JMortensen
    68
  1. If you mounted the engine behind the driver the weight distribution would be really severely screwed IMO. You'd end up with possibly worse than 911 distribution. Basically driving the car would be like throwing a dart backwards, and as soon as you started to get a little sideways the heavy end would want to go to the front. I gotta agree with Alex that mid engine a la S2000 (front midengine) is the way to go in a Z, rear mid engine is going to be a problem.
  2. I'm probably going to be the odd man out here, but I think that 90% of the Z's that have oil coolers on them don't need them. In fact I think most of them do more harm than good, because most people don't run a thermostat, so the oil never gets up to temp. I've run a 30 minute session in 105º temps, come in and checked tire temps then shot my oil pan with the pyrometer. Oil temp was in the 215º range IIRC. Definitely not hot enough to warrant a cooler. Turbos are the exception, but NA's don't need oil coolers in most cases (there are defintely exceptions).
  3. It's been my experience that "the UPS store" has about 100% markup vs actually going to the UPS location and dropping it off directly. I would imagine a dashboard is going to be what they call Oversize 2 or Oversize 3, otherwise known as really damn expensive to ship. You can check rates at http://www.ups.com To figure out the surcharge for oversize, look here: http://www.ups.com/content/us/en/resources/prepare/oversize.html
  4. Searched the drivetrain forum for "240sx" and found these: http://forums.hybridz.org/showthread.php?t=92808&highlight=240sx http://forums.hybridz.org/showthread.php?t=72261&highlight=240sx
  5. Do a search on bumpsteer. Maybe a year or more back I gave a pretty detailed explanation on how to do it on the cheap. I think total cost was ~$40 the way I did it. If you REALLY don't want to measure, then just go 3/4" and you'll probably never know the difference.
  6. That's the problem; there isn't any correct number. I don't know how or if the AZC arms are different from stock with relation to the pivot heights on the outboard end of the arm. It's obviously different than a stock arm since it uses a totally different ball joint, but whether the height from the arm to the pivot is the same... ??? If you just want to get it in the ballpark I'd say 3/4", but to get it right there is no substitute for measuring. If you aren't racing you'll probably never notice IMO.
  7. preith, what timing curve are you running with your DIS setup? I've heard one other person (also with a very high compression race motor) suggesting a really wide advance sweep that goes way up in the rpm range as well. Everyone else I've ever heard talk about recurving, and this is regardless of the type of engine, says start at around 20º and end at the mid 30's at around 2000-2500 rpm. IME my car doesn't accelerate nearly as well with the timing cut down on the low end, it definitely has better throttle response with ~20º at idle.
  8. Jeromio-now might be the time to consider some G Machine bushings in addition to the poor man's toe adjuster. Until you get that thrust angle right the car is gonna crab down the road...
  9. I would just like to point out that moving the pivot up 3/4 or 7/8 is not a true fix. To truly fix bumpsteer it needs to be measured with a gauge, and the correct amount of movement will change based on a number of factors like a bent car, modified suspension, bumpsteer spacers, eccentric camber bushings, etc. When I measured mine I only moved the pivot up about 1/2" and that was all that was necessary.
  10. I run ~11:1 and I have my chambers polished with no sharp edges. E31/L28 combo 490/280 cam. I need 95 octane to keep from pinging and get a full 35º advance.
  11. The LSD is going to make a much bigger difference especially at autox. I'd get the stock flywheel lightened, that only runs about $150 and you can get it down to about 15 lbs. A lightened flywheel is more prone to warping, but it should still hold up fine as long as you don't burn the clutch holding the car on a hill or be a dumbass and drive around with your left foot resting on the clutch pedal. Many machine shops can do this lightening for you. If you decide to hold out for a really light one, then I'd say do the diff first. You can just drop the tranny and swap the flywheel, you don't have to pull the engine. Clutch in a Z is a pretty easy job and that is basically what you'd be up against to swap the flywheel later.
  12. I'm with you Nigel. Some people have to taste the poo to learn, and taste the poo they should.
  13. LCD gets trails really bad from what I understand. DLP less so, plasma not at all. Plasma really is the best if you've got the $$$. Here's a pretty thorough comparison: http://www.avdeals.com/classroom/LCD_tv%20_versus_plasma_tv.htm
  14. Now that you mention it, just leave the cap off and stick your thermometer in the top of the radiator. It might overflow a little when the thermostat opens, but so what? Better than buying a new radiator.
  15. http://story.news.yahoo.com/news?tmpl=story&cid=514&e=8&u=/ap/20050106/ap_on_fe_st/wacky_warnings
  16. Turn the TV off, then do the mute, 1, 8, 2, power and it will come on in the setup mode. When you originally posted mute+1+8+2+power I was trying to hit all those buttons at the same time. Not necessary. Just hit the right succession and you'll get it. One thing I did notice is that mine likes to be on setting one for the TV and setting 3 for the DVD, which is kind of annoying, but worse things could happen.
  17. With a 1" drop I'd just leave it alone. Kinda like sectioning the struts, you COULD, but it's just not necessary IMO.
  18. 3/4 tons usually have bigger torquier engines, bigger transmissions, much larger and stronger differentials, bigger stronger frames, and bigger brakes. 1/2 tons have made a lot of progress in the brakes and engine areas in the last few years, but they are still lacking in the other areas.
  19. That cam is a little bigger than mine which is a 490/280. I wish mine were a bit bigger than the one you're looking at but I think that's because of the triples. 510/280 sounds like it will do fine with SU's, and the build sounds good. Make sure he takes all the sharp edges out of the combustion chamber, even the spark plug threads that stick into the chamber. $650 sounds more than fair. That's a really good deal IMO. Power I'd guess somewhere in the 200 range. Should be fun.
  20. http://www.arizonazcar.com/LSD.html I'm pretty sure that's what this is...
  21. Rev it to 3000 rpm then and set it at 35º and ignore what it is at idle.
  22. I ported my 22RE head and when I slapped it back on my idle was at 3000 rpm, so I would say that porting is going go have an effect on vacuum. Of course so will having a fresh engine (probably a lot more than the porting).
  23. If your fan comes on too soon then what will happen is the thermostat will open and close all the time, because the coolant in the radiator will get extra cold, closing the thermostat, then it will open, let in really cold coolant, then close right back up because the temp drops immediately, and repeat that cycle. It's been frickin cold here, which does almost the same thing as having the fan stuck on. I had to put a piece of cardboard over half of my Toyota radiator just to get the thing to warm up properly. You might want to try that if you find that you can't get it to warm up. Sounds like you might have a stuck open thermostat too, though, because even with no fan the thing should still get to operating temps before the thermostat opens. If you have a good gauge you can watch the thermostat open and close like that even under normal circumstances, but the problem would be exaggerated if your fan came on at 140. You really need to find out if the gauge is right. Maybe you could get a hold of a pyrometer and shoot the radiator after it's been running a while.
  24. Just an idea, but maybe that huge intercooler is causing problems with overheating at idle? Do you have both the radiator and the intercooler sealed to the core support with foam weatherstripping so that the fan can actually suck through all of those fins when it comes on? EDIT--looked at the pictures again and I now see that the IC is about 4" in front of the radiator. I'm not a turbo guy but my friends with turbos are pretty adamant that the IC and the radiator need to be sealed to the core support if they're going to be one in front of the other. Not sure if that is a hard and fast rule or not. Also, even if your thermostat was new before you rebuilt the engine you should replace it. Seen too many "new" thermostats fail after being pulled out of a motor then put back in when the motor is fixed or rebuilt.
  25. That don't make no sense Owen. If the sway bar is connected to the frame and the end links are connected to the body, then it does nothing. It has to connect to the suspsension somewhere. I've worked on a couple 3 series and the BMW end links are very long and they attach to a tab that sticks off the strut. Terry is right, the advantage is that the end link doesn't get tweaked even under full compression or extension. It really is a better design.
