NewZed
72
Everything posted by NewZed
What's the difference between a 1978 and 1981-83 l28et engine?
NewZed replied to Junleung123's topic in New Members Forum
No offense - that's obvious. But people put turbo engines in 280Z's often. Anyway, both engines and the car look pretty beat up. The bottom engine looks like a 76 or 77 280Z NA engine. You can tell from the fuel rail and fusible links. Can't tell from your pictures which engine is from the 280Z 2+2. What are you trying to do? -
It's described in the Factory Service Manual (actually it looks like they left it out for 1974. First year of electronic ignition. Try the 1976 FSM). I think that its function is to maintain a consistent gap at the pickup coil.
Surprised that it hasn't sold. Whitehead is incommunicado so that source is NLA. You might add the other axle if you have it, not sure why it's missing in the picture. Are they included? And a pinion shaft flange, although not as big a deal. Somebody doing a V8 swap might just build a new driveshaft and use the same pattern, instead of swapping flanges. classiczcars.com has a nice sale forum and gets more traffic, you might post there. No offense to hybridz.org, I'm sure that things will come back some day, but it's pretty slow now.
And to add a little bit more - it could be a turbo "engine" but without the turbo parts. The valve cover has a stamp on it like the Nissan replacement engines too, so that might be part of the mystery. If you want to dig deeper, get the numbers from the cylinder head. They're right between/below cylinders 1 and 2 plug holes. A turbo head would be P90. A 280Z head would be N42 or N47. -
The bottom engine with the orange plug wires is definitely an NA engine. The top engine with the black wires might be a turbo block, it looks like it has the oil filter mount of a turbo engine. But it's a bad angle. I think I see an AFM on top but not sure. Here are some links to look at. You need better pictures of the top engine. Look at where the AFM is mounted and look for the J-pipe. The AFM is underneath on the turbo engine. It's on top and visible on NA. https://bringatrailer.com/listing/1981-datsun-280zx-turbo-6/ https://bringatrailer.com/listing/1982-datsun-280zx-turbo-12/ J-pipe marked in green. -
Sure, post the pictures. I know that some things are different in the UK, like the 260Z went on for a long time, but the turbo was not developed until 1981, I think. The Z body and the ZX body are completely different though, in both countries. And the turbo parts are obvious. Some people have tried to fool people with the ZX injector cooling fan, because it looks odd. But a turbo is obvious. -
The turbo engine came out in 1981. So a 1978 car would not have a turbo engine. And the 280ZX came out in 1979. I think this is true even in the UK. A 280ZX turbo engine would have a lower CR than a 280Z NA engine, among other differences. -
It is a vacuum operated device that pulls the throttle open a bit to raise idle speed when the AC compressor is working. Also called the fast idle actuator. If you don't have working AC you don't need it.
Are you talking about the top one or the bottom one? There are two types of the top one, one with two inlets and one with one inlet, depending on year of car. The top one is the fuel pressure regulator (FPR). Yours looks like a 1976 FPR. The bottom one is the F.I.C.D.
You're right. That was in the back of my mind, the question has come up before, because on the 280Z's they run it through a relay. I kind of knew it was wrong when I posted it, should have held off. Not sure why they would change to constant power wires over the engine. But, apparently, they did, they show it twice. Doesn't make sense. Continue with the 20 questions... 1982 1978
If the engine runs there's a ground for the injectors. Use the FSM and a meter. You can't get far without doing basic electrical testing on the EFI systems. Download the FSM and the 1980 EFI guide. Use the Engine Fuel and Emissions chapter. The EFI harness has its own ground point. Test at the ECU connector. https://www.classiczcars.com/files/file/32-efi-book-1980/ https://www.classiczcars.com/files/category/14-280zx/
Compatibility 280ZX Turbo Cv axle/Companion flange upgrade to 280Z
NewZed replied to Jyarb's topic in Drivetrain
Compatibility with what? http://www.zhome.com/rnt/FordPower/HalfShaft.html -
I blew up my kid's 240.....sorta
NewZed replied to jvandyke's topic in Gen I & II Chevy V8 Tech Board
Did you grease the half-shaft u-joints while you had things apart. Easier but you can still do it while they're in the car. They'll last about forever if you keep them greased. Tighter, more precise, than aftermarket. There's a thin head screw that covers the Zerk hole. -
what's up with this differential front mount weight thing?
NewZed replied to jvandyke's topic in Drivetrain
It's small in the drawing, but this would be the part. It's factory. http://www.carpartsmanual.com/datsun/Z-1969-1978/axle/rear-suspension/83 -
It's a damper for diff noise and vibration. Many people take them off. -
Removing 280z dash- heater controls
NewZed replied to fusion's topic in S30 Series - 240z, 260z, 280z
I found a picture of some on the internet. The slot is right next the sheath and the side on the right in the picture snaps over the edge of the metal framework. Might need a thin blade and some lubrication to get it off. Don't break it. https://maseraticompound.com/products/datsun-280z-oem-climate-control-cable-anchor-clips -
There is a metal clip that holds the cable sheath down. One end fits in to a small slot and the other snaps in to a different slot or over the edge of the assembly. Can't remember. Pop the clip up and remove it, then lift the sheath up to get the end of the cable out of the hole. In reverse it would be insert the cable end in to the hole, lay the cable and sheath flat, then insert the clip and clamp the sheath down. The clip is outlined in green here. I outlined the metal clip here. -
It might be the pipe to the air regulator heating block. The air regulator sits on an aluminum plate with coolant running through it. The plate gets hot and keeps the regulator closed. Probably hard to get to but all you need to do is replace the hoses. Here's a picture of the regulator. It has two large air hoses that connect on each side. The plate is underneath.
