clarkspeed
    50
Everything posted by clarkspeed
  1. You are really doing some great stuff down there. Thanks for sharing and participating in these forums.
  2. The large body Bosch pumps are a great upgrade. Such good quality, I don't have a problem buying used ones off ebay. Most of the part numbers are for different inlet/outlet configurations. So if you adapt to you pump, you can order the same part number again.
  3. I actually bought some 1/4-20 aluminum bolts for interior pieces and such.
  4. I saw a formula SAE car once with variable runner length on 4 trumpets. A simple trumpet tube sliding in a custom intake runner. The trumpets were mounted on a movable wall of a plexiglass box with linkage and a servo controlling. I think the box prevented leak by on the tubes. It looked pretty cool when they reved the engine.
  5. Your piston to head to clearance is fine, but the valve to piston clearance with cam at desired setting also matters. Usually checked with a pre-assembly. Even so, the one time I missed timed a cam the tapping went away after a few revs when the valves made there own pockets in the pistons and slightly bent. Then it showed with comp check.
  6. Might have one in our shop in Orlando. Want to drive that far?
  7. Mine basically had all the doubler plates cut out around the perimeter and the hinge supports. And vents installed.
  8. My race car had a chopped up hood when I bought it. It weighed 26.5 lbs. It eventually began to crack apart after years of abuse. I replaced with FG shell I reinforced myself. It weighs 11.5. I was going to cut up a hatch in similar fashion, but ended up buying FG instead.
  9. Pickup points can vary greatly from car to car. Especially the strut tops. Not too hard to measure. I leveled the chassis on jack stands and plumbbob points to tape on the floor. Took about 3 h ours ea. Front and rear.
  10. I'm using the SusProg3d. I played with the demo version for awhile before I bought. Works ok once you get used to it. You can learn a lot just playing with it. I was amazed how sensitive roll center was to ride height and camber on strut suspensions. I now try to set my ride heights to the millimeter. And you can figure out what is BS and what is not on this forum. I wish I had bought years ago instead of copying others.
  11. Good luck. I was reading an article about the Toyota F1 engine program. They had a dedicated building and about 25 engineers working on their fuel delivery system. Seems the pumps were very hi-tech.
  12. I say invest in a geometry simulation program. I've been playing around with one for a few months now along with re-reading many books. You can change that spacer, lengths of CA, inner pivot points, etc. and see the results in 2 minutes. Some things have a big effect, others do not. It will point you in the right direction.
  13. I say buy the pre-flaired lines. Available locally in most any size you need in 3/16 Dia. Standard unions for long runs and standard tees easy to get. Just buy some standard to metric adapters to convert the ends. Save yourself a bundle. Unless you are restoring to concourse level.
  14. Some shops like to shave a head after it is warped instead of straightening. The head will be thinner on the ends and thicker in the middle. The combustion chambers will measure accordingly.
  15. Reproducing this head could be much more cost effective using selective laser melting in the future. The technology is advancing rapidly. The prices are dropping each year for 1-off and prototype parts. Similar material properties and finishes to investment casting. Unlimited complexities. Amazing stuff.
  16. I also recommend reading Bobistheoilguy forum. Everything you ever wanted to know.
  17. Basic alignment then get some sticky autocross tires. They will cover up most minor handling problems and transform even the most mundane car into a race car. You can then work on improving driving skills. The downside is the tires will wear quickly on outside until you get enough camber for them.
  18. I have raced 2 cars with the plates bolted underneath. No problems seen. I would do something extra if you wanted to put on top.
  19. I run the same Fuel safe box with an external Bosch pump. I forgot to add gas before a practice session at Atlanta and ran out on track. I was able to limp a half lap back to pits. There was less than 1/4" of gas left in bottom of cell. It works great.
  20. Impressive stuff! Thanks for sharing.
  21. What # radiator cap are running? Moving up in pressure may help.
  22. I just bolted up a similar oil pan on my fresh engine a few weeks ago. It's an older piece but I'm pretty sure it is of the Nissan Comp lineage. When i ran the engine we had leaks everywhere. Turns out the ARP main studs were hitting the pan causing a .030" gap. Couldn't see it with thick Nissan Comp gasket installed. So check the fit up before bolting down if you use the studs.
  23. I've been chasing front end shake on the race car for a long time. Most recently thought the rack was bad on center but instead traced it to the splined steering shaft just below the coupling. I removed the shaft and rotated it a couple teeth and reinstalled. Seemed to engage the splines better and the movement was gone.
