stony
Super Moderators
    10
Everything posted by stony
  1. Well finalized the wiring today. Got my taillights wired up for the track. And played around a bit. Sorry in advance for the crap video.
  2. these say they at for 2 OD wonder if heat and freezing would get them over a 2.16 OD strut :> http://www.speedwaymotors.com/Garage-Sale-QA1-Coilover-Kits-2-Inch-Body-7-Inch-Coilover-Sleeve,79340.html
  3. So the struts I have are 55mm OD (2.165 in OD) the collars i found on Coleman racing are 2.08 ID. I'm guessing that if i froze the strut housing and heated the aluminum collar... it would slip right on?
  4. Cool thanks... any idea what size diameter i need. they are 280z struts.
  5. I'm redoing some struts i have for the drag car. Everything i have on the current struts will swap over. All i need is the threaded stuff you slip over the tube. Anybody know where i can get this stuff? I don't need the entire coilover swap just the threaded sleeve.
  6. If you are asking about what i said about the z31 mounts and how they bolt up ... yes you need z31 rb20 mounts.
  7. First time the Z has had seat bolted in with real seatbelts in both spots.... EVER
  8. I want to see what it does on the current setup before i change anything.
  9. Looks like i may not need nitrous after all. On the rev limiter building 15 psi no rev limit 20 psi
  10. http://www.vteworld.com/content/electromech/busbar/terminal_busbars.php
  11. Brakes bled, seat and belts in... time for a drive....crap its raining ;<
  12. Now the question will be is it too loose? Click pic
  13. More boring pics... Got the dash all wired up all the gages work. speedo has a burnt bulb ;< Also got the line lock, Trans brake, and neutral safety switch all wired up and ops checked!!!!
  14. Wiring about 90% be ready for seats soon :>
  15. Car is coming along nicely. Got motivated and actually cleaned up the interior and installed the dash. Put the battery in and after the garage was heated up to around 75 degrees the car started right up!!!
  16. Got my new flexplate in today and installed it. Trans in Had to put this belt in before I put the center tunnel in. Center tunnel in Shifter in. I’m going to try and get the dash in tomorrow. Also need to finish installing torque converter bolts. Then do A LOT of cleanup before final wiring.
  17. Yea I allready got in contact with andy. Thanks.
  18. Sat down, well laid down in the car and got just about everything wired up. Just need to do the nitrous circuit and the chassis harness. Also got in all my certified tranny shields. Only thing left is my flez plate and its in the mail ;>
  19. Its mounted in the passenger kick area where the stock fuse block used to be. It replaces all the wiring. the block with 4 fuses is for the engine harness and the bigger one is for the rest of the chassis, lights and everything.
  20. Well i finally completed something i have been putting off forever. Wiring. its not all done BUT all i really have to do is run wires (14 to be exact) and clean up the engine harness under the dash and its done. This is the first time time i have ever attempted something like this. Probably wont do it again either. VERY TIME CONSUMING!!!
  21. Not really. Damper is installed and I dropped the tranny off to get freshened up and fix a leak. Hoping to have it back next week then its on like donkey konG!!!! Oh wait i did install the nitrous fogger in a different location with a bung and a new intake pipe vs the hokie fitting that came with the kit.
  22. I couldn't really say. i think mckinney has been around the longest.
