After hearing what seemed to be valvetrain noises decided to check valve adjustment. Here is what I found inside. Status: Hydraulic valves, No roller cam. Roller rockers die cast style. Alum heads, guide plates. No major wear on lifters or cam. No broken valve stem springs. No metal or debris in motor valley, heads. It all looked 'good' and clean.
Did find intake #3 preloads VERY easy. Too easy I think. Could crank in all the preload by hand untill the lifter bottomed out. The others felt much more harder almost solid feeling and could not preload them by hand. What I mean by hand is turning the rocker stud nut with my fingers only. #1 intake and ex felt kinda soft but only half as much. I know this is hard to explain.
Something is making noise. The noise has been going on for quite sometime now. Approx 800 miles. And is not load sensitive. This (#3 IN) lifter was on the drivers side of the motor. The side making noise before teardown.
Question:
Do I have a bad lifter or lifters?
Can I replace all the lifters and still retain use of my existing cam?
All lifters have a part number on them it reads... 99277
I'm far from motor savy but know some engine basics.
Enough to know I have a very bad feeling about thi$$$......
Any help would be great.
Grumpvette are you out there?
Thanks!
