Phlebmaster
Everything posted by Phlebmaster
  1. Why not just drop an A15 in there?? JK! The KA would be an interesting project, if you do it I expect pictures!!
  2. It is going to sound good! be sure to post a video when you get it on.
  3. Be careful when making your decision. Don't jump on the first "good deal" you come across. You will get what you pay for so be prepared by knowing what parts are expensive and hard to find and ones that are a dime a dozen.
  4. I wrote this how to from experience... http://forum.ratsun.net/showthread.php?t=10971 I did this on my L4...but it it the same for the L6. I have pulled my cam towers on many occasions, So I thought I would share what works for me. The reason not to do it is simple...binding your cam will wear it out the towers and send metal into your motor. Not good at all. But if you are very careful you can put everything back together without incident by doin this: #1. number your rockers in the order they sit in your head. carefully pull the rockers, springs and retainers keeping them as sets. #2. Put your motor at TDC and chock your chain tensioner and pull the cam gear. Don't lose your chain or you will be pulling your timing cover. I use a 1" dowel about 10" long. #3. loosten the 10mm allen head bolts that are holding your towers first and pull them out. Better be sure you have your torque wrench handy for re-installation. Re-torque can be tricky....you need to snug the head bolts back in first, then go in three to four steps tightening them down. Head bolt re-torque Try like 10lbs, 15lbs, 20lbs, 35lbs, and no more than the standard torque for the final step. Check your owners book for that last step. Then do a quick check on all head bolts at the top setting, being careful not to over torque them. Iv'e done that. #4. Now your cam should spin freely. Then take out all of the other cam tower bolts. They are 10mm socket. #5. Pulling the cam towers can be a bit tough at first..use a rubber mallet and tap very gently while you wiggle the cam towers. There will be several inserts that aid in lining up the towers and they get stuck sometimes. Be sure you DO NOT lose any of them. Your cam and towers should lift right off. Mark your towers 1-4!! Re-install #1. putting everything back in is pretty strait forward...just do the opposite of the steps you took to get it off. If using new cam towers 1-4 according to where they go on the head. #2. Now the tricky part.....getting the towers to line up takes some finesse. If the head is in the car, then you will need to insert the cam into all of the towers making sure you have the right tower on the right cam bearing before you install them. If you don't, you will be pulling them again I promise. Use assembly oil like Lukas or something in the cam towers and on the cam bearing races. #3. line up the cam towers on the head and get the inserts I told you about lined up and gently set them in. Then you take the cam tower bolts and set them in and get them started, but don't tighten them. #4. Now put in your head bolts you pulled and get them started too leaving them loose. #5. The allignment..... now you take your cam and turn it many times as you make the bolts tighter and tighter. This will ensure your allignment and you will know if the towers are off before you finish. #6. once everything is tightened and torqued down, you put your rockers and springs back in. The trick with this part is making sure your cam does not move backward in the towers....keep it lined up!! Line up your timing marks and you are golden. Do not turn your cam with the motor at TDC...otherwise you could bend your valves on the #1 and #4 pistons. Thats about it.
  5. Hahahaha....Yeah right, nobody ever does that!!
  6. You can't be serious!! Those things are hilarious!! hahahaha I would drive one.
  7. Good to know so when I pick up an L28 I know I can use the parts off of my L26.
  8. Hahahaha...nice! That should keep the sharks away.
  9. I always use felpro and never have problems.
  10. I traded a 1973 Datsun 620 truck for my 240Z. I put two years and a lot of custom work into my truck. My wife was very unhappy with my decision to trade, but I took two weeks before I moved on it. It was the right choice! The Zcar is not a plush as my truck.....yet, but that will all change.
  11. I had trouble too, but I just went strait for the battery with a fuse.
  12. Hey that sounds like fun!! I wanna ride too except I am north in Orygun.
  13. This is what I found on Rockauto... 1977 NISSAN 280Z 2.8L 2753cc L6 MFI (H) [L28E] : Ignition : Ignition Coil STANDARD MOTOR PRODUCTS Part # UF10 Choose: [Regular Inventory -- Full Mfr. Warranty] ($37.79)[Wholesaler Closeout -- 30 Day Warranty] ($14.88) $14.88 $0.00 $14.88 AIRTEX Part # 5C1017 Exc. Calif. $23.79 $0.00 $23.79 ACDELCO Part # E571C {#89057910} COIL,IGN 12 VOLTS, USED W/ EXTERNAL RESISTOR SYSTEMS * Non-stock item--shipping delayed up to 5 business days $35.79 $0.00 $35.79 I don't see a resister listed I found this also http://www.jegs.com/c/Ballast-Resistors/11561/10002/-1?sendroiad=2881405659&sendroikwd=ballast%20resistor&gclid=COq-o-fDlJsCFRwpawodvRvQoQ&sendroicid=bbef8492-2d00-41d6-b158-38db0de2603c
  14. It is sad to see such a great project not get finished due to economy.
  15. Wow!! that looks real good. Gives me ideas
  16. Well, let's start with the rear hatch and the defroster lines that run vertical, then you most likely have a knob on your gas door, and your side vent emblems behind the rear side windows. Thems are the rare parts. I am sure that there are more.
  17. Enjoy that car...these are always projects, unless you buy someone elses complete project. lol Keep us posted!
  18. I swapped my L24 flywheel and clutch onto my L26. Works just fine. I don't think the L6 motors are like the L4's. (The L16 and L18 flywheel/clutch (200mm 5 bolt crank) can interchange, but the L20b has a larger (225mm flywheel 6 bolt crank.) I would expect the L24 stuff to work with the L28 and visa versa, can you get pictures or test fit??
  19. I can't wait to see pics of this project.
  20. Ron, what was the original thread you got the first quote from? I want to see what "looks good" so I know what the reference is. Thanks
  21. What's up Phleb?! Sorry it took a couple days to accept the friend thing. I forgot you had to check the little button on the avatar before saving changes, lol. Do you have a project page going yet? Like Skib said, if you want others to be able to post on your build page, don't put it in member's projects...
  22. I had to replace one of mine after fighting with trying to adjust them. I found one was stuck and would not close all of the way. Once I replaced it I didn't get that smell anymore.
  23. WERD!! However...I have seen a local 280Z with the 4bbl Holley and the owner seems to be sold on it.
