Onto the fronts. Looks like the front mount for the control arm isn't going to be double shear Cary. You can see in the photos that the angle iron is about 1/8" away from the TC rod. I actually had to grind the TC rod for clearance (I'm redoing the front part of the rod anyway, so it doesn't matter). There just isn't room in there for both pieces of angle iron. With it situated this way it would be impossible to put a nut on the end to tighten the end link. I could move the brackets further up the control arm, but then I end up with less motion ratio on the bar, and I don't want to make the bar weaker in all 3 adjustment positions if I can help it.
So in the last pic I removed the tacked piece of angle that I had tried, and that appears to be the way it's going to stay.
I've also already cut the end of the bar, but didn't take pics of that. So basically I just need to bend and drill the ends on the bar, and weld the other bracket on the other control arm, and then the sway bar saga will be over.
