whatever you have in your state and have the timing optimized than you will running the extra point of compression and having to back the timing off to prevent pinging. This is a V8 video but the point carries over. Timing has a HUGE influence on power. To relate back to L series, I think I was able to run 91 and have the timing at 0 or slightly retarded at idle, which would have been somewhere in the 15-20 degree range all in. Did that for a couple days before I started buying race gas and mixing octane booster and stuff like that. Just KILLED power. You can see the same here: https://youtu.be/HXX4zcPr9IE?t=590
No, sorry. Just convinced that the stock intake is restrictive and the stock turbo exhaust manifold has a T3 flange and is a crappy log manifold design.
Turbo. An L at that power level will have a lifespan measured in hours. I've driven zredbaron's stroker with 300 bhp. It's a lot of fun. Also requires race gas and is fragile. By comparison, I have a 2L 4 cyl GTI with somewhere in the 280ish bhp range (based on the tune and mods) and I can drive it on pump gas, and I don't feel like it's in imminent danger of catastrophic failure. I would suggest if you turbo it that you ditch the entirety of the intake/exhaust systems and start over, new manifolds, bigger turbo, intercooler, tunable FI, get rid of flap door AFM, etc. If you were going to put $10K into a stroker, I'd look at spending that money on swapping in a better engine that is already turbo'd and doing it that way. L series just has too many limitations, IMO.
The key question to me is: ARE YOU DRAG RACING? If you are, then you need to go to something really strong, and as time goes on I think a solid axle is at least as good a choice. If it's a street driver I'm guessing the 4340 axles and a CV upgrade works. Problem is that's already a lot of money, for something that should "probably survive."
I got a hold of Joe on FB, he did fold up Chequered Flag. Never met him in person but talked to him on the phone a handful of times and found him to be a good guy. Bummer at losing another good vendor.
Joe from Chequered Flag is still on FB, so I just messaged him to find if he's still in business. Just 2 weeks ago people were wishing him luck racing that weekend so it would surprise me if he were out of business. I don't have the patience to go through that Super 8.8 thread, but that's a very strong differential. I got to the post where the guy was talking about 2000 hp axles and tuned out. Just look out for systems that end up 100 lbs heavier than they started. Some of the other attempts at 8.8s are just ridiculously heavy. Especially if you have 400 hp, the weight is a bad trade off.
I had a NB and the surfboard seats suck. Worst part about the NB.
curious to know what are the best L Series Transmission options now?
JMortensen replied to primaz's topic in Drivetrain
Supposed to be a manual setting, but IME they never work quite right, and this one is no exception. Hit the rev limiter or hang close to it for a couple seconds and it will upshift just as you dive into the braking zone for the next corner. I'm pretty shocked at how much I enjoy driving it. FWD hatches never really appealed to me, but I wanted something that is fun and that I could run the kids around and go to the grocery store with. I've put a bunch of money into it already, but so far I am loving it. -
240z SCCA vintage race car, restoration
JMortensen replied to AydinZ71's topic in S30 Series - 240z, 260z, 280z
Another tip is to make the holes for the screws oversized a little bit. Apparently if they're tight you can crack it when it heats and cools. I used plastic spacers from mcmaster.com to get my hatch glass to sit flush. -
Jigsaw cuts Lexan like butter. Just don't peel the protective film off, and think about adding some masking tape around the lines too. It scratches so easily and that shoe on the jigsaw has to drag all over it. I buy my Lexan at tapplastics.com. Not sure if they have locations in SoCal, but there has to be someone in that area that sells 4x8 sheets. If you need smaller pieces it's cheaper on ebay than at TAP, FWIW. -
Control arm damage fix opinions
JMortensen replied to calZ's topic in Brakes, Wheels, Suspension and Chassis
I would weld and grind that, personally. If you're using poly I'd suggest sanding the bushings down so that they're not way longer than the sleeve in the middle. If rubber, just remember not to torque until it's on the ground. -
Stainless steel vs plated steel vs aluminum rivnuts
JMortensen replied to fusion's topic in Body Kits & Paint
I used AL rivnuts all over my build. They work great. I've hit cones at autoxes with the flares hard enough to spider web the gelcoat, but the rivnuts were unaffected. You don't need a lot of torque on 1/4-20 bolts, which is what I used, so that also is a non-issue IMO. I have had a few spin where the surface they were put into wasn't totally flat (trans tunnel for instance). They're easy to remove and redo, I expect the zinc or stainless will be slightly more hassle. I bought some zinc plated steel ones and they were way too stiff for my Harbor Freight rivnut hand pliers. No friggin way I was going to do that over and over again, and I glued in a windshield with that glue by hand with a caulking gun. Not touting my super strength, just saying I will put up with a lot if I don't have to buy an expensive tool, and I was not going to do the zinc ones by hand. If you have a pneumatic gun, then maybe consider zinc or stainless if you're worried about it, but AL is fine. -
On the subject of DCTs, I bought a 2007 GTI with a DCT with a bunch of go fast parts basically as a daily, grocery getter, and winter autoxer since the Z leaks from everywhere. I've got thousands of hours on sims, so very much used to the flappy paddle shifting, left foot braking, etc. My main concern about DCT was that it would shift for me when I didn't want it to. This was a problem on the Porsche tiptronics that I worked on back in the day. Mine is supposedly tuned, but it does still shift on its own when I autox it and have it in manual mode. Despite this, I love it. I understand that a better (more expensive) tune on the DCT ECU might help, and will try that eventually. But it really doesn't feel that much like an automatic. You hit the paddle it shifts NOW. Downshift at higher rpms and you can hear it rev match. It's pretty damn cool. -
One other aspect which may or may not be pertinent is the transmission bell housing. I was looking at my LS engine and trying to figure out how much ground clearance I needed. I bought a custom oil pan that was shorter, then when I bolted it up I realize that the bell housing hung down about as far as the stock Camaro pan did, so I paid a bunch for a pan that didn't gain me any clearance. Shame on me for not looking at some pics before I ordered the pan.
He had a Quaife sequential gearbox so shifter was likely right next to the steering wheel.
Never saw pictures of John's, but Cary (tube80z) sent me pics of his mounts that had the engine back 4" maybe 15 or 20 years ago. He might still have them. Not sure if it was lowered. I think you need dry sump or a shorter sump to lower it 2" and not smack the pan on the ground.
Mine ended up at 2352. And it turns. I got sick last year (pretty much all year), finally had surgery in April for "smoldering diverticulitis", recovered for a few months, then bought a GTI to race in the rainy winters here. So I have been racing once this year, and it was in the GTI, which understeers like a mofo and is getting camber plates and a racy alignment in a couple weeks. I wish I had my fastest run from this day which was good enough for 2nd overall and less than a second behind a stripped, supercharged S2000 on slicks, but I'm terrible about starting the camera.
Spindle pin puller
JMortensen replied to Ryanotown22's topic in Brakes, Wheels, Suspension and Chassis
https://zcardepot.com/products/spindle-pin-removal-tool-240z-260z-280z
